Question about Jarden HWM6008-UM - Holmes Warm Mist Humidifier
Holmes humidifier won't reset - Jarden HWM6008-UM - Holmes Warm Mist Humidifier
I am unable to open the tank cap.. it is stuck.
Service and Support at HolmesProducts com
HolmesĀ® Brand Customer Service
HolmesĀ® Home Appliances
1-800-546-5637
Phone Number
800-284-3267
Holmes Calls You Instead Home > Find a Call-back > Holmes Calls You Instead
It's true! We can have Holmes call you so you don't have to wait on hold - free! You can go back to what you were doing, and avoid the waiting on hold on the phone. We'll do the waiting for you.
reference: http://gethuman.com/phone-number/Holmes/
Nov 23, 2014 | Jarden HWM6008-UM - Holmes Warm Mist...
Red light keeps blinking
Hello, this is Ava with Think Crucial.
It looks like you may need to change your filters. It is advisable to change filters every 3-6 months for optimal use. When replacing your filters, make sure that the unit is turned off and unplugged from the power. Once filters are replaced, turn on your unit then press and hold the filter check indicator button for 3 seconds. The indicator light will blink 3 times and turn off, and reset the filter change timer.
You can purchase a wide variety of high quality Holmes replacement parts for your Holmes Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?type=product&q=holmes
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Aug 24, 2014 | Holmes Products Air Purifiers
When bar light is on level 3 what does that mean holmes air purifier
There are 3 settings for optimum air filtration. You can operate your Holmes air purifier continuously on the Medium (2) setting. It's rugged motor has been designed to give many years of use. For quieter operation (such as bedroom), select the Low (1) setting. When high levels of air polution are present, select the HIGH (3) setting to quickly circulate and filter the room air.
Ava B.
May 19, 2014 | Holmes Products HAP422-UC Air Purifier
Red filter light does not change to green when filter is changed
Call the manufacture and tell them it is defective and to please replace it.
Apr 02, 2014 | Holmes Products Air Purifiers
My Holmes HAP9412bf air purifier 'filter status' light does not reset with new filter
while running, press and hold the filter reset button for 3 seconds.
Oct 01, 2013 | Air Purifiers
My holmes air purifier makes a screeching sound
If you can access the fan, spray lubricant onto the shaft as close to the fan body as possible. It will work it's way into the bearing
Apr 14, 2012 | Holmes Products Air Purifiers
Cannot replace cabin air filter
buy a new machine on a super sale deal
fyi
Holmes offers its Holmes Odor Grabber HEPA-Type Air Purifier, model no. HAP223-UC2, together with three Holmes HAPF22 Hepa Filters for $29.97 via the directions below. With free shipping, that's $30 off and the lowest total price we could find for this bundle by $33. Recommended for use in room up to 20-square feet, it features air purification and deodorizing. To get this deal:
  1. Add three Holmes HAPF22 Hepa Filters to your cart for $29.97
  2. apply coupon code "H0PVGRAB3" to add the Holmes Odor Grabber for free
May 25, 2009 | Holmes Products Bionaire Permanent Filter...
Hepa (HAP223)
Apr 08, 2008 | Holmes Products (HAP223-UC2) Air Purifier
Replace Filter Indicator Will Not Turn Off
I owned the previous model of the same unit with the hole for the paperclip. But it wore out and I replaced it with the HAP422 and found the same issue; no hole to "reset" the light. I was just fooling with it and determined that "some" switch would reset it and finally held the power on button on for a few seconds, after which, the red light flashed and then went out. Problem solved. BUT THERE IS NOT ONE WORD IN THE MANUAL TO TELL YOU THIS! WHY NOT?
Dec 18, 2006 | Holmes Products HAP422G-U Air Purifier
Jarden HWM6008-UM - Holmes Warm Mist Humidifier Logo
89 people viewed this question
Top Jarden Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you a Jarden Air Purifier Expert? Answer questions, earn points and help others
