Question about Roper REX4634KQ Electric Dryer
Our dryer is working fine until it trips the switch.
The tripping of the switch has become more frequent about once every 2-3 uses.  I have been told it might be because of the heater box.  Can you help me diagnose the problem?
I have a Maytag dryer that is approximately 12-14 years old.
I have never had any trouble with the thing until now.  It has been a great dryer.  Also I just replaced the belt about two weeks ago and it works fine until the dryer stops due to the tripping of the switch at the fuse box.
thank you very much for your help.
Jeff
    President:
  • 1,214 Answers
If tripping of the switch means the circuit breaker is tripping, then yes, the problem may be in the heater box, or may be the motor. It could also be some faulty wiring though, and a good tech could easily determine what is causing the failures.
Posted on Jan 24, 2009
What part need to replace LG DLGX5171V keep getting power Trip or stop working
Check wires going to motor. Must be a short there.
Aug 16, 2017 | LG Dryers
I have had my whirlpool dryer about 4yrs + (geq9800pw2) has always worked fine. Last week it started tripping ckt breaker toward the end of drying cycle. As of this morning, it blows ckt breaker...
leave off the oven and a/c breakers and plug dryer and reset the breaker. if not tripping occurs then one at a time trip back the oven first. if no trip then trip off again and trip the a/c. if no trip then trip the oven back. if trip you may have a wire problem. if dryer trip any way then possibly you have a short in dryer. check the heating element wires,power cord at the dryer side(terminal block).
Feb 14, 2011 | Dryers
Dryer is 2 years old. Worked fine until we moved to a new house and could not hook it up. 1 year later I finally had the electric problem fixed and hooked the dryer up No Heat. Dryer turns on but NO Heat.
is the outlet 3 or 4 prongs?. voltage check the outlet for propper voltage. check connection at dryer power cord. 2 of the wires power the motor circuitry(120vac) the other 2 the heating element. you may have a loose connection in outlet,switch wires or bad-half trip breaker. if not,,,, there's a dryer problem, call us again with update please. good luck to you.
Feb 07, 2011 | Dryers
I had my oil changed in October after the "oil
Try this procedure and let me know if this does not work;
Turn the ignition switch to the "On" position but do not start the engine.
1. Press the Trip/Reset button until "Setup Menu Hold Reset" is displayed.
2. Then press and hold down the Trip/Reset button for approximately 2 seconds until "Reset For System Check" is displayed then release the Trip/Reset button.
3. Then immediately press and hold down the Trip/Reset button again for approximately 2 more seconds until "OIL 100% RESET IF NEW" is displayed then release the Trip/Reset button.
4. Then immediately press the Trip/Reset button once to display "HOLD RESET IF NEW OIL" then release the Trip/Reset button.
5. Then immediately press and hold the Trip/Reset button again for approximately 2 seconds until "OIL LIFE SET TO 100%" is displayed.
Turn off the ignition switch, and then start the engine to verify that the reset procedure did work, and you might have to repeat the procedure if the Trip/Reset button is not pushed fast enough, or it is not held down long enough, or it is held down too long during the reset procedure, and it may take a few attempts to be successful.
Nov 11, 2010 | 2006 Ford Explorer
Hotpoint WDM 73 keeps tripping ringmain when powered on
I suspect that the problem is probably being caused by a fault on the dryer element or thermostat.
Remove the top cover and disconnect the heater, and see what happens..
If it does not trip, then prob is the dryer element or stat.
Hope this helps.
Jan 04, 2010 | Hotpoint Ultima WDM73 Front Load Washer /...
Speedqueen Commercial Dryer trips electricity
there is moisture in there and it trips off the safety switch. some refridgerator points are not connected to the safety switch, this can dry out the moisture and this safety switch is there to save lives, don't touch the appliance when on and do at own risk because i am covering myself, you shouldn't have any problems but i have to cover myself. there is leakage from probably the element to earth which is the reason i sugest to try and dry it out. your element could be blown as well? you might need a sparkyto replace element
Jun 01, 2009 | Speed Queen AES68AWF Dryer
Hoover CA230 1300 Special Edition Washing Machine
Should you have to use un due force to get the filter undone on the Hoover 1300 special deition washing machine
Jan 14, 2008 | GE S8000E
Hotpoint CTD00 trips the power
This happened to me.
Your condenser unit on the front bottom left corner may be clogged up and causing water to back up around the fan and heating element behind the rear panel.
Take condenser unit out and give it a good clean removing as much fluff as possible.
If the heating element senses damp on it, then it will trip the electric.
The back panel which is at 45 degree angle on back. I took this off and sure enough there was water in there.
Wipe away all water and use an ever so slightly damp cloth to remove as much dust stuck to the metal as possible.
I used a hair dryer for about ten minutes fanning over the heating element and circular fan. Don't rush this. Take your time to make sure all signs of damp have been removed from heating element before putting the back panel back on.
After carrying out the above my machine worked fine and no longered trip electric.
It is a pain, but to prevent this problem happening I suggest cleaning condenser unit about once a week if you have alot of washing. Empty water panel after every two loads, maximum.
Good luck
Jon
Oct 24, 2007 | Dryers
Dryer tripping electricity saftey switch
You probably have a shorted heating element.
May 15, 2007 | Miele T1322C Electric Dryer
Roper REX4634KQ Electric Dryer Logo
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
