Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Bulb went out
Read that filter may help the bulb last longer. Is there a place to put a filter on so that dirt does not get into system.
    President:
  • 1,077 Answers
This maybe a McGuyver thing. Last thing you want to do is block the air flow to cool down your TV set. I would blow out all the dust, get a HEPA filter for house ventilation, get a computer cooling fan. Cut and put the filter in front of the fan, make the fan blow in to the TV vent in the back, that way it blows clean air in and keeps dirty air out. I hope that's one good idea.
Posted on Jan 25, 2009
Car wont star up makes rumbling sound and wont start
Could be one of several things. Check your spark plugs and distributor/rotor first off. If the distributor cap has lines inside it, or gray deposits on the inside terminals replace both it and the rotor. I highly recommend NGK Iridium spark plugs... put them in and forget about spark plug issues for 60K miles! Be careful when removing the distributor cap to unplug one wire at a time and place each wire in the proper place on the new cap each time, so you don't get them mixed up. Check your air filter and vacuum the dirt that sits underneath the filter to help it last longer. Changing air filters once a year is recommended to make sure your engine can breathe properly. Look at your vacuum line diagram under the hood and trace every connection making sure there are no unplugged lines or holes,
Apr 10, 2015 | Cars & Trucks
Tip
Air Filter changing - easey and often
Examine the air filter at the beginning of each cooling and heating season and at the beginning of each day light savings time change. Write the date on the sides of new filters so you know when you changed them last.
A filter you can read a stop sign through is not a filter just a bigger trash collector. It wont stop particles that cause hay fever and irritate asthma. A filter that will help these items is one that you cannot see through except for light.
Keep a new filter on hand so you can compare the differences in color of the media. Some particles are so light colored they can only be seen by contrast.
A filter grille can usually be installed in under an hour (if the hole is correct size). Not only does it make changing a snap but encourages more frequent check ups. And this eliminates the indoor unit door not being put back in place correctly.
While changing look over the old filter for signs of moisture or special or different colors of particles so as to tell you about how good or poor the filter is doing. Wipe down the grille or door while open.
A washable filter is okay but you keep some of the dirt every time you put it back in place. Throwaway filters and electronic air cleaners are an excellent combination.
on Mar 28, 2009 | Carrier 38BRC036 Air Conditioner
I cleaned my filter and forgot how to put it back on, how?
Hi there! To return the air director back into the dirt cup, rotate 1/4 turn clockwise to lock into place. To replace the pleated filter. Return filter cartridge to base of cleaner. Click button on filter cover back into place to lock filter cartridge in base of cleaner. Hope this helps! I have also included a link to the instruction manual for reference if needed. Thanks! http://dirtdevil.com/file/956/
May 20, 2014 | Dirt Devil Easy Lite Quick Vacuum
How to change the fuel filter on an Echo 315
Im going to assume that this echo saw is the same as most saws. Open your fuel tank and remove the cap completely. Empty the fuel from the tank, and try to swirl around the fuel to get the last bit out and any dirt that might be in the tank. Compressed air can be used to blow the tank out or flush the tank with some more fresh fuel. This is important to help your new fuel filter last longer and also the reason why the filter would need replacing. Using a length of wire, coat hanger or smaller, make a small hook on the end, small enough to get into the fuel tank, big enough to fit around the fuel line. Place the hook in the fuel tank and fish out the fuel line and the gently remove the filter from the tank, its on the end of the fuel line. Pull the old filter off and push the new filter on, Place back in the tank, Fit the fuel cap chain and fuel cap. Job done. Hope this helps
Oct 04, 2013 | Echo Chain Saw Service Repair Manual...
I have a Karcher WD 3.500 P wet dry vac. First ? when vacuuming dirt off floor do I always need the bag or is the cartridge primary filter ok.. I clean it regularly. Second problem. I went to turn on...
The bag is part of the filtration design of the machine. Using it will not only make your primary cartridge filter last longer, but make the vacuum suck more efficiently & make your vacuum as a whole last longer.
You can bypass the switch to check if the motor is okay.
More often than not an intermittent operation of a machine is actually due to a break in the power lead. This is not always apparent externally though. You may need to get this checked by a qualified / certified person.
Mar 29, 2017 | Vacuums
My irobot 530 is not collecting any dirt in its bin. Why would that be?
Most common issue is the filter is clogged try washing it out make sure you let it dry completely before putting it back in. replacement filters are available on ebay last time I checked they were 3 for under $10
The 530 uses a vacuum suction along with the spinning motion of the brushes to pick up dirt make sure its making a vacuuming sound if not could be only the brushes are moving and a motor has died on you.
lastly make sure that the brushes are spinning freely remove the tray that holds the brushes and clean it out with compressed air. the tray easily removes by first taking off the lower pan and removing the 4 screws that holds the tray in place. There are no wires to unplug when doing this.
hope that helps.
Jan 05, 2010 | iRobot Roomba 530 Robotic Vacuum
2001 chevolet cavilier brake lights & blinkers burning up
sounds like you put a 21 watt bulb in place of a 6 watt bulb ,or you have put single pole bulb in place of a double filament,double pole bulb
Feb 02, 2009 | 2001 Chevrolet Cavalier
Hvac
When was the last time you checked your filter? Suppose to be changed every 30--90 day , depends on the type of filter .If you remove the filter and the same low air flow, then the dirt and dust went to far and need a full serviced on your system. (koolbreezes74401@yahoo.com.)
Jun 09, 2008 | GE Heating & Cooling
Dacor IVS1 Vent Hood - How to change a light bulb?
Buylighting.com, JDR120V-75W-E27CG...also comes in 50 watt. They aren't inexpensive, but if installed properly, will last a while. We have a little suction cup to take them out and put them in. It came with the range hood. If you get fingerprints on a halogen bulb, it can blow out quicker.
Dec 30, 2007 | Kitchen Ranges
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
78 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
