Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave wont start
Clock sets fine and all the numbers beeb when pushed except for the Start button which doesn't make any sound or start cooking.
  • daveyseeg Jan 24, 2009
    Thank you for offering such detailed advice and problem solving!
  • braundharbor Jan 25, 2009
    Our microwave won't start and the turntable has stopped. Digitable programming [timer, clock,beeper] still works. Where do I start investigating?
  • GE Master
  • 9,098 Answers
Assuming the Start pad on the keypad is good, I would strongly suspect the upper or lower door switch or the switch's mount, depending on your model number.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
It's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
Posted on Jan 24, 2009
  • William Miller
    William Miller Jan 25, 2009
    If you need more help, please let me know, and I hope you'll consider a FixYa rating if it turns out I'm right.
    Thanks & good luck!
I have maytag advance cooking system(electric) and the oven will not work.The timer to set the oven and the time is not lighting up but the stove is working.any sugestion
try resetting the clock. If it is digital, push the clock button and then the number buttons untill you have the proper time displayed...then push the clock button again. If your clock and timer are manual, try pushing in the clock lever and turning it 1/4 turn. If this works it would indicate that your timer has a start and finish time and that the oven is not working because the clock has rotated around to the finish time.
Sep 09, 2011 | Microwave Ovens
Our Kenmore Microwave Oven # 721.89941490 does not respond when the "start" button on the touch pad is depressed. All other functions of the oven work normally, including time set, count down, light,...
poosible burned contacts on cook relay mounted on circuit board; or, a defective solder connection(s) on same board. another spot to check in the door microswitches.
Aug 30, 2010 | Microwave Ovens
My mother just bought an Emerson MW8119 Microwave and can't figure out how to only set say 15 seconds cook time. Is it possible?
Hi! I just purchased the same microwave, and came online to find the solution. I was then able to find the correct answer to this problem. On this model, Emerson does not put a "time cook" button for odd cook times such as 15 seconds. Instead, they have you push the "Power Button" prior to setting the cook time.
If you want to cook on full power, press the power button once, and then enter your cooking time and press start. If you want to cook on 50% power or 30% power or something like that, push the "Power Button" several times until the appropriate power level is displayed, then enter the cook time and press start.
The reason that it starts up right away when *********** pushes the 1 button is because Emerson has the quick cooking feature for 1 minute through 6 minutes. You only have to push the number once to get the 1 minute cook time or anywhere through 6 minutes respectively.
Hope this helps!
Jun 22, 2009 | Emerson Microwave Ovens
Emerson microwave, #MW8119SB, push start button to start cooking
Replace the fuse with a ceramic fuse from Home depot! costs less than $3 and it will fix the problem. I had all the same problems as everyone else, you name it my microwave had it! you must remember replace it with a ceramic fuse! not a glass one. I know people say its the switchboard and all that nonsence but I promise you, the fuse plays a majoe roll in the microwave not working properly. Even though it doesnt look broken, a junky fuse can cause your appliance to do very strange things. I replaced mine 6 months ago and it works like its fresh out of the box.
Apr 08, 2009 | Emerson Black Microwave Oven
No power
To enter the time you must push the clock button once before you enter the time and again after you enter the numbers. Try that and you should be all set.
Please mark this as a fixya! thanks.
Mar 11, 2009 | Emerson Microwave Ovens
Old Quasar (Panasonic) Microwave won't work
I believe you need to set the clock on that before it will take cook programing. So Push the clear pad then push clock, Maybe clock twice. Been a while sorry!! set the time and I think you have to puch clock again, for it ro start the clock or start. As long as you do not puch cook then any time pushing start should only start the clock. That should do the trick. Good Luck!
Oct 19, 2017 | Microwave Ovens
Oster 1.1 cu. ft. Stainless Steel Combination Microwave Grill - OMW1199
After six months I just figured it out. Push the cook by weight button in and hold it until the clock function comes on. Turn left for hour and right for minute. Figured this out by holding the cancel button in and a child lock came on, I didn't know how to release it so I reversed the process by holding it in and it cleared. I tried it with the cook by weight, which has a small clock icon next to it and voilla.
Oct 26, 2008 | Microwave Ovens
Whirlpool(GH7145XF2-0) does not work occasionally
That's how it would sound if you were cooking on a power level less than full power.
If you enter the cooking time and hit Start, it should cook at full power by default and not cycle like you describe.
If you are using some sensor cook setting or automatic type cooking setting, it may cycle like that normally.
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
If you don't have your manual, you can download it free here. Check the lower right area to enter your model. number.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 17, 2008 | Whirlpool GH6177XP Microwave Oven
Sanyo Em-u1000w
i have the same microwave and mine does the same thing,try this push the clock button and enter the time or just push 100 and hit the clock button and then enter in your cook time and hit start.
Jan 10, 2008 | Sanyo EM-U1000W Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
282 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
