Question about Dryers
My Roper Dryer REX4625EWO doesn't get hot. - Dryers
  • 13 Answers
SOURCE: Roper Dryer REX4625EWO
You will have to remove the cabinet and fix the switch. Go to www.repairparts.com and enter you model number. They will have a diagram on how to remove the cabinet.
Posted on Dec 09, 2007
  • 3074 Answers
SOURCE: hi i've got a hotpoint condenser dryer it's
the belt may be off/broken, motor bad, or idler assemblage.
Here is a website with the routing of the belt the Hotpoint is( General Electric (GE) - Large Capacity Models 1970-1990):
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
how to replace the belt:
http://www.ehow.com/how_6100255_replace-hotpoint-dryer-belt.html
Posted on May 08, 2011
  • 414 Answers
SOURCE: Dryer runs but doesn't heat
If I remember correctly, this model has a switch on the motor which activates both legs
of the 220 to allow the heating element to come on. There is a wiring diagram under the
lid of the dryer and should show this. Hope this helps.
Posted on Jun 21, 2011
BElectric
  • 1140 Answers
SOURCE: roper dryer heats
Michael: Offsite Experts' Lounge
(Run by experts for experts)
Posted on Dec 13, 2011
hunter19_46m
  • 7482 Answers
SOURCE: roper dryer doesn't stop
Hi frank_kleins...
Sounds like your timer is faulty...replace, they are not rebuildable.
When you go to replace the timer, be sure to buy the same kind, and remove one wire at a time and replace one wire at a time that way you will not get confused with the replacement
Please rate me
Bud
Posted on Sep 29, 2012
Dryer doesn't shut off and doesn't get hot
Look at this video to help you fix the no heat issue.
Nov 14, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
Roper dryer doesn't stop
Hi frank_kleins...
Please rate me
Bud
Sep 28, 2012 | Roper RES7648E Dryer
Dryer model Roper RED4340SQ1 rmy heater don't stay hot all the time during a drying cycle is it normal or i need to change it
You may want to do a thorough tuneup on your dryer. I worked on a couple and wrote a pictorial on it. ROPER DRYER TUNE-UP
My Home movie of a Roper dryer with a heat problem:
Sep 06, 2012 | Roper Dryers
MY Roper Dryer model # RED4340SQ1,Will Tumble but not Dry Clothes
For this job, all your work is going to be behind the machine. Tools you'll need is: 1/4 nut driver or drill with 1/4 adapter and a multimeter with ability to check continuity. With the machine unplugged, remove the back cover of the dryer. Once done, the heating element will be located on the right hand side with two fuses on the housing of the element. Test the element and each fuse seperatly by removing the wires and checking for continuity on each component. All parts should show continuity, so if one doesn't its bad and needs to be replaced
Apr 25, 2012 | Roper REX4634KQ Electric Dryer
I have Roper Dryer model RED4340SQ1,SER -MU1914782,it will tumble but no heat
For this job, all your work is going to be behind the machine. Tools you'll need is: 1/4 nut driver or drill with 1/4 adapter and a multimeter with ability to check continuity. With the machine unplugged, remove the back cover of the dryer. Once done, the heating element will be located on the right hand side with two fuses on the housing of the element. Test the element and each fuse seperatly by removing the wires and checking for continuity on each component. All parts should show continuity, so if one doesn't its bad and needs to be replaced.
Does Not Shut Off
1st go the the house breaker (dbl breaker) for the dryer and shut it off and turn it back on, your dryer runs on 220 volts of power but if the breaker is partially tripped it may be only running on 110 volts which is only enough power to turn the lights on and to turn the drum the element needs 220 volts to turn on. If it still doesn't heat after resetting the breaker then you may need a heating element or thermostat. The dryer isn't shutting off because it isn't detecting the clothes are getting dry so once you fix your heating problem the dryer should start shutting off on its own again.
Apr 21, 2012 | Roper Dryers
High pitch squeak
This is typical when the drive belt becomes worn and slips more than it grabs. This causes the squeaking noise you are describing. Below is a short but helpful video which shows the location andl how to replace the belt on a Roper dryer. Best of luck!
Greg
Jan 05, 2012 | Roper Dryers
My roper gas dryer seems to be getting heat (not very hot) but isn't drying clothes. the selector nob only turns under timed dry.
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Jul 23, 2011 | Roper RGX4634KQ Gas Dryer
Dryer runs but doesn't heat I have a Roper RES7646KQ2, l have replaced the following parts: 1-Thermostat 2-Thermal cut off kit which replaces (hi limit and Thermostat 3-Heating Element Still...
Jun 21, 2011 | Dryers
Dec 08, 2007 | Dryers
Dryers Logo
21 people viewed this question
Top Dryers Experts
