Question about Western Digital 500GB ELEMENTS 500 GB USB 2.0 Hard Drive
My Elements 500 ext hard drive no longer appears on desktop
On Mac 0s 10.4.11 - Elements was disconnected without being put in trash. ... Since then has just  spun - blue light flashing but never appearing...
I did this on my PC. Took it to the shop (Harvey Norman). The techie reckons I got a spike across the terminals because I did not properly disconnect. He reformatted the drive for me. Unfortunately i lost everything on it (unrecoverable anyway he said). Worked fine till I got a problem with the transformer. Still working on that one. Know where to get a new transformer/power supply?
Posted on Feb 09, 2009
I purchased a Toshiba Canvio 3.0 500 GB portable hard drive, and plugged it into my MacBook with Mac OS X Tiger. The icon for Toshiba EXT came up on the desktop but wouldn't do anything. The box came...
1 . Open the system drive, usually titled "Macintosh HD." Open Applications, then Utilities and double click the "Disk Utility" program to open it. A window will open giving a list of all the drives currently mounted on the computer.
2. Select the disk that needs to be formatted on the left. It is not possible to format the startup disk unless the system has booted from the Install Disk. It is important to note that formatting the startup disk will permanently erase the data stored on the disk. If you are planning on erasing the startup disk, back up all important files and applications.
3.
Click on the "Erase" tab to the right of the list of drives. The window will now display the options for erasing the hard drive and formatting it to work on the Macintosh computer.
4. Select the Volume Format from the pop-up list. In most cases it's best to leave it at "Mac OS Extended (Journaled)" as this is the default. This setting is the best option for running Mac OS X. If there are other requirements for the disk, then select the format that best suits your needs.
  • 5. Name the hard drive. Type a name for the disk in the field where it asks for the name. This name will always appear when the disk is mounted on a Macintosh computer.
  • 6. Click the erase button. A window will open asking to verify the erase procedure. Click the erase button in this window to start the process of erasing the disk. Once the process is complete, the drive will appear with the name it was given on the left side of the window with the list of drives and on the desktop of the Macintosh computer.
    Aug 30, 2011 | Toshiba Canvio 500 GB USB 20 Portable...
    The power light on cord is blinking and I'm not detecting it in my drives.
    IF PLUGGED INTO EXT. CORD, REMOVE AND PLUG INTO WALL OUTLET. IF THIS DOESN'T HELP REPLACE POWER SUPPLY.
    Aug 12, 2010 | Western Digital 500GB ELEMENTS 500 GB USB...
    External drive no longer appears
    Hi Neil The are many reports of these drives doing just that (mind you, it's not confined to WD)
    I'm guessing you're on a Mac - did you install any of WD's software?
    the WD software does nothing on a mac other than cause problems. The best thing is to try connecting to another mac to see if it shows up there.
    On the positive side, most times it's not the HD but the enclosure that is at fault.
    Sep 10, 2009 | Western Digital My Book Essential 500GB...
    Usb devise not recognised
    You probably damaged the drive from sudden disconnection of the signal line. I would suggest trying it on one other computer before considering it trashed.
    Jun 08, 2009 | Verbatim 500GB USB Desktop 500 GB Hard...
    My Western Digital Elements external hard drive is no longer recognised by either of my computers. When I attach it to computer it says it has found new hardware and installs it and when I look in device...
    Check the Disk Manager to see if the disk has a valid partition and is recognized as being formatted. Start -> right-click My Computer -> Manage -> select Disk Management.
    If not, then your MBR could be corrupted.
    This troubleshooting external hard disk article should help you further.
    Jules
    Apr 21, 2009 | Western Digital 500GB ELEMENTS 500 GB USB...
    Lap top will not boot correctly when not connected to ext hard dr
    First u check the laptop Display
    if it has display, thn it might be problem ur windows
    instead of it.
    if computer does not give display thn u check the power adopter of ur laptop.
    after all gonig through these steps.even u find all these above steps perfect.
    it will mean,
    it might be problem of ur hardware.
    lets check out it by ur computer vendor.
    Thanks
    Danish khan
    Feb 01, 2009 | Western Digital My Book Essential Edition...
    Creating space on external hard drive
    When you move files to the Trash on a Mac you are just marking the files to be deleted next time you empty the trash. You are not actually deleting them when you move them to the trash. They will continue to take up space on your drive until you empty the trash.
    Emptying the trash will delete everything in the Trash folder regardless of which drive it is stored on. If you have files you are not certain you want to delete that are located on your internal drive, open the Trash folder and move them temporarily out (like to the desk top), then empty the trash to delete all the ones on the external drive that you do want to clear off.
    You will see that the free space has increased on the external drive. Now put back in the trash the files from your internatl drive you were thinking of deleting but not certain you wnated to (if that is your reason for not wanting to empty the trash. I'm not clear on why you would not want to delete them.)
    Apr 04, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
    URGENT HELP NEEDED (editing a film) G4 0S 10.4
    It sounds as if the enclosure has failed. IF THE DRIVE IS GETTING POWER, but not making strange noises, you may just need to extract the drive from the enclosure. Keep your fingers crossed. If the drive has been affected, data recovery may be the solution. Good luck.
    Sep 06, 2007 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
    Western Digital 500GB ELEMENTS 500 GB USB 2.0 Hard Drive Logo
    321 people viewed this question
    Top Western Digital Computers & Internet Experts
    Arora Singh
    Arora Singh
    Alun Cox
    Marcin
    Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
