How do I remove spent ink cartridge?
The manuel doesn't cover removal of cartridges in order to replace them.
  • 29 Answers
Hi
ensure printer is on,open printer cover,cartridge come to center or load position...snap the old cartridges out of cartridge carrier box,replace cartridges..close printer cover..good luckl
Posted on Jan 24, 2009
HOW DO I CHANGE THE INK CARTRIDGES IN MY CANON PIXMA MP160
Hi
Here's how to replace ink cartridge.
Make sure the printer is turn on. Place your fingers under the LED control panel and lift the scanning unit. The cartridges inside the printer will automatically slide to the left, for easy access. Remove the empty cartridge by pushing the front of the cartridge downward. It will snap out of its cradle. Pull out the cartridge and replace the new ink cartridge. Insert the new cartridge. With the front of the cartridge tilted down, push the back into the cradle. Lift the front upward, and the cartridge will snap into place. Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help. Regards and thank you for using Fixya !
May 21, 2011 | Canon PIXMA MP160 All-In-One Printer
Instructions on how to install the printers ink
Solution: Replace ink cartridge(s) MP210
Replacing An Ink Cartridge Use the following procedure to replace empty ink cartridges or when an ink cartridge error appears.
  1. After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.
    Note: After confirming that the scanning unit support is fixed into position, release your hands.
    *MP470 shown
  2. Press down on the semi-circular tab (circled area in , above) to release the cartridge and then remove it.
    Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
    *Optional cartridges PG-40 and CL-41 shown in examples
  3. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
  4. Take out a new cartridge from its casing and gently remove the orange protective tape in the direction of the arrow.
    Note: - Do not attempt to reattach the protective tape once you have removed it.
    - Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.
  5. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot*
    *One black cartridge and one color cartridge must be installed in the machine in order for the printer to operate. It does not matter if the capacities (Standard or High) do not match.
  6. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)
  7. Confirm that the ink cartridges are installed properly.
    The ink cartridge is not installed properly.
    The ink cartridge is installed properly.
  8. Fold the scanning unit support and close the scanning unit (printer cover).
  9. Wait until the preparatory operation is complete; it takes about one to two minutes.
Mar 31, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
Impossible to insert the cartridge in a printer always shows that it is not a good loaded
  1. After confirming that the printer is powered on, open the scanning unit (printer cover).The ink cartridge holder moves to the replacement position.
    Note: After confirming that the scanning unit support <1> is fixed into position, release your hands.
    *MP470 shown
  2. Take out a new cartridge from its casing and gently remove the orange protective tape in the direction of the arrow.
  3. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot*
  4. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)
  5. Confirm that the ink cartridges are installed properly.
    <1> The ink cartridge is not installed properly.
    <2> The ink cartridge is installed properly.
  6. Fold the scanning unit support and close the scanning unit (printer cover).
  7. Wait until the preparatory operation is complete; it takes about one to two minutes.
Removing Ink Cartridges:
  2. Press down on the semi-circular tab to release the cartridge and then remove it.
  4. Fold the scanning unit support and close the scanning unit (printer cover).
Nov 30, 2010 | Canon PIXMA® MP210 Printer
HOW DO I REPLACE MY INK CARTRIDGE IN MY CANON 2600 PRINTER?
How to install or remove ink cartridges To print normally, install or remove ink cartridges in an orderly procedure.
How to install ink cartridges
1. After confirming that the printer is powered on, open the front cover. The ink cartridge holder moves to the replacement position.
2. Take out an new cartridge from its casing and gently remove the orange protective tape in the direction of an arrow.
Caution: Do not attempt to reattach the protective tape once you have removed it. Do not touch the gold electrical contacts or the print head after removing the protective tape.
3. Insert the color cartridge into the right slot and then the black cartridge into the left slot.
Note: Push up on the nearest side of the cartridge until it clicks into place.
4. Confirm that the ink cartridges are installed properly.
(A) The ink cartridge is not installed properly.
(B) The ink cartridge is installed properly.
5. Close the front cover. Wait until the preparatory operation is complete; it takes about one to two minutes.
How to remove ink cartridges
2. Remove the ink cartridges.
Good luck
Feb 15, 2010 | Canon Pixma iP2600 Photo InkJet Printer
I m having problems installing the ink cartridges and sggestions?
Installing ink cartridges:
Nov 03, 2009 | Canon PIXMA MP460 All-In-One InkJet...
How to change cartrigde
  1. Make sure that the machine is turned on, lift the Scanning Unit (Printer Cover) with both hands, then pull the Scanning Unit Support (A) down into place.
Oct 24, 2009 | Canon MX300 Office All-In-One Printer
Installation of the cartridge for Canon Pixma iP1600 printer
cartthingsnottotouch.jpg3. Insert the color cartridge into the right slot and then the black cartridge into the left slot.
ip1600puttinginink.gif4. Confirm that the ink cartridges are installed properly.
Jan 06, 2009 | Canon PIXMA iP1600 Printer
Loading the ink cartridge
Please remember to rate other users who assist you for free :)
Sep 29, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Install ink
Installing / Removing Ink Cartridges To print normally, install or remove ink cartridges in an orderly procedure. Installing ink cartridges:
    *MP470 shown
I hope it helps!!!
Dec 08, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Mp 460 tryin to insert ink for the 1st time
Your post is in the wrong place. I almost got you the wrong directions. LOL
Issue: How do I install the ink cartridge(s)?
Solution: Installing / removing ink cartridges MP160 / MP180 / MP460
Nov 12, 2007 | Brother HL-2040 Laser Printer
75 people viewed this question
k24674
jasbo
jasbo
