Question about Kenmore 62602 Electric Dryer
Runs but does not heat up
Electric runs well but no heat
    Sniper:
  • 50 Answers
If the dryer runs and doesn't heat check the fuse or circuit breaker first flip the circuit breaker to off then on again. to check fuses check visually to see if wire across meter is broken. if this doesn't solve the problem check the terminal block where the line cord attaches to the dryer the red block is the heat block, if ok turn power off and manually take the heater out and check for a break in the coil. if you have a multi-meter just take one wire off heater and set meter on ohms and put one lead on one heater terminal and one on the other if meter pegs the heater is ok if it only moves a little or not at all the heater is no good if heater is ok check the thermostata in the same way. but my money is on a bad fuse or heater, thermostats very rarely go bad
Posted on Jan 24, 2009
Electric dryer runs but no heat. all thermal and motor and heater element have continuity.
Dryer Diagnostic - Not Heating up - Repair ... - YouTube
? 11:16
https://www.youtube.com/watch?v=3Vns05qIjGs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your trusty Maytag Electric Dryer suffering from some of the ... However, in REGULAR mode, it runs normal too, but theheat stops ...
Maytag Dryer Not Heating - How to Test the Heater and ...
? 4:12
https://www.youtube.com/watch?v=_zjiZ0sbCgI
Oct 12, 2013 - Uploaded by Bill Newberry
How to test the heating element on a Maytag Dryer. If you Maytagdryer is running but not heating these are what you need to check. ... The dryer runs but does not heat. .... Not heating Maytag electric dryer - Duration: 19:38.
Not heating Maytag electric dryer - YouTube
Jan 13, 2016 | Maytag Dryers
Runs but no heat
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
May 29, 2010 | GE Profile Harmony DPGT750EC Electric...
The dryer runs but will not heat up
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
May 20, 2010 | Whirlpool GEW9250 Electric Dryer
My dryer runs, but doesn't heat up...
heatman101
May 19, 2010 | Whirlpool LER4634J Electric Dryer
The dryer runs but does not heat up
Depending on your heat source (gas or electric), your problem could be one of the following:
* if electric: heat element, thermostat or timer
* if gas: gas coils, radiant sensor, thermostat or timer
Note: In either case, check to ensure that the dryer is receiving the proper amount of electricity (110 volts for gas & 208-220 volts for electricity).
Feb 19, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Carrier heat pump (basic model) runs at 0 or below
A basic model heat pump with an air handler with electric strip heat generally will continue to run with a call for heat regardless of the outdoor air temperature unless there was an outdoor thermostat (an accessory) installed. There is still heat in the outdoor even at temperatures of zero and below. Generally, there is a balance point of approx 30-35degF that allows the heat pump to heat your house to 68degF without the need for the electric heaters. Below that, the heat pump can still extract heat from outside and "pump" it into your house; however, it will need help from the electric heaters. In temperatures below the balance point, the heat pump will run non-stop. As the temperature in the house falls approx 1 - 2 degF below the setpoint, the electric heaters will energize. So it is not uncommon for the system to run non-stop with the temperature falling a few degrees below setpoint. The colder the outside temperature, the more often the strip heaters will cycle on/off. If your system is well-maintained and operating at proper performance, it is still cheaper to run your heat pump than it is to run on straight electric heat. If you live in a climate where below zero temperatures are normal during the winter months, you might want to research heat pump options that offer higher COP's and increased performance in colder temperature than the basic contractor's model. Start with initiating communication with a local contractor. You will need to consider initial cost and the pay-back period based on your local energy costs and your specific demands you want your system to meet.
Hope this helps!
Feb 14, 2010 | Carrier 38CKC036 Air Conditioner
My unit has been running all day. set on 75 degrees and still only 65 in the house
If this is a heat pump depending on the outside temp. it may not bring the temp. up. It is really not efficent to run a heat pump below freezing or near freezing.I suggest running the Auxillary electric heat if. Most heat pumps have auxilarry back up electric heat banks installed in them.
Dec 26, 2009 | Heating & Cooling
Dryer will run but does not heat up
Either bad heating element or missing one leg of the 240V circuit. The motor runs on 120V.
Sep 24, 2009 | Whirlpool LER4600 Electric Dryer
Kenmore 62602 Electric Dryer Logo
65 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
