Question about Microsoft Windows XP Home Edition
I've lost my ''Recently used program list'' from the Start menu in Windows XP (Home Edition). How do I get this list option back?
  • 1 more comment
  • JEFF DAVIS Jan 24, 2009
    I do not have an Advanced option under Customize for my Start Menu. Anything else you can think of?
    Also, my only option is for the "Classic Start Menu"
    I'm running XP Home Edition with SP3.
  • 871 Answers
Hey jeff
Go to Control Panel >TaskBar and StartMenu properties > StartMenu > Customize > Advanced > Re-check the box for "list my most recently opened documents".
hope this is what your looking for.
Posted on Jan 24, 2009
  • 1 more comment
  • earl norman llanera
    earl norman llanera Jan 24, 2009
    pls look at this
    if you dont have this feature, then your using a modded type of OS.
    classic start menu is your only option?
    what type of OS are you using? right click on My Computer the select Properties so that youll see what type of WinXp youre using. Windows Xp Home and professional have these 2 selections of the start menu, Classic and XpBasic.
Blue creen with blinking cursor
you can do a clean install from your usb. i use this setup for all my flash drive boots.
WinSetupFromUSB - Install Windows XP from USB Flash Drive
This guide will show you, how to use WinSetupFromUSB to create a bootable USB Flash Drive including all Windows source files, plus the following installation of Windows XP. Compare to the different USB_Multiboot versions, WinSetupFromUSB comes with a Graphical User Interface (GUI) and is in my opinion easier to use.
Here you can get the latest version of the program and you will also find many detailed informations about WinSetupFromUSB.
I've tested this guide with a 32-bit version of Windows XP and a 64-bit version of Windows Vista and it worked flawlessly.
Prerequisites:
All you need is:
a USB Flash Drive with at least 1GB of storage
the original Windows XP Setup CD
WinSetupFromUSB
If you use nLite to slim down your version of Windows XP, please keep the following in mind:
DO NOT remove "Manual Install and Upgrade"
under Operating System Options!
I also recommend to integrate Service Pack 3 into your Windows XP source files.
1. Preparations
Download and install WinSetupFromUSB. Default installation path is C:\WinSetupFromUSB.
Create a new folder with the name WINXPCD in the root directory of drive C:\ and copy all files from your Windows XP Setup CD into this folder. Depending on your version of Windows XP, the content of C:\WINXPCD should look approximately like this:
Content of WINXPCD
The following files will show you, which Service Pack is already integrated into your CD:
WIN51IC.SP1, Sevice Pack 1
WIN51IC.SP2, Sevice Pack 2
WIN51IC.SP3, Sevice Pack 3
2. Start WinSetupFromUSB
Connect the USB Flash Drive to your PC and start WinSetupFromUSB. It should show up under USB Disk Selection :
WinSetupFromUSB - main window
3. Select your Source Path
Click on Browse under Windows 2000/XP/2003 Source and navigate to the folder with your Windows XP Source Files. It should be C:\WINXPCD:
Browse to Folder
Click OK and C:\WINXPCD should show up under Windows 2000/XP/2003 Source :
WinSetupFromUSB - source path
4. Format USB Flash Drive
PeToUSB or HP Format Tool are used to format the USB Flash Drive. There is no need to download these programs seperately as they are already included in WinSetupFromUSB.
USB Flash Drives up to 2GB should be formatted with PeToUSB in FAT16, USB Flash Drives with 4GB or more with HP Format Tool in FAT32.
I will use PeToUSB to format my Kingston Data Traveler with 2GB.
In the main window of WinSetupFromUSB click PeToUSB under Format target using to start the program. The USB Flash Drive should show up under Destination Drive. Check USB Removable, Enable Disk Format and Quick Format. Uncheck Enable File Copy under File Copy Options :
PeToUSB
Click Start and answer the following two questions "Continue?" with Yes.
All existing volumes and data will be lost!
