Question about Sharp MX-2300N Color Copier
Won't connect with computer
Suddebly print will not respond to computer commands
  • 29 Answers
Ping the ip address of the printer if the request times out check all the connections and the router
rest everything
Posted on Mar 09, 2009
Not responding
Check that, the printer is connected to your computer and that you are able see in under "Devices and Printers". If the icon of the printer is grey then there is a problem with your data cable. Alternatively, you might want to check that the "Print Spooler" service is properly running. To check it, simply right-click 'Computer' and select 'Manage', from the window that opens, simply select the services option from the tree and find a service called "Print Spooler"
Nov 07, 2013 | Epson Stylus CX7300 Series
I Have A Epson PLQ-20 passbook Printer and it is connected through USB cable. after successful setup when i give print command to the printer it is not responding and nothing happened.
Sep 20, 2011 | Epson Passbook PLQ-20 Matrix Printer
My printer dont print
Hi
The first thing to check is the cable replace and try to print. If still the printer does not respond then you can check to make sure the port on your computer is working. If you are connecting to a USB port then try to use a pen drive etc., to make sure its working. If connected to LPT then try to go to DOS mode in the Command prompt try to give the command as C:> DIR>LPT1 this should print a list of files on the root directory of C: if this is printed then the problem may be with your application.
Try to make sure of the printer is set to be used as off-line or Pause printing.
Jul 17, 2011 | Epson LQ 680 Matrix Printer
Printer does not respond to "Copy" command
Press and hold the Setup button, and then press Options (or Copy Options ).
It will bypass the alignment.
Apr 09, 2010 | HP PSC 2175 All-In-One InkJet Printer
Five computers networked with Linksys WRT320N router. Operating systems: Win 7.0 on 3 computers (two hardwired)(one laptop - wireless), Snow Leopard 10.8 on 1 (wireless), and XP on one (wireless). Also...
Sometimes this problem occures when you install a later model wireless router.
Try installing the latest Wireless card driver on the XP computer and the LAN card drivers on the other computers except the MAC.
Dec 31, 2009 | HP LaserJet P2015n Printer
Driver
if the copier is not responding to print commands then you need to verify that the ip address listed in the print driver is the same as the one on the copier and that the copier's ip subnet and gateway are apropriate for your network...
Dec 29, 2009 | Sharp AR-5320 Black and White Copier
It won't print anything, the command would be
you have lost your printer driver .
delete the original one in add and remove section and re install it and it should be printing after that
Sep 28, 2009 | Office Equipment & Supplies
Hp 4180 won't connect to my computer all of a sudden AND DOES NOT RESPOND TO PRINT COMMAND
1. check cable connection. Reconnect printer to different usb slot. 2. check drivers. Reinstall it. 3. check system registry with special tools.
Oct 17, 2008 | HP Office Equipment & Supplies
All in One Printer/Scanner/Copier will not respond to print command.
Pls make sure that your computer recognizes your Printer, if it doesn't it would never respond to any print command you sent
check to see (if the computer recognizes)
1- go to start then select printer
2- select your desired printer - right click
3- go to properties
4- select print PRINT TEST PAGE
5- check the message on your paper
if it doesnt then you might have installed a wrong driver
Jul 14, 2008 | Office Equipment & Supplies
Will not respond to print command
download the newest software from web and install it. if its not helping, check connections, if your printer has a display and menu key, you can print aut configuration and demo sheets, to see that the printer itself works. if not the last option is firmware upgrade.
Jan 31, 2008 | Konica Minolta magicolor 2400 Laser...
Sharp MX-2300N Color Copier Logo
182 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
