Question about Whirlpool 2217220 PUMP
Ice maker circulation pump - Whirlpool 2217220 PUMP
It is not making ice. We cleaned it with solution; etc. the light when we press "on" or " clean" does not blink; stays steady. Water comes into the pan in back; we can hear we think, the compressor r
Remove the plug in the right rear that connects the circulation pump, test for 110V voltage at the plug ramaining in the bracket, this machine was made by whirlpool for Scotsman, usually after a clean is done with the solution, it's very common that the circulation pump mecahanically fails. Either the impeller has slid up on the shaft, or the steel plate has rusted and caused an alignment issue with the shaft. You will most likely need a replacement pump, Scotsman part# 02217220. PleazerAppliance....
Oct 01, 2014 | Scotsman CSW45 15" Ice Maker with 26 lb....
Ice maker kitchen aid kuic18nnts won't pump water over chill plate. Replaced circulating pump still no water.
Does the circulating pump- pump water? Remove the hose that goes to the spreader bar and run the unit again, if it moves water as a new pump should check for blockages in that hose and spreader tube. Get back to me if this doesn't work please. Personal email address kidlmo@gmail.com...
Jul 21, 2014 | KitchenAid KUIS18NNT 18" Automatic Ice...
Ice maker leaks water into ice bin
Some things I have seen that causes this issue:
A. Plug not sealing properly in the bottom of the water reservoir
B. An issue dealing with the circulation pump. Maybe splashing water out of the reservoir while running due to crack in pump housing, especially around impeller, or hose that feeds water from recirculation pump to cold plate has a crack/split/loose connection.
Dec 23, 2013 | GE Monogram ZDI15C Automatic Icemaker
I have a Kenmore ice maker that makes a sucking sound while cycling. The water pan will not fill up all the way between cycles and my ice harvested is thin and cloudy. Do I have a pump problem? Can it...
It sounds like your water supply line might be partially clogged probably at the water inlet valve in the bottom left front of the machine. I think there is a screen in there that you can clean out. The circulation pump will make a sloshy surging sound when not enough water is cycling through it as it pumps it up to the ice making sheet. You may need to replace the inlet valve itself. Pour extra water into the water reservoir in the interior of the machine and see if the pump runs smoothly thereafter.
Dec 31, 2010 | Kenmore 51lb. Clear Ice Maker
My clr 2060 ice maker is not doing anything,their is no ice in the storage bin. opened up ice maker and cleaned the condenser coils. Found red light on board lit, with a slow steady blinking green light
HI
It sounds like you have a drain issue. You can do a test with the unit on open the panel with the board and remove the 2 pink leads and make a jumper for those terminals. If the unit comes on 3 min fill then circulating pump and compressor and fan come on then you know you either have a kink in the drain line or a bad pump. If your unit doesnt have a drain pump then the pink lines could be open and it will turn the unit off too.
Sep 13, 2009 | U-Line Icemaker
Does this ice maker need a pump or is it built in zdis15css
It has a circulation pump that continuosly supplys water over a plate that forms a slab of ice on it. As the slab gets thicker the resistance values change in the ice and the machine opens a hot gas solenoid operated valve which floods the plate with heat from the condenser below. This makes the slab slide down the shoot onto a wire grid that is heated. The slab is cut into tiny little cubes and drops off into the ice bin. So yes the machine has a circulator pump. Ever so often you need to put it into the clean mode and add some nickleguard or ice machine cleaner to keep the pump and its components all happy happy.
Jun 13, 2009 | GE Monogram ZDI15C Automatic Icemaker
U-line CLR 60 B ice maker
U-Line's tech line is 1-800-2547. The compressor, condenser fan and circulation pump operating at the same time?
May 24, 2008 | U-Line Icemaker
Whirlpool 2217220 PUMP Logo
13 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
