Question about Oster 5834 ExpressBake Bread Maker
Oster Breadmaker stops after kneading cycle
I can program the cycle and it will go through the kneading process, but then there are several beeps and it shuts off. If one more appliance I own breaks I'm going to cry. Can someone help?
  • 1 more comment
  • ijustam1 Jan 25, 2009
    It was definitely set on bake. No error codes. It just shuts off instead of displaying the "RISE" cycle like it used to.
  • Wise Old Soul May 11, 2010
    Are you sure you didn't accidently set it to just make dough, not bake?
    Are there any error codes displaying?
  • Leah Stevenson Jan 15, 2018
    Same happening for me: definitely on bake, no error codes. I did a workaround by putting it on the dough setting, then on the bake setting, but it wasn't as good.
    President:
  • 1,734 Answers
Find the manual for download here
Posted on Apr 09, 2009
How to use machine sunbeam oster bread making machine model 4811
go google and type in--operators manual for sunbeam bread maker model 4811-- and if there is a manual available in pdf version down load it
just be aware that with these machines there is a period in the program where after the needing process, it stops for a period to allow the dough to rise before it goes to the cook process
most machines work on the same principle so if you can not find a sunbeam manual see what else is available and check it out
Feb 21, 2016 | Sunbeam Oster 1.5 To 1 Lb Bread Maker...
Paddle won't turn properly while kneeding
does the pan turn at all while kneading? Does in knead at all?
Feb 03, 2013 | Oster Model 5812 Bread Machine Loaf Pan...
Breadmaker will not startup
which program are you selecting? Is it whole wheat?
Jan 23, 2013 | West Bend WestBend Hi-Rise Breadmaker
Kneading blade comes off during breadmaking process
Yes, if the blade come off then your bread is not going to mix and knead properly. The blades on all makers are designed to slip on and off though so you can remove them for cleaning etc. Be sure you are pushing the paddle all the way on. If it still comes off when mixing that would be very odd as the weight of the dough ball itself helps keep paddles on. I have owned dozens of machines by different manufacturers and never had a paddle come off in process.
Jan 01, 2013 | Sunbeam Oster CKSTBRTW20 Bread Maker -...
My breadmaker is on the dough setting and will not beep to let me know when to add ingredients to the dough
If there is no beep just look at your manuals cycle times and verify how long the 2nd knead takes. Then set another timer such as an alarm clock or oven timer etc. to alert you with a beep that coincides with 5 minutes BEFORE then end of the 2nd knead. Add your fruit, nuts etc. then.
Mar 06, 2011 | Black & Decker B2000 Bread Maker
Plugged in breadmaker, selected time, mixer will not come on. Tried unplugging and restarting. Beeps when you plug in and select light works. Will not mix ingredients.
If you want it to come on right away you need to not be using the timer at all. You need to select one of your bread programs, basic, whole wheat etc. and push start it will start kneading right away or after a few minutes if it detects the temp is too low.
Oct 10, 2010 | Oster Kitchen Appliances - Others
Paddle sticking in bread when baked bread is removed. Oster Breadmaker 5838
This is a common problem. The solution is to take the paddle out of the machine after the last kneading cycle and before final rise/bake. You may want to take the pan out of the machine to remove the paddle to be safe...unless your machine has a pause cycle. Hank
May 18, 2010 | Oster 5838 ExpressBake Bread Maker
Loaf falls in the middle and outside is hard
Falling in middle is usually due to innacurate measuring of liquids. Try again using the instruction manual's recipe and very carefully measuring. Be sure to adjust the liquid if you use honey or other liquid not called for in the recipe.
orleydog
Feb 01, 2009 | Oster 5836 ExpressBake Bread Maker
Oster 5834 ExpressBake Bread Maker Logo
331 people viewed this question
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Ben Eng
Level 1 Expert
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
