Question about Westinghouse Refrigerators
Year of manufacture fir Westinghouse silhouette 442 series 2 fridge RJ145951 please
5 Suggested Answers
SOURCE: I need to replace light globe in westinghouse
I rang Westinghouse and they gave me the type of globe I needed.
Many Thanks
Posted on Aug 05, 2009
BMT60
  • 126 Answers
SOURCE: Westinghouse Silhouette Frige 522 frost free is
UNPLUGGED FOR 24 HOURS AND LET IT TOTALLY DEFROST.
Posted on Apr 24, 2010
tunde007
  • 2382 Answers
SOURCE: Westinghouse Silhouette Frost Free 442
Hi, this is a common problem that often doesn't have a clear, permanent solution. The first thing to check is the overall internal refrigerator temperature. The proper temperature should be between 35 and 42 degrees. Here are some things to try:
If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly. If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, i usually recommend you contact a qualified appliance repair technician.
Posted on Mar 03, 2011
  • 1891 Answers
SOURCE: Have a westinghouse silhouette frost
its easy to remove the ice ( just add heat ) / but you do need to correct the problem . this sounds like a defrost cycle failure .. ck the defrost heater and the defrost terminator . and the heater itself .. the model # is not complete try to find the one on the unit itself . in order to get better info .. hope this helps mmm. feed back pls.. 7/10 //11
Posted on Jul 10, 2011
I have a Westinghouse Top Level Silhouette 411 Model RB411G-R-9. I need the Manual for this Refrigerator please.
Go to manualslib.com... Westinghouse... or SEARS
has a pretty good library... ALL FOR FREE
searspartsdirect.com
http://searspartsdirect.com/
Jul 09, 2016 | Westinghouse Refrigerators
Year of manufacture? Westinghouse fridge
Contact Westinghouse customer service with your serial number.
Nov 22, 2014 | Westinghouse Refrigerators
Westinghouse 633 litle, 2 door
The latest 2 door Westinghouse 610 litre without ice maker is a 2.5 star rating with energy consumption (kwh/year) quoted as 605. We had an older 633 litre Westinghouse about 20 years ago which was less efficient and I would assume about 2 star rating. With older fridges the door seal and thermostat are more important as they will waste electricity if not working well.
Mar 12, 2014 | Westinghouse Refrigerators
Have a westinghouse silhouette frost free 442 fridge freezer. It is full of ice behind the back panel. How can I remove the panel? Is there a simple way to defrost the ice? It is approximately 5 cm...
Jul 10, 2011 | Westinghouse Refrigerators
I have a Westinghouse wall oven and grill in the Silhouette series (approx. 18 years old). Where would I be able to purchase a replacement oven light glass cover?
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Dec 29, 2010 | Microwave Ovens
Apr 24, 2010 | Refrigerators
Refrigerators Logo
98 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
