Question about Sony Handycam DCR-HC42 Mini DV Digital Camcorder
Works great for about 5 minutes then shuts off
I have a Sony steady shot CCD-TRV52 that we are donating to an area school. We thought that it just needed a new battery but after getting a new battery and charging it the camcorder will work great for about 5 minutes then shut off. Any ideas of what could be wrong with it?
  • paul_roth Jan 26, 2009
    Yes it does...thought about that right away too.
  • Roberta Smith
    Roberta Smith May 11, 2010
    When you run it on external power... does it do the same thing ?
    Robert
    Brigadier General:
  • 5,158 Answers
Ok... simple solution that battery is possibly defective or the camera has an issue that causes an excessive draw on the battery. digital camaras eat batteries anyways. when you bought the new battery did you charge it for at least 12 hours before the first use ?
Robert
Posted on Jan 26, 2009
I have a Sony dsc s600 that works great except all the pics come out totally black. Is this caused by a bad ccd?
not usually, it is caused by under eposure make sure you have the settings of the ISO to a level that is complimetary to daylight
set it to 100 and to say scene and take a few pics. Donload them on to the PC and with the software look at the graph that accompanies each pic to see what is happening with th light factor. You can drag areas of the graph and the pic will alter on screen.
Perhapsa the shutter is not opening.. look in the lens and press the button to see if the shutter actuall opens and shuts
Please rate my help++++Thanks for using FIXYA
May 16, 2010 | Sony Cyber-shot DSC-S600 Digital Camera
I have a sony Super Steady shot DSC-T200, worked great until after the warranty was over. Now it intermittently shakes and the picture in the viewfinder shakes. When i take a picture it is very blurry....
if you alsow get vibrationOn Sony T100 and similar,
its the vibration canceling unit, i had the same problem.
if you have good hads you can fix it.( on your oun risk)
1) disasamble the camera, you will see black plastic box inside, this is he lens unit.
2) on the botom you see 2 scrwes, they are holding the CCD remove them and the ccd unit will come from the lens assembly
3) the next is the stabilizer unit it is the problematic one. it is located on the left side of the lens asebly and is held by 2 screws.
you can test it by puling out the cable connected to it (the conector is just under the lens) and verifign that the problem is solved. ( you can leave it this way it will shoot fine just without the anti shake)
4) to fix it take it out ,remove the plastic cover, you see the lens on a plastic mount it should be glued to the magnet under it. the problem is that the glue fals apart.
remove one of the pins on wich it slides, and take the lens and the magnet out.
5) reglue the magnet and reasemble the camera.
6) power up and test, for me that solved the problem
if you need more help you can mail me at adisarit(et)yahoo(dot)com
this is spam mail so be prepared to wait a few days for reply.
i have a document with pictures explaining it
Aug 19, 2009 | Sony Cyber-shot DSC-W200 Digital Camera
Recorder
I also have a SONY 460x Handycam Vision CCD-TRV68 NTSC video Hi8 Steady Shot not able to record a picture but will record audio, playback is the same. Unfortunatly this occured after warranty was out. Seems like this might have been a manufactors defect.
Sep 24, 2008 | Sony 2.0MP Handycam High-Definition DVD...
Same Cam shutdown Issue
hummm, thats fine. go ahead n let me know of out come for knowledge ;)
May 29, 2008 | Video Cameras
Picture shakes when I zoom
I don't know how you can easily tell the spec for the anti-shake is working on your camera. There is a specific specification for how much it can compensate. There is a factory spec that specifies that with a specific lens magnification ratio, the camera can be moved a specific number of arc-seconds and display within a specific amount of movement error. At home it would be impossible to do a technical evaluation of this feature.
What you can do as a user is to read the instruction manual about the option and see how to make sure that it is turned on in the camera's menu section. It is possible that your model may not have the feature. This you have to check in the spec sheet that came with the camera.
When the anti-shake is turned on, you should see the picture appear to be more stable than when it is turned off. With high zoom settings, it will be less stable looking than with wider angles of zoom. It does have its limitations.
Professional photographers normally don't like the anti-shake feature for shooting videos. For still pictures it is a good feature if you want this type of performance. This is because with moving video taping when the camera is being panned in small motions, the smoothness of the pan is taken away. The stabilizer starts to work at the beginning of the pan and then it gives out in sort of stepping actions. This can create a sort of jerking type of pan motion in the pictures.
Jerry G.
May 02, 2008 | Sony Handycam CCD-TRV318 Camcorder
Sony HandyCam CCD-TRV52
download one here:
http://www.iq.sony.com/srvs/DocsConnect/docget.asp?manualid=7182&DL=true
Oct 21, 2007 | Sony Handycam CCD-TRV418E Camcorder
Pictures with areas of color distortion
I know this is an old post, but this sounds like a defective CCD imager. If so, Sony should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info: http://camerarepair.blogspot.com/2007/11/sony-konica-minolta-cameras.html
Applicable cameras include:
Cyber-shot DSC-F717, F88, P10, M1, P12, P2, P31, P32, P51, P52, P7, P71, P72, P8, P92, T1, T11, T3, T33, U10, U20, U30, U40, U50, U60, V1
CD Mavica MVC-CD250, CD400, CD500, and FD Mavica MVC-FD100, FD200
Aug 22, 2006 | Sony Cyber-Shot DSC-U30 Digital Camera
Sony Handycam DCR-HC42 Mini DV Digital Camcorder Logo
118 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
