Question about Sony DAV-DZ175 DVD Home Theater System
SUROUND SPEAKERS NOT WORKING - Sony DAV-DZ175 DVD Home Theater System
My suround sound works w/dvds how do i get tv volume to work in suround?
Hi Charles,
To hear audio from your surround sound (stereo receiver) the audio signal needs to be managed by the receiver. You likely have your DVD machine connected (going into) your receiver, then your receiver going into your TV --- your receiver is splitting the audio to the speaker, then the video to your tv. To get your TV signal split, you need to have your cable signal going into your receiver as opposed to into your TV directly.
Feb 07, 2015 | Audio Players & Recorders
Ma5806 5.1 suround not working
sounds like a problem in the amplifier. what brand is that?
Jul 08, 2013 | Audio Players & Recorders
Hi, I am using the AVR1612 with an MP3 player. The center speaker and the suround speakers do not work. When I test the speakers they are all working fine. The cables are plugged correctly
Your mp3 player only supports 2-channel stereo. To get sound from more speakers, you need to select a sound program, try selecting one of the sound field options on the bottom right of your remote (music cinema, direct, ... ).
Jul 24, 2011 | Audio Players & Recorders
Can't get surround sound while playing the PS3. The surround works while watching cable
your suround sound system has been wired up so only cable plays throgh speakers
does your tv have a audio out RCA jack?
if so then connect the home theater to that
i cant help anymore because i dont know the suround sound model number ot what tv
Jan 11, 2010 | Audio Players & Recorders
I don't now what settings to use on my technics stereo system it has 5.1 surround sound. My prob is I don't now what levals to set the speakers at for best results in the book it says I should hear bullets...
switch off pro logic/switch on supper suround/press button twice it will say MOVE:/
switch on Supper suround EQ then Vertual Rear suround then Multi Rear suround then Seat Position.they should be lit GREEN exsept Vertual Rear & center focus.
Seat Position should flash when it does move the curser in the middle of the jog dial.......... i.e UP:DOWN :LEFT :RIGHT .let go & it will set itself. then switch on the Supper s woofer on the amp to MID.
I THINK L.O.L
Jun 10, 2009 | Technics SC-DV290 System
Only 2 speakers working
on your computer if you go to
  • start
  • control panel
  • sound and audio devices
  • click on change the speaker settings
  • click advance in speaker settings
  • and change it to 5.1 suround sound
Apr 11, 2009 | Audio Players & Recorders
Suround speakers and center speaker is not working
Well you can change the setting to hear from different speakers. Play with it you will hear the front on one setting then all 5 on another
Nov 29, 2007 | Panasonic SC-HT680 System
Sony DAV-DZ175 DVD Home Theater System Logo
22 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
