Question about Makita 10" Compound Miter Saw LS1040
I can not remove armature caseing from makita miter saw
I have removed armature but can not remove caseing
    Top Expert:
  • Makita Master
  • 45,659 Answers
The casing at the saw end will have an inside case that is bolted either from behind the gears or from the armature side by screws. This has to be undone to allow the bearing to separate from the case
Posted on Aug 04, 2013
4 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: Makita 10" Compound Miter Saw LS1040 manual?
Here you go.
This is the ls1040
http://www.makita.com/en-us/Assets/images/Products/LS1040/owners_manuals/LS1040.pdf
This is the ls1040f
http://www.makita.com/en-us/Assets/images/Products/LS1040F/owners_manuals/LS1040.pdf
Posted on Mar 12, 2009
  • 583 Answers
SOURCE: My two year old Makita LS1221 Miter saw will not
PUT THE CENTRE BOLT BACK IN PLACE SCREW IT RIGHT IN THEN UNDO IT 3 FULL TURNS THEN GIVE IT A GOOD CLOUT WITH A DRIFT AND HAMMER IT WILL COME WHEN IT DOES YOU WILL NEED TO GIVE IT AGOOD CLEAN UP AND REASEMBLE IT AND YOU SHOULD BE RIGHT
Posted on Sep 26, 2009
  • 6 Answers
SOURCE: How to replace main bearing in a Makita GA5000 5'' angle grinder
with the head off and the brushes out you just need to turn the metal plate so you can tap the plastic body down on a hard surface. the armature should just fall out with a few taps. to get the gear off you need to use a puller on the gear. once the gear is off you can remove the woodruff key and use a puller on the bearing. to get the new bearing on, push it on by tapping it on at the centre of the bearing, a 5/16 deep socket should work to get the bearing on.
Posted on Feb 12, 2010
Saw stopped working. changed brushes. still not working.just dead.blade turns ok.not even a click
These are notorious for burning out armatures.
The replacement process is pretty involved, I would not attempt unless you are comfortable.
Remove the brushes
Remove the 3 Screws hold the motor assy to the saw
Remove the screws holding the motor housing together.
Separate the housing and you should be able to see right away if the armature is burnt (many times the windings actually blow apart)
Often when the armature burns out it also melts the brush holder assy - I would recommend replacing it as well.
If the armature appears fine then I would lean toward the switch. Makita BSS611 18V LXT Lithium Ion 6 1 2 Circular Saw Parts
Mar 12, 2015 | Makita Bss611 18v Lithion 612" Circular...
Armature replacement
If there are brushes, they are hanging up on the armature. Take out the brushes. They are usually held in by black covers with screwdriver slots in them.
Nov 29, 2013 | Dewalt DW703 10" Compound Miter Saw
Saw growling
the problem is poling and that means the armature is touching the field shoes and is shorting out. If you have replace d the field coils then may be the shoes have not been fitted in tightly enough and the clearance is not as it should be. Worn bushes or bearings will give the same effect as when the current is on the armature is pulled to the shoe.. Ensure that the end caps are fitted correctly to ensure alignment and tighten the screws evenly around the case.
Jun 19, 2013 | Makita 10" Compound Miter Saw LS1040
Motor growls when switched on.
The armature is hitting on the field shoes from misalignment of the end caps and or bearings.. When the power is applied the armature instead of spinning is attracted to the metal shoes of the fields and is touching and shorting out.
Dave,
The only thing i could offer would be try and look at one like that or a Bosch that ia all ready set up. of course there;s always the option of calling the company. I love those saws my 12 inchRigid takes up too much space.
Good Luck.
Jan 16, 2013 | Makita 10" Dual Bevel Sliding Compound...
Makita LS1221, started heavy sparking from both brushes with greatly reduced speed. Brushes are ok. I'm assuming it is a shorted winding on either the armature or stator, how do I determine which...
you need to make sure the brushes move freely in the tubes and if they do I would suspect the armature is bad. LOOK for discoloration in the commutator thru the brush tubes.
Aug 03, 2011 | Makita 10" Miter Saw LS1030N
How do I replace the blade guard on my 10" Makita
If you want to replace the plastic cover there is a screw towards the front of the saw that must be removed and then the bolt at the back loosened and the guard will pull off. If you need more info get back to me with the other questions and I will try and help
Jul 10, 2011 | Makita 10" Miter Saw LS1030N
How do I get the base off I've taken the fence off and the screw in the center out.
Hi
Not sure if you want to remove the center base. If yes with the center bolt removed it should go.
If this can help view the parts diagram.
http://www.ereplacementparts.com/makita-ls1030n-miter-saw-parts-c-97_98_99_321.html
Feb 07, 2011 | Makita 10" Miter Saw LS1030N
Electric brake Fault. Blade Runs On.
some of my ls1040 repairs i replaced the switch and it seemed to correct the problem...
sometimes replacing the armature worked ...but like you did i always started with replacing the brushes
how does the condition of the armatures commutator look?
Jun 05, 2009 | Makita 10" Compound Miter Saw LS1040
Makita 10" Compound Miter Saw LS1040 Logo
186 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
