Question about Vacuums
Where can I get a Shop Vac Model 85L250B manual
  • 7 Answers
SOURCE: shop vac 90L400 stopped working won't start
I had the same problem with the same model. Turned out to be the thermal fuse on the motor housing, between the switch and the windings. Took it apart and replaced the melted solder with 14 guage copper wire. Works fine! No thermal protection but I don't use it for long at a time anyway. Check the switch for continuity, if good then check the thermal fuse for continuity. If good, it's the motor.
Posted on Sep 28, 2009
  • 8404 Answers
SOURCE: I just bought a shop vac at a yard sale. it is
Take a gander at this site ... http://www.shopvac.com/
Posted on May 01, 2010
  • 447 Answers
SOURCE: Change shop Vac Model LM500 from dry to wet pick
To change from dry to wet, remove the paper filter and install ball float if not already attatched
Posted on May 16, 2010
SOURCE: vacuuming up water with Shop Vac model 84M200
when picking up dry materials use the foam sleeve that slips on and the blue cloth (assuming there all blue) over it, there should be a ring that slides over blue cloth to hold it in place over the foam sleeve, for wet pick up u can use the foam sleeve minus the blue cloth but let it dry out before picking up dry stuff, you can pick up both wet and dry with a cartrige filter that looks simular to a car air filter and it slips over the foam sleeve, but let it dry out after picking up water before picking up dry cause itll just clog it up
Posted on Aug 29, 2010
javeedcare
  • 316 Answers
SOURCE: I have an old shop
http://www.hammerwall.com/Download_Manual/16114/
GO TO THE ABOVE ADDRESS TO GET YOUR MANUAL.
REGARDS.
PLZ RATE THIS
Posted on Jul 04, 2011
I bought a 1 gallon shop vac at an estate sale. They said it was new. It isn't. The model # is 2E200. The front says shop.vac 1X1. I have no directions can't open it or put the hose in it.
You have two options: return it to seller or put the information about the model number and name in your search spot and Google for manual.
Mar 23, 2015 | Shop Vac Vacuums
the fact that it blows dirt out when you use it is a simple solution just simply clean the canister out really well and replace the filter it is either ripped warn or you simply do not have one on the unit and as for getting a users manual just go strait to the shop vac website and go from there and you will be able to find what you want and download a manual for free
Mar 28, 2014 | Vacuums
I have an old shop vac floormaster wet & dry vac, 8 gal., model 700c. I need the users manual to find out how to use it as a wet vac.
REGARDS.
PLZ RATE THIS
Jul 04, 2011 | Vacuums
Lost manual need to know how to use as a wet vac 2 hp model Qas60
Here is a list of MOST Shop Vac Manuals. I did not see your model number, however you may be able to find it know the exact name of the vac. Best of luck!
http://homeappliance.manualsonline.com/manuals/mfg/shop_vac/shop_vac_vacuum_cleaner_product_list.html
Mar 10, 2011 | Vacuums
Older model shop.vac parts/owners manuel
Hi, I know on my Craftsman shop vac 2 different sizes of vacs that I use, I try and stick to the craftsman filters, but you can use other brands if they are not available or you want to save some ( $ ) ? As far as a manual for this vac, more then likely you will have to go to the maker and distributor as Sears, O.C.Hardware also sell there products. You may have to go with a manual that is the same peak H.P.and gallons that covers all different makes and models. Filter wise, make sure you have the right ones on or off when using the wet or dry pick-up settings.
Sincerely,
Shastalaker7
Jan 23, 2010 | Craftsman 17765 Canister Wet/Dry Vacuum
Shop vac 90L400 stopped working won't start
Oct 19, 2008 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Need an owner's manual on line
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19255&thid=658668
Posted by LinJay on Jun 09, 2008
I have lost my owner's manual for my shop vac and need to figure out how to set it up so I can pump out my flooded basement using a garden hose.
Is there anywhere I can find an owner's manual on line??
The model stated on my vac is not what I clicked on your site....my vac states:
Model QPV 10.5
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I am supplying you with the contact for the Shop Vac Factory Service for owner’s manuals listed below: for the website and the customer service line, but make sure you include the Shop Vac Model # and the Serial # as well. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://shopvac.com/contact.asp Customer Service 570-326-0502 Phone #
Shop-Vac Corporation Customer Service 570-326-7185 Fax #
2323 Reach Road
P.O. Box 3307
Williamsport, PA 17701
Hours are: Monday thru Friday 8:00 am to 5:00 pm (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 09, 2008 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Vacuums Logo
62 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