If everything goes well, the message "Operation Completed Successfully!" should appear. Click OK and close PeToUSB.
The process with HP Format Tool is similar.
5. Copy Windows XP Source Files
To start the process of copying the Windows XP source files to the USB Flash Drive, click GO in the main window of WinSetupFromUSB. Depending on the write speed of your USB Flash drive it may take a while to copy all files.
WinSetupFromUSB - file copy
At the end the following notice about the Windows installation process should be displayed:
WinSetupFromUSB - notice
Click OK and close WinSetupFromUSB with EXIT.
6. Windows Installation - Part 1
Connect the USB Flash Drive to your PC and turn on the computer. Press ESC at the boot screen and you will be able to select the USB Flash Drive as your boot device from the boot menu.
The ESC key is used by ASUS for the Eee PC series.
Other manufacturers may use other keys, e.g. F8 or F12.
After booting from USB Flash Drive, the following menu should be displayed:
Windows XP/2000/2003 Setup - First and Second parts
Press Enter or wait 10 seconds to get to the next menu:
First part of Windows XP Home Edition setup
Second part of XP Home Edition setup+Start Windows for first time
First part of Windows XP Home Edition setup is already selected. Press Enter or wait 10 seconds to start the Text mode part of setup. During this part you can create, delete and format partitions and finally the setup files are copied to your hard disk. At the end the system will restart automatically.
7. Windows Installation - Part 2
After restart, boot the PC again from your USB Flash Drive. The same menu should be displayed:
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to start the GUI mode part of setup. During this part you will be asked for your product key, timezone, usernames and other necessary informations. At the end the system will restart automatically.
8. Windows Installation - Part 3
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to Start Windows for the first time. The Windows installation process will be finished and finally the Windows Desktop will appear.
DO NOT disconnect the USB Flash Drive too early!
At next startup you can boot into Windows from your hard disk.
Notes:
After successsful installation, the following boot menu will always be displayed during startup:
Please select the operating system to start:
USB Repair NOT to Start Microsoft Windows XP Home Edition
If you don't plan to use the repair option and want to boot directly into windows, you have to do the following:
Open the file boot.ini in the root directory of drive C:\ with Notepad:
[Boot Loader]timeout=30
Default=multi(0)disk(0)rdisk(0)partition(1)WINDOWS
[Operating Systems]
multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(1)partition(1)WINDOWS="USB Repair NOT to Start Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
Delete the following line:
DO NOT delete the wrong line!
Your computer may not boot the next time!
Save changes to the file.
At next startup the boot menu will not be displayed.
If you want to keep the repair option, you can reduce the time to display the operating system options from 30 to 5 seconds:
[Boot Loader]
timeout=5
At next startup the boot menu will be displayed only 5 seconds.
gd luck
Mar 09, 2014 | Computers & Internet
Lost original cd
I'm afraid it's not available as freeware but it can be bought used for 25 cents + 3.99 postage from http://www.amazon.com/gp/offer-listing/B0001IQNBG/ref=dp_olp_used?ie=UTF8&condition=used
It's not intended for use on windows 7 probably because it was released before windows 7 was created. However it is compatible with windows XP and programs on windows 7 can be run in a windows XP environment if there's a problem running it on windows 7.
Install the program as normal. If it fails to start or there is a problem with it, right click on it's icon and select "Properties" from the menu. Click on the "Compatibility" tab. Tick the box "Run this program in compatibility mode for:" by clicking on it. Click the drop down arrow beside it and select the version of windows in which you were running it before or select "Windows XP Service Pack 3" It should run then.
I hope this helps you.
Apr 21, 2012 | Broderbund 3D Home Architect Home Design...
How do i uninstall cnet tech tracker, im using windows xp home edition
Click on your start menu, then open "Control Panel." From the control panel, click "Add or Remove programs." This will display a list of all the programs on your computer, which you can use the uninstall whatever you like.
