Question about GE WBSR3140DW Top Load Washer
I have a top-loading washer. I put a comforter that was too pig in there, and now the agitator goes, but only slightly-not the full back and forth. And its making a high pitched humming sound when it drains...any idea of what to do? My husband is in Iraq, so no man-help here!!!
  • 640 Answers
Ok see if you can pull that agitator straight up...and check to see if you wore the splines down and there not catching...onthejob
Posted on Jan 25, 2009
How do I remove agitator?
On a top load washer, grab the agitator on opposite sides and pull up while wiggling it back and forth. The agitator is on a vertical slotted spindle and the further down it goes makes it tighter. By being slotted, the agitator will not spin on the spindle but only come off by coming up.
Oct 23, 2014 | Washing Machines
How to remove clothes stuck under agitator
the agitator should pull straight up, you may have to twist it back and forth as you pull upward. when you put it back on make sure its all the way down and in place, this may be the reason your clothes are getting stuck under it.
Aug 23, 2014 | GE WBSR3140DW Top Load Washer
Cabrio washer 5d error code
chances are the 5d error code you see is actually sd. it is supposed to signal excessive suds in the water but it seems to show at other times as well. but regardless of the code and depending on you mechanical abilities, remove the center cap on top of the agitator, remove the bolt and remove the agitator. some force may be needed to get the agitator off the shaft, keep equal pressure 180 degrees apart and work around the base lifting the agitator, gently rock the agitator as you lift. when it comes off take the screws from the gear hub assy out, probably six screws. when the cap is lifted off you should find a small gear, pull it off the shaft, clean and look at the teeth inside. if worn, get replacement part. put back together and run a rinse and spin cycle or similar to see if it spins . hopefully it will solve your problem.
May 31, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer works fine just no agition goes though cylces just fine fills and drians fine but agitator does not move
80040 dog kit is all you need. The upper portion of the agitator has four dogs mounted inside. As the transmission moves the agitator back and forth these dogs catch the side of the upper agitator. This rotates the fins and makes the clothes tumble on top of each other forcing them into a downward motion. When the facing of the agitator dogs wear smooth the upper agitator will cease to function.
I have a service manual and more videos HERE
Feb 10, 2011 | Kenmore 24032\24036 Top Load Washer
I have a GE washer that will not agitate. The washer thinks it is agitating and goes through the cycle. The drum turns but the agitator doesn't. What could be wrong with it and how hard is it to fix?
Pull the agitator off and check the plastic block attached to the shaft top. Is it split or has sheared splines inside it? Remove the mounting screw to expose the shaft. Does it turn back and forth when it should be agitating? If no, possible transmission problems.
Jul 15, 2009 | Zanussi FJS1225W Front Load Washer
I put a down comforter in my Whirlpool Ultimate Care II washing machine (I have done this at least 50 times). Last time, it got hung up around the agitator and started making a funny sound. The agitator...
Pull the agitator off and check the plastic drive hub at the top of the agitator shaft. It should not be split, or have it's internal splines sheared off. If this all looks ok, then likely transmission problems or a slipping drive belt (motor to transmission). Good luck!
Jul 12, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator not engaging
it will spin freely try to move it back and forth in full spins. if it spins both ways you need to replace the agitator dogs
Jan 28, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitator moving just a little.
If it is a Whirlpool or Kenmore make washer you probably stripped the "dog ears" in the agitator. They give you the duel agitation that makes your clothes cycle from top to bottom of the machine. Should only rin you around $8.00 or so. Hope that helps.
Jan 24, 2009 | GE WBSR3140DW Top Load Washer
GE topload washer Agitator
theres no nut and bolt,,only a cam or bell have to roch agitator back and forth,,until it losens,,and pull up reall hard..or put your belt under agitator and yank up..onthejob
Jan 23, 2009 | GE WBSR3140DW Top Load Washer
Wheezing sound
The inside tub moves on the spin stage only and cause the water, by a centrifugal force, to be forced out of the clothes. During the wash cycle,the tub is stationary and the agitator moves forth and back. If you would like to remove the agitator - Remove the inner agitator cap (inside the top of the agitator) and then open the screw (be aware not to lose parts !) Good luck !
Jun 11, 2006 | Whirlpool LSQ7533JT Top Load Washer
GE WBSR3140DW Top Load Washer Logo
49 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
