Question about Kelvinator 12 cu. ft. / 340 liter Chest Freezer KDC-47
My kelvinator fridge freezer wont freeze in the freezer but the fridge is ok
  • Anonymous Jan 25, 2009
    my fridge freezer no worky fridege ok but wont freeze the freezer
  • 3 Answers
Check freezers blower fan, might not be working
Posted on Jan 24, 2009
My Kelvinator N245C fridge freezer is ok but fridge not cooling when i open the freezer door , the cold air through to fridge air outlet ok but when the freezer door shut and than no air to the fridge the...
first look for an air vent in the bottom of the fridge(a small grill on the inside wall) & make sure nothing is blocking it, like bread eg: if there isn't then unplug your fridge & let it defrost, check the drain outlet in the back of the freezer, sometimes a small item like a frozen pea gets into the drain & the water freezes around it causing the air not to return to the freezer from the fridge, to push air into the fridge you must be able to get air out or it presurises,
Nov 01, 2011 | Kelvinator 12 cu. ft. / 340 liter Chest...
I have a two door kelvinator it freezes the food aside
Ok, your thermostat is buggered, the fridge wont turn off becaust it hasnt been told from the thermostat, easy DIY but be aware DISCONNECT the power first and unplug from the wall and do not kink the thermo tube when replacing. Buy the same thermostat and take a pic of where the wires go before removing the old one. Hope that helps, if you need help, call me on 08 9523 0552 Russ and I can help further.
DONT FORGET TO VOTE, I JUST HELPED YOU FOR FREE
Mar 02, 2011 | Kelvinator Freezers
Hi, I have a Kelvinator KCI 35 BFF fridge freezer, the fridge is freezing all the products I am putting in it. There is a control at the top of the fridge freezer which controls the freezer. There is no...
There should be vents on the wall of the fridge that you can close up a little more. the cool air comes from the freezer into the fridge. Check it out and let me know. Also just for good measure>>>
Jan 07, 2010 | Freezers
Kelvinator fridge freezer is a geiger counter
something could have fallen into the fan between the two compartments
Nov 10, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
Fridge not getting cold
unplug unit to "reset." pull unit out from wall and blow the coils out on the back of refrigerator. if that does not work- call service man to come check freon level.
Aug 09, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
Kelvinator Fridge/Freezer C 340 RM does not switch off
the problem is your thermostat in your frig.the dial with numbers on it.it is no longer sensing properly and theres nothing you can do but replace.that is as long as your dial is not broken[the plastic pice with the numbers] God bless ,tom
Jan 10, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
Kelvinator freezer is not freezing!
you mean it cools but not as afreezer ok, rework again the system properly vaccum and slowly charge it but please watch out the proper amperage of the compressor or might be the compressor motor now is weak, how old this unit,sir.thankyou
Aug 05, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
Freezers Logo
847 people viewed this question
Top Kelvinator Freezers Experts
Mike Squire
Victor Nwachukwu
Victor Nwachukwu
Are you a Kelvinator Freezer Expert? Answer questions, earn points and help others