Hope this helps.
Aug 18, 2011 | Computers & Internet
Need to close internet browsers to uninstall toolbar in control panel HOW?
Disable toolbar,
The normal procedure to disable a toolbar is:
1. Click the browser view menu.
2. Select toolbars.
3. Uncheck the toolbar name.
This will hide it from view, however some adware programs remain active and keeps monitering your internet activity even though their toolbar is disabled.
Uninstall toolbars,
Use windows add remove programs utility.
1. Click the start menu.
2. Click control panel.
3. Double click the add remove programs option.
4. Locate the name of the toolbar in the list and follow the prompts to remove it completely.
Regards,
Yateesh Varma
India, Bangalore.
Aug 09, 2010 | Microsoft Windows XP Home Edition for PC
Lost SP3 windows xp home edition version 2002 how do i get it back or do i need to I have automatic updates turned on when I look at programs beside it ,there no file size? also how do I fix error...
If you mean no file size showing up in "Add / Remove Programs"
thats because it's integrated / uninstallable but registered.
Error: 0x80070005, is that when you access "Microsoft Update"?
As for repairing SP3 Read more here:
http://windows.microsoft.com/en-us/windows/help/learn-how-to-install-windows-xp-service-pack-3-sp3
and you probably have to go for option:
"Manually installing SP3 using the Microsoft Download Center or a CD"
Good Luck
Jul 18, 2010 | HP Compaq Presario SR1620NX...
How to remove cim.meebo spyware from computer - using Windows XP home edition? Popping up in browser history 10 times per day - a scan/cleaning with my McAfee did nothing to remove it....
try to perform system restore. restore the computer back to the date where you are not encountering this spyware. click start menu - all programs - accessories - system tools - system restore. thanks!
Apr 05, 2010 | Microsoft Windows XP Home Edition
When i turn my computer on, it ask me to pick xp home edition or it will pick the first one on the list. I wan to know why it is doing this
This will occurs when the Computer did not shut down properly or restart automatically or a dual Operating System installed in the Computer.
To resolve this:
1. Click on Start -> Control Panel -> System.
Or, Click on Start, right click on the My Computer option and select the option Properties.
2. In the System Properties option click on Advance tab.
3. In the Advance, click on Setting option under Startup and Recovery option.
4. Under Startup and Recovery option un-check the boxes:
a. Time to display list of Operating Systems.
b. Time to display list of Recovery options when needed.
5. Then, Click OK, then Apply and OK in the System Properties window.
6. Restart the Computer.
This should resolve the issue.
Good Luck!!!!!!!!!!!!!!!
Sep 29, 2009 | Microsoft Windows XP Home Edition
Programs missing from add/remove list
Once you have the "Add or Remove Programs" window open look at the left side and make sure you have "Change or Remove Programs" selected. Also make sure you have the checkbox ticked that says "Show Updates".
As for the other programs in the list without the chage / remove option. You need to first click on the progam in the list to show that option.
Jul 10, 2008 | Microsoft Windows XP Home Edition
Help me..whats going on with windows xp home edition
When installing a new operating system, all file saved will be deleted. Since you've lost all data, you might as well format the entire drive, and then reinstall the vista inspirat thing. Then, download an Avast! anti virus form avast.com. Download the home version, which is free and scan the computer for any viruses. Delete every last one of the suckers.
Jul 03, 2008 | Microsoft Windows XP Home Edition
Paint on windows xp
Put the winxp cd in the drive. goto start settings control panel, add remove programs, left side add/remove windows components,
if accessories is checked then paint,calc etc are installed.
if acc. is checked goto start search/ files and folders/ all files and folders, type in accessories search c: drive select accessories folder location c:\documents and settings\all usersopen folder and link to paint, calc etc will be there.
Apr 10, 2008 | Microsoft Windows XP Home Edition
Microsoft Windows XP Home Edition Logo
59 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
