Question about Texas Instruments TI-89 Calculator
TI89 Titanium troubleshooting
The Xres set in the Windows Editor is always greyed out, like other areas that don't pertain to an operation get greyed out....but I can never change the resolution in the Windows Editor. What happened? Thanks
  • David Wright Jul 12, 2007
    TI support fixed the problem. I had inadvertantly changed the Discontinuity Detection from Off to ON. Access this through Tools in the Window Editor, scroll to Format (#9 item), then scroll down to Discontinuity Detection and select "Off". Now you have the Xres choice back on the menu of the Window Editor.
  • 360 Answers
It has to be that your have gone beyond mathmatical bounds or the physical bounds of the calculator itself or screen.
Posted on Aug 27, 2009
How do i change notification settings
A simple registry edit will stop the bubbles, for all applications. You can watch the screen cast to see two ways to make the change. You can either make the editmanually using regedit, a registry editor that comes with Windows. Oryou can download a file from Murphy and double-click it. The file will make the change.
You don’t have much to worry about. In fact, you can right-click thefile (after unzipping it), select Edit, and you’ll see it’s just acouple lines of text. The change is easily undone. Simply delete theentry from your registry.
The balloons will stop appearing for all applications - only for theuser you’re logged in as when you make the change. Log out and back into test your results.
If you’re comfortable in the registry go ahead and make this entry:
Add a DWORD value in the following key, and name it EnableBalloonTips. Set its hex value to zero.
HKEY_CURRENT_USERSoftwareMicrosoftWindows
CurrentVersionExplorerAdvanced
Not a registry person? Watch the screencast.
I don’t even know if they have bubbles in Vista…
Jan 28, 2010 | Microsoft Windows XP Professional
Tip
How to disable Notification Area Balloon Tips in Windows Vista: Click...
  • Click Start, Run and type Regedit.exe
  • Navigate to the following subkey:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced
  • Create a new REG_DWORD (32 bit) value, and then name it EnableBalloonTips
  • Double-click EnableBalloonTips, and then give it a value of 0
  • Close Regedit.exe
  • Log off Windows, and then log back on.
This method applies to Windows XP as well
Using Group Policy Editor Settings:
  • Click Start and type GPEDIT.MSC
  • Accept the User Account Control prompt
  • Navigate to the following branch:
User Configuration \ Administrative Templates \ Start Menu and Taskbar
  • Double-click Turn off all balloon notifications and set it to Enabled
  • Close Group Policy Editor
Here is the corresponding registry value for the above setting:
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer]
"TaskbarNoNotification"=dword:00000001
on May 25, 2008 | Microsoft Windows Vista Home Premium with...
My pc is slow work
it it is xp the follow the following steps
When you start to shut down Windows XP, it has to quit, or "kill," any live
applications or processes that are currently running. So close all applications first.
However, some applications and processes are always running in the background.
You can reduce the amount of time that Windows XP waits for those applications and
processes to close before Windows XP kills them.
1. Open registry editor
2. Navigate to HKEY_USERS\.DEFAULT\Control Panel\Desktop. Set the
WaitToKillAppTimeout and set the value to 1000. Select the HungAppTimeout
\newline value and set it to 1000 as well.
3. Navigate to HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control.
Select the WaitToKillServiceTimeout value and set it to 10000.
4. Close the Registry Editor.
Memory Tweak
1. Start Registry Editor (Regedit.exe) and locate the following key in the registry:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SessionManager\
MemoryManagement\PrefetchParameters
2.On the EnablePrefetcher value, change the setting from 3 to 5 (decimal).
3. Close the registry editor and restart your computer
Feb 20, 2009 | Computers & Internet
Windows folder cannot be hidden
Hi its a virus.
Heres the fix for it.
Go to registry editor by running regedit in the run box.
Go to this key:
In the right hand area, double click hidden and change the value to 1.
Now you’re all set to go. Check it in your tools menu if the changes have taken effect.
alternatively use this tool
Smart Virus Remover
Nov 04, 2008 | Microsoft Windows XP Home Edition
Slow booting & low performance
It may be a disk related problem.Repartition may be useful on your hard drive.
Regards
ucp_pru
Jul 23, 2008 | Microsoft Windows 2000 Professional for PC
Can't input values for xres in graph window.
Go to the graph app (diamond + f3)
to the graph apps settings (f1 , then 9: Format)
turn off discontinuity detection
go to the window setupt (diamond + f2)
change xres to 2.0
Jul 16, 2008 | Texas Instruments TI-89 Calculator
Desktop properties (desktop and screensaver tab is missing)
The following is solved me
Well if anyone is interested and for general knowledge these are the 3entries that were killing the Desktop and Screen Saver tabs in XP. Hupigon13 seems to be at the root of it all.
Quote: Microsoft.Windows.System: Settings (Registry change, fixed)
HKEY_USERSS-1-5-21-1343024091-1060284298-1011862931-1004SoftwareMicrosoftWindowsCurrentVersionPoliciesSystemNoDispBackgroundPage!=W=0
Microsoft.Windows.System: User settings (Registry change, fixed)
HKEY_USERSS-1-5-21-1343024091-1060284298-1011862931-1004SoftwareMicrosoftWindowsCurrentVersionPoliciesSystemNoDispScrSavPage!=W=0
Hupigon13: Settings (Registry value, fixed)
HKEY_LOCAL_MACHINESYSTEMControlSet001ServicessrImagePath=...SystemRoot...
Read full story here
http://forum.osnn.net/showthread.php?s=f44e1bb094fbae9305c9f0c9999c52e7&p=841430#post841430
Jul 16, 2008 | A4tech PK5
How to use the registry editor
ok if ur so influenced in changing registry then u can change or else it would be too risky too enter into registry editor . To enter or to change registry editor just type the command regedit in ur run command thats it
Apr 13, 2008 | Microsoft Windows XP Professional With...
Texas Instruments TI-89 Calculator Logo
185 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
