Question about Water Heaters
Rheem powervent2 water heater not starting
No hot water, found the vent outside was blocked with snow (LED was flashing 4 times and manual said this could be a problem with the vent). Cleared away blockage and now blower is venting but water heater won't work. I unplugged the water heater and plugged back in. Blower cycles on and off for 10 seconds and the LED indicator is flashing "fast" (manual says this is normal and it is calling for heat). After about 1 minute the LED goes back to flashing 4 times (manual says this could be a blocked vent but I know we have fixed this).
Is there something else we have to do to reset the controls or the gas or something? We didn't adjust or turn off anything else other than what I've said above. We did not toucht he gas supply.
  • davidjacq515 Jan 24, 2009
    Thanks for the suggestion...but I did not see anything like a flag switch (no electrical device that is inserted into the vent pipe). The blower has two small hoses on the outlet pipe spaced apart by about 3-4 inches. I believe these measure the differential static pressure in the vent pipe across an internal orifice and if there is a blockage they would read the same pressure and tell the system that there is a blockage. Now that there is definitely airflow when the blower is running I don't see why it isn't reading a proper differential pressure.
Hi - I have a backyard inground pool heater that runs on gas. It had a problem the last few days with its control module - ran constant - heated the pool to 95 degs!! In doing so, must have hogged enough gas that my hot water heater indoors could not get enough to run constant - it went off. I got the yard unit shut down, but could not get the HW heater indoors to fire. Same symptoms as above - 4 flashes.
I thought about the suggestion - and went to my unit, and inspected the short clear hose on top of the unit that goes from one side of the blower to the other - looks like it goes from and to some sort of presure sensing diaphrams, or something.
I shut off the power via the switch on top, on the blower - the red led light went out on the gas unit. I shut the gas valve on the gas unit off as well.
The hose is only 6 " long - I saw a big ball of moisture just outside of the upper diaphram nozzel that goes into the hose - pulled off the friction fit on the lower end, and tapped the moisture into a very lot of small bits.
Plugged the line back on, turned on the power, turned back on the gas valve and after 10 seconds - it lit up!
Will keep an eye on it, and take it apart farther if moisture continues to be a problem. Has been very humid the last week - that might have agravated it. Thanks for the thought stimulus - saved me $250 no doubt!
Posted on Aug 07, 2012
  • 2,692 Answers
I am guessing that their is a flag control(switch) in the airstream of the vent and it is now stuck in the closed position due to the snow, maybe. Find the flag switch and make sure it can move freely. It must move freely for the venter fan airstream to operate or move it.
Posted on Jan 24, 2009
My Rheem powervent2 water heater squeals while running
The power vent motor squeals when burner is activated?
See if you can oil the power vent motor.
If the water heater squeals when water is turned on, then remove heat trap nipples and inserts and install di-electric nipples from water heater department local home store.
Copy following link illustrations.
Additional link:
Troubleshoot by type of gas control valve:
Oct 08, 2012 | Rheem Water Heaters
Rheem Water Heater and the LED light is flashing 4 times which according to the manual states the the "Vacuum Safety Switch is open and fails to close to sequence, how can i fix this
Rheem does not post service manuals:
Here are resources that can help solve problem:
1) Troubleshoot by type of gas control valve using other water heater manufacturer's service manuals: Service manuals are very large pdf files.
2) Scroll up on same page and on right side is heading 'Pressure Switch' with 2 related pdf files.
3) Post question on pro water heater forum
Oct 06, 2012 | Rheem Tankless Hot Water Heater...
No hot water. Constant beeping at the tank. Tempature gauge flashing 11.
Before calling service technician, open following links for Rheem troubleshoot resources including Rheem chat and typical service manual and typical product manual.
Error codes are start place for troubleshooting:
Error 11 is 'gas is inadequate' or 'ignition failure'
Open gas valve so handle is parallel with gas line.
Bleed air from gas lines.
Check that appliance is grounded.
Check igniter wires and harness for damage.
Check that vertical vent length does not exceed limit.
Other causes: Gas inlet solenoid valve, bad igniter, solenoid valve, flame rod.
Jun 14, 2011 | Rheem Tankless Hot Water Heater...
Rheem Power Vent 2 water heater is flashing 4 times and there is no hot water. Model # 41VRP50NT What can I do to fix this? Do I need to call a plumber?
The flashing light is a trouble sequence light. Find your manual to see what 4 flashes means. It's usually attached to the side of the water heater tank. Try a quick fix by unplugging the power vent and see what happens.
May 15, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Rheem power vent motor doesn't shut off
There could be blockage in your water heaters venting on the outside of the home. It sound like the high limit switch has been tripped. Try unplugging the tank and plugging it back in. this will reset the tank. if the problem persists you will want to call your provider for service.
Oct 07, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Power vent 50 gal tank flashing code 2-3
1. Turn off power vent blower and set water heater temp to vacation (lowest temp)
2. Turn on power vent blower
3. Turn the water heater temp from vacation (lowest temp) to hot (highest temp) four times.
4. Set the water heater temp to normal
Aug 21, 2009 | Rheem Water Heaters
Rheem/GE power vent water heater, pilot lites, but not the main
I would check to see if the switch on the blower pressure sensor is closing...When T-stat calls for flame, the circuit starts the blower, then the blower pressure sensor switch closes to allow the main gas valve to be powered.
Jul 08, 2009 | Water Heaters
Water Heaters Logo
313 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
