Question about Intex Pool & Spa
58145 filter pump not working
The filter pump worked for three days then when connecting it will not work or make any noise
3 Suggested Answers
SOURCE: Engine cranks, won't start. Three days later, it starts???
probaly a fuel pump its common for vehicles to do that the best thing to do next is a fuel pressure check to verifiy its the pump
Posted on Apr 15, 2009
lee428920
  • 52 Answers
SOURCE: cranks won't start
smelling gas like you are is a bad thing, engine must turn over to fire injector. sounds like flooding ( possible ECM/power computer bad ). Before condemning the computer pull all spark plugs, disable ignition coils, then try cranking to see if engine will turn over. Be carful if hydro locked gas will be pushed out the spark plug hole/s
Posted on Feb 07, 2014
Testimonial: "Hydro-locked? I don't think there's any water in the cylinders, unless you're using that term in a more general way and you're referring to the potential flooded gas as the hydro-locking fluid. I'll give that a try. If it does crank without the plugs/coils, what does that tell me? If it doesn't crank without the plugs/coils, what does that tell me? Sorry for the relatively stupid questions - I can change parts (brakes, sensors, fuel pump/filter, etc), but my diagnostic skills start and end with "it makes a bad sound"."
Signs my 95 chevy tahoe fuel pump is failing
For how long after does it make noise it's not uncommon for the pump to stay running 3-7 seconds after shut down however if it getting noisy you may need to change your fuel filter restrictions in the system will make it noisier
Aug 31, 2012 | Cars & Trucks
Polaris 380 wheels not turning
check wall fitting filter inside probably clogged and wont let water flow that's why plug blew out repair person should have caught that bad tech
Jun 24, 2012 | Polaris Pb4 - 60 Booster Pump
My washing machine will not drain. no error messages. umplugged and plugged back pressed start it will beep three times everytime you press start but it will not do anything else
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Please revert for any further assistance.
Hope this helps...
Daniel
Feb 10, 2011 | Washing Machines
Last couple of days when i started my my car up it would idle fine but when i took off it would sputter out and end up dying on me and i would have problems starting it back up i would have to pump my gas...
you can usually hear the fuell pump more and more as its going. try the fuel relay first. i cleaned mine and it worked for a while again. my fuel pump also made a noise and this is usually the end.
i reversed the fuel pumps motor polarity and somehow all the gunk came out. the pump still works
after about three months, if not more and the noise is much less.
Dec 26, 2010 | 1997 Volkswagen Jetta
I have a bestway 10 ft pool, filter making loud noise, doesn't seem to be working. Its only been in use for the last 2 days, tried releasing air, makes no difference.
Normally, the filter does not make any noises! The noise is generally from the pump. Since I am not sure what you have on the pool, to be able to find the issue, we will need a bit more information.
Do you have a seperate pool pump and filter? The pump will have a motor and some have a debris basket in front of the motor. If this is where the noise is coming from, you may want to return/exchange the pump if it is only two days old!! When you turn on the system, do you see water moving to the pump, air in the basket, or is the motor getting hot to the touch?
If you have a seperate filter from the pump, what is the pressure gauge reading on the top? If you have one, check it when the noise starts. If it is higher than it was when working properly, you have a blockage somewhere from the filter to the return line. If lower, then you may a small leak, generally o-rings, and will need to replace what is bad.
If the motor on the pump is making the noise, then it can either have debris in the Impeller area, or it is going bad. Hope this helps! If you can let us know what pump and flter you have, we may be able to find out what is going on.
Jul 01, 2009 | Pool & Spa
Apr 15, 2009 | 2000 GMC Jimmy
1998 gmc sierra. fuel pump making a whining noise. any ideas
Often the closer they get to giving up, the noisier they get. Changing filter might help. I've seen them last 6 mos, or 6 days, but clean filter will easy the work load on it, and may or may not buy you some extra time. If it does go after filter, your not out anything because a new filter should accompany a new pump anyway.
Apr 10, 2009 | 2003 GMC Sierra 1500
Wash machine agitates but won't drain the water -- on any cycle choice. Machine makes noise like something is happening, but water remains.
Yes, the problem is the pump filter which is hidden behind the lower front panel. To access the filter, unscrew three screws at the bottom of the panel and carefully remove the lower front panel. Make sure to unplug the machine. With the panel removed you will see the pump filter. Get a bucket and some towels ready, because when you open the filter, you may get a gallon plus of water coming out. GE failed to put this in the use and care manual for the 6260. But low an behold, GE put an access door and explicit instructions on cleaning the pump filter in the updated 6400.
You may have burned out your washer pump. That is what happened to me. The machine would not drain or spin properly and so I kept pushing the blinking start/pause button to get it going again. Then it finally did not drain at all. I installed a new pump and with the cleaned filter, the machine worked like new. For some, simply cleaning the filter allows the pump to work properly. As the filter gets clogged the pump has to work harder and harder to pump out the water. When this happens the cycle times get extended . One symptom of a clogged filter is the final minute (spin cycle) takes much longer. Obviously this is a "design flaw" that GE "fixed" in the recent version of the 6260.
Jul 07, 2008 | GE WCVH6260FWW
Pump Problem
Our lucky fix for this identical Christmas day problem was to put the reservoir in place about half full of water, then to reach down in it and pull the plunger up to open it. We had the machine running at the time, but that may not be necessary. regards, Gene
Dec 23, 2007 | Breville ESP8XL Espresso Machine
Pool & Spa Logo
64 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
