Question about Kenmore Side by Side Refrigerator
Kenmore refrigerator model number 10657562790 a 1997 coldspot. water quit working to drink and for icemaker. Filter? any solutions
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
SOURCE: Water filter stuck on my Kenmore Fridge
I had the same problem. I coudn't get the knob to turn. I ended up taking the front grill off so I could get a better grip on the knob. Once I did that I still have to put a lot of pressure on the knob to turn it but that did the trick. When I got it turned a quarter turn then it was easy to pull the filter out. Hope this helps!
Posted on Jan 11, 2009
rogrrabbit
  • 986 Answers
SOURCE: Oue Kenmore Coldspot ice-maker quit working. Any
Wake up one morning and Boom no ice left in the bin. What happened and What can I do to fix it without calling someone? Some ice makers will get a piece of ice in the wrong place and jam the extraction. Get a hair dryer and heat up the ice maker to release the fouled ice cube and that baby will start going. No water in ice mold?Do this easy test: pour some water in the ice maker mold and wait. If it kicks out a batch, but it has no water in it, most likely the water valve is bad. water%20valve%20for%20water%20and%20ice%20through%20the%20door.jpg Watervalve for SxS box Since it is the cheapest part and you can do it yourself replace it. If it turns out you need a new ice maker then you have a new water valve already to go with it. What if the ice maker has ice in it but won't harvest any? One cheap and easy item for the do it yourselfer to replace is the ice mold thermostat. Check for voltage between T and H if you have 120 volts then the bi-metal (inside that ice mold thermostat) is bad. If it's good you will have 0 volts. ice%20mold%20thermostat%28modular%29.jpg Ice mold thermostat Located in the plastic housing and seated against the ice mold is that thermostat. This looks intimidating but is easily fixed by anybody who could change a spark plug. There is no wiring. One more thing to look for: You can put a jumper between L and V and this will activate the watervalve. Have rags ready! If you are a cheapskate and want to be frugal and not buy a new ice maker or a new head(brain) head1.jpg modular crescent ice maker you may want to remove the main gear and clean the copper plate behind it. That plate gets dirty and won't allow for a good contact with the water valve connection and does not power up the valve...Shhh! They will all be doing it! Modular crescent Icemaker test points: With NO power to the icemaker, and ice ejection fingers in the freeze position: Your ohm meter should read 8800 ohms between L and M, and 72 ohms between L and H. With power ON to the ice maker: If meter reads 0 volts between L and N you have no power to the ice maker. If the meter reads 120 volts then you have power to the ice maker. If you have 0 volts between L and H heater is off if you have 120 between L and H the heater should be ON. If you have 0 power between L and M the motor is off. If you have 120 between L and M then the motor should be ON. If you have 0 volts between T and H the thermostat is closed If the meter reads 120 between T and H then the thermostat is OPEN. If the voltage is 0 between N and V the water valve is closed. If the meter reads 120 water should be filling the mold.
Posted on Nov 11, 2009
SOURCE: getting water
I have Kenmore Coldspot refreidgerator and am having a problem with water pooling inside the fridge at the bottom underneath the drawers (mostly the left side). Where is the water coming from and it formed a thin ice.
Thanks
Posted on Dec 22, 2009
SOURCE: kenmore coldspot model 106: top freezer leaks
Have you tried adjusting the freezer temperature to a higher level? This worked for my Kenmore. It will take a couple of days to quit leaking.
Posted on Dec 19, 2010
I have a Kenmore 55602400 Coldspot and the icemaker has stopped making ice. What do I need to do to fix it?
The model number you listed is for an air conditioner. Please check inside the refrigerator for the model number?
Oct 15, 2012 | Kenmore Refrigerators
Kenmore Coldspot Model 51572200 is leaking water all over the floor
On the bottom rear of the refrigerator as you are looking at it from behind the left side where the water is feeding into there should be a double valve. 1 is for the water and the other to the icemaker. Many times that valve won't shut off, however the switch that dispenses the water is evidentially bad and needs to be checked if it is stuck open.
Jun 03, 2017 | Kenmore Side by Side Refrigerator
I have a Kenmore Coldspot refrigerator with top freezer. The icemaker is "leaking" if it is the right word into the ice tray bin that it is building a chunk of ice along with the regular ice...
What that sounds like is the water valve isnt fully closing. This tipi wrote is about that issue,
http://www.fixya.com/support/r10343350-icemaker_drips_causing_all_ice_freeze
Reply with your exact model number as found on a label usually on the ceiling of the refrig. compartment and i will give you the part number for that water valve.
GENE
Sep 05, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My icemaker quit working. Water does not come in to fill the tray. Water source is turned on. In door water dispenser works fine. What should I do to troubleshoot? I don't hear the solenoid click in...
have you checked the inflow tube to see if it's iced up? if your icemaker isn't filling with water and your getting water in the dispenser your feeder tube is probably frozen
Apr 11, 2011 | Kenmore Side by Side Refrigerator
I have a leak inside my Kenmore Coldspot Model # 106 72104100. It is not coming from the icemaker.
If the water filter is old the seals will leak into the evaporative tray overflowing it. Replace the filter or give it a turn to bypass.
Jan 26, 2011 | Kenmore Refrigerators
Kenmore coldspot 105.59502992 ice maker doesn't work. Water flows through the drink outlet though a bit slow it seems.
Lines may be frozen and most of these machines have an in-line water filter that requires replacement. Also check the water inlet valve to make sure it is fully opening. You can get parts and manual at repairclinic.com
Sep 22, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Kenmore coldspot ice maker quit
The first step you need to do is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board. If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker. You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Thank you for contacting Fixya.com
Aug 12, 2009 | Kenmore 52632 / 52634 / 52639 Side by Side...
What is the part number for the water filter for a Kenmore Coldspot refrigerator model 106.54209300?
The part number is 4392922 for the water filter. You can purchase this water filter at the below link for $ 34.49
http://www.freshwatersystems.com/p-3051-whirlpool-kitchenaid-deluxe-filter-4396510.aspx
FreshWaterSystems
1.877.335.3339
May 17, 2009 | Refrigerators
Trouble with ice-maker
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the second one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Sep 30, 2008 | Kenmore 52632 / 52634 / 52639 Side by Side...
Kenmore Side by Side Refrigerator Logo
54 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
