Question about Canon PIXMA MP160 All-In-One Printer
I installed windows vista and now I can't scan
I get an error that says it is not compatible, and vista says it is a canon problem. Can you help?
  • earl norman llanera
    earl norman llanera Jan 24, 2009
    well just to comment, i also had problems with some printers not being compatible with vista. its a very long process and sometimes we need to wait for the manufacturer to provide new drivers for the printers to become compatible.
    Guru:
  • 1,463 Answers
Here the drivers fopr vista from canon at MP160
riz.
Posted on Feb 05, 2009
I bought the Canon Canoscan N1240u flatbed scanner. I downloaded the drivers and plugged in the cord that came with it but it doesn't do anything.
Just to be sure, did you install the driver in addition to downloading it? Full software or basic driver. The software must be installed before connecting the data cable. What OS are you using? (if you have Vista 64-bit, it is not compatible) If you didn't install the software, uninstall the OS driver and disconnect the data cable before attempting to install the Canon software. Otherwise see the notes for scanning with other software.
First are you trying to use the scanner buttons? These will only work if the full software is installed. For the buttons to work, you have to set up the scanner button destinations in the Canon software first. Also a monitoring program must be running for the button presses to work.
So try scanning from the computer first. If you still get an error, try a new data cable. If you are using a USB hub, try a direct connection. Make sure your USB ports work with a known working device. You can also check if the ports are disabled for security (in the Device Manager for Windows) or power savings (an advanced setting from the Screen Saver).
Once you have scanned successfully from the computer, go to the Settings section of the Toolbox to set the default destinations for the scan buttons.
If you only installed the basic driver, you can scan with Paint (XP or Vista), File > Import from Camera or Scanner > New Scan. Vista also has Windows Fax and Scan (New Scan) and Photo Gallery to acquire scans. I don't know the Mac software. Third-party software will also work if installed.
I hope this helps.
Jan 12, 2011 | Canon CanoScan N1240U Flatbed Scanner
I have a canon MF5550 printer that I am trying to use with Windows Vista. There is no compatible printer that I can find. What is recommended?
Canon isn't supporting this printer for Vista. You can try using the driver for XP. Available here: http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/imageclass_series/imageclass_mf5550?selectedName=DriversAndSoftware#DriversAndSoftware
You may need to use the Compatibility Mode on the installer as well as the driver. (Right click on the .exe and select Properties. Then go to the Compatibility Tab and check the box for the Run this program in Compatibility Mode and choose XP in the adjacent drop down.) Then right click again on the .exe and choose Run as Administrator to make sure the UAC allows the installer to work.
I hope this helps.
(a generic printer driver may install when you plug in the printer without installing the software first. If this happened you should uninstall that driver before trying the Canon version. If the Canon driver doesn't work, the generic printer driver in Vista will probably let you print but you may lose the scanner features. Please note that the buttons may or may not work to launch the software on the computer. Try opening the software and initiating scans from the computer.)
Jul 22, 2010 | Canon imageCLASS MF5550 All-In-One Laser...
No driver for Canoscan FB 630U Vista 64 bit
Unfortunately, it doesn't look like Canon supports this scanner under Vista. Check if the Windows generic TWAIN scanner driver will work. The Canon software won't work. If the generic driver can be installed, then you should be able to acquire scans in Paint (File > Import from Scanner or Camera), Windows Fax and Scan (New Scan) (some versions of Vista) or Windows Photo Gallery (IIRC it works like Paint).
I hope this helps.
(Canon wants you to upgrade. I have a different scanner that isn't officially supported past XP and the generic driver works fine. Unfortunately, you can't just use the XP driver in the compatibility mode due to the lack of signed drivers that are required in the 64-bit OS)
Jun 03, 2010 | Canon CanoScan FB630U Flatbed Scanner
Will not scan... Apparently, the scanner with this canon printer (Prixia MP500) will not work with Windows Vista. What can I do?
Your machine is compatible with Windows Vista. Uninstall whatever drivers you currently have installed, then download and install the drivers from this link. Be sure and also install the MP Navigator (listed under Software), which provides the scanner interface program.
Mar 03, 2010 | Canon Pixma MP500 All-In-One InkJet...
Need drivers
there is no driver yet for windows 7.but download scan gear and scan gear toolbox from here:http://software.canon-europe.com/products/0000473.asp  open properties,compatibility and run it in compatibility mode for xp sp2
Feb 28, 2010 | Canon CanoScan N650U Flatbed Scanner
I bought a canon laser shot lbp2900 printer but whenever I try installing it I get an error message saying that the installer is not compatible. I use windoes vista home premium. please help
It could be possible that the drivers those you have installed for your Printer is not for Windows Vista.
Find the link below to download the drivers for Windows Vista.
http://drivers.softpedia.com/get/PRINTER/CANON/Canon-Laser-Shot-LBP2900-Printer-Driver-R111.shtml
I hope this should resolve the issue once you re-install the drivers, also please be carefully to select the Windows Vista as operating system while installing the drivers.
Feb 24, 2010 | Office Equipment & Supplies
I can not install driver Printer Canon LBP 2900 on Vista 64bist
it could be possible that you are running on a different platform, say Vista, and you are downloading on XP vice versa, ensure you have the correct version of the driver you wish to install, unless you correctly choose the right OS, you will never make this work. sometime it is confusing really...
hope this helps
Jul 10, 2009 | Canon LASER SHOT LBP-2900 Printer
Twain error on cannon scan D646U on VISTA
The D646U is not compatible with Windows Vista. Call Canon and inquire about their Customer Loyalty Program. They let you upgrade to a more current scanner at a reduced price.
800-828-4040
Jul 01, 2008 | Canon CanoScan D646U Flatbed Scanner
Scanning
This is all due to driver compatibility issue,please thry this,first remove all software n drivers for the scanner ,download driver from this site by selecting ur operating system,n install,do remember to reboot ur laptop after removing previous software.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=14003
do revert
thnx N
Jan 26, 2008 | Canon CanoScan LiDE 70 Flatbed Scanner
Canon PIXMA  MP160 All-In-One Printer Logo
old marine
old marine
