Question about NA Black & Decker MM875 Lawn Hog 19-Inch 12 amp Electric MulchiMower with Rear Bag
Black and decker electric lawnmower mm875 won't start
Won't start
Shaft turns while trying to remove blade on B&D MM875 elec. mower
Here's the scoop on the MM875: it has a plastic piece called a "blade insulator" (part # 241381-01) that "locks" the shaft to the blade, so that you can remove the nut by stopping or blocking the blade. If it has been damaged or stripped out, then stopping the blade won't do anything. However, the metal spacer directly under the nut IS still locked to the shaft (because of its shape), so you can use a pipe wrench or something to hold that in place and unscrew the nut. You might even be able to get someone in a home improvement store to do this for you. But you will still need to replace the insulator, which is only a few dollars.
Jul 22, 2010 | Black & Decker 19" Electric Lawnhog...
Black & Decker MM875 blade
You can pick up a blade at almost any hardware store.
Sep 26, 2008 | Black & Decker 19" Electric Lawnhog...
New black and decker lawn mower, MM875 starts but I cannot get it to cut, what am I doing wrong?
did you sharpened the blade. checked the blade if not installed reverse.B&D clean the blade. info in the blade say's facing the grass
Aug 17, 2008 | Black & Decker 19" Electric Lawnhog...
MM875 electric lawnmower
check motor if armature are not broken & see if the rectifier not burnt. rectifier works from ac & convert it to dc to run the motor.
if you need diagram for parts see toolpartsdirect.com
Aug 27, 2007 | Black & Decker 19" Electric Lawnhog...
NA Black & Decker MM875 Lawn Hog 19-Inch 12 amp Electric MulchiMower with Rear Bag Logo
Top NA Garden Experts
Dan Apthorp
Steve Corstvet
Steve Corstvet
Level 1 Expert
Are you a NA Garden Expert? Answer questions, earn points and help others
