Question about Hoover U8125-900 Savvy Bagged Upright Vacuum
Drive and brushes stopped
Savvy U8125-900. when we turned on the vacuum the brushes would not spin. we checked for blockages and there werent any. we waited 30 minutes and still nothing. tried again the next day nothing. the brushes move when I rotate them by hand. Clean bag and plenty of suction. Any ideas?
  • 548 Answers
Look for a missing belt that may have burned off or broken. Was there a burning smell at some point before the roller quit turning? If so, the belt must be replaced. I would also look at the ends of the roller to see if there is any string, hair, etc. that might be binding the roller that needs to be removed.
Posted on Jan 24, 2009
Replace belt on Hoover savvy vacuum
There is not a brush belt on your model. It has a drive mechanism that turns the brush rolls.
Feb 20, 2016 | Hoover U8145-900 Savvy Bagless Upright...
Brush spins once then stops.
I don't know this machine but I'd check the bearings on the ends of the brush to see if they are spinning freely. If it has a drive belt try changing it, if it is an impeller drive check the vanes for damage.
By the way this machine I believe has a 5 year warrenty,
Jun 22, 2015 | Shark Navigator Deluxe Vacuum - Model NV42
Henry hoover airo brush not working
yes, it probably is stretched.
Jan 07, 2014 | Vacuums
In Carpet mode brushes are not spinning.
Have you checked to see if it has a belt that drives the brush roller? If it has one it could have come off or broken. Also could be the control switch.
Feb 19, 2010 | Hoover U8135-900 / U8153-900 Savvy Turbo...
Suction/Brush not working
Hi there SmartAlec from NelsonVacuums.com.au here.
There are a couple of common reasons that your electrolux vacuum cleaner would appear to have lost it's suction. The first and most common is that it has actually broken a belt. If the belt is broken the brushes won't spin and it will not pick up dirt. It is easy to test simply turn the vacuum on, release the handle (as if you were about to vacuum carpet) and lift up the head and see if the brushes are spinning. If not i can supply you with a new belt.
If the brushes are spinning then your next most likely cause is that there is a blockage in the vacuum somewhere. Test this by turning machine on and checking the suction at the hose (as if your were going to vacuum the couch) if it is poor then remove hose and fish out blockage. If it is ok you may have a blockage between hose and the brush of the vacuum.
If it is neither of these problems i can trouble shoot over the phone if you live in Australia 0269215200 or by email nelsonvacuums@netspace.net.au
Happy Vacuuming.. :)
Aug 25, 2009 | Electrolux EL5010A Bagged Upright Vacuum
Very loud click/catching noise - Dyson DC07Allergy
Take the sole plate off the brush bar (with a coin or a screw driver)compartment and check for blockages near the brush bar and make sure the brush bar spins round freely.
Its sounds like the clutch is slipping (it does this to protect it self from burning out when something is stopping the brush bar from turning)
A quick test is when in upright position turn the brush bar knob to off
(usally in drive postion) then try the user position again - the brush bar should not be turning and they should be no noise
Aug 23, 2009 | Dyson DC07 Allergy Blue/Turquoise Bagless...
Roomba Stops
I just fixed mine by cleaning the shaft that the spinning brushes is on. I used an eyeglass screw driver to tke out the screw. it is running great now. I didn't realize my brushes werent spinning at the time of my post. Cleaning this part seemed to have fixed the problem.
Jun 03, 2008 | iRobot Roomba 4210 Bagless Robotic Vacuum
Kenmore progressive Direct Drive Vacuum w/Hepa
Check the hose and dirt inlet for a blockage. Also the brush roll, check it to see if you can turn it or not by hand. If not, then something may have jammed it.
May 03, 2008 | Kenmore 31913 Progressive Direct Drive...
Dyson DC07 Original won't pick up at base
Lie machine on its side pull back handle as if vacuuming & switch on (KEEP YOUR FINGERS & ANY LOOSE CLOTHING CLEAR OF BRUSH ROLLER)
Brush should spin if it doesnt ensure clutch control knob on side of machine is in drive position if it isnt rotate knob by hand to drive brush should now spin.
If it doesnt & your machine has A clutch either clutch will need replacing or belts will need replacing.
Manuals are available to replace belts & remove the clutch from this site http://dysonmanuals.llc.nu/index.htm
Apr 28, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Help
as the hose fits into the base (if i am correct) the power at the base should be fine, make sure the base is clean and free from blockage, you say the brush doesn't spin, has the belt broken, if so replace it, (very cheap) and only a couple of screws to undo, the roller not rotating will effect the power of suction dramatically, start from there and see how you go if i have helped please rate me
Sep 15, 2007 | Hoover U8171-900 / U8172-900 / U8173-900 /...
Hoover U8125-900 Savvy Bagged Upright Vacuum Logo
128 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
