Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Changing out old thermostat
I have an old white rodgers thermostat and putting in a programable RTH7000 series from Honeywell. My old one has A wire and new one does not. Where would that go or is it not needed on the new thermostat?
  • 92 Answers
Your old thermostat is a milivolt and the wire runs from the heater to the thermostat. You have to open the back of the new one and connect the wire as per the instructions on the wireing diagram that came with the new one. I just installed a similar one myself, you will be very happy with it.
Posted on Jan 24, 2009
Need help understanding how to wire a new programmeable thermostat. I currently have a White Rodgers 1F73 model (non-programmeable) connected. I am confused with the instructions on how to connect the...
the black wire is your common wire, you need to program your thermostat, in the advance mode, to tell the t-stat if your heat pump reversing valve is energized on cooling or heating, is the orange wire connected to your t-stat.= w2/o/b
Dec 20, 2014 | Honeywell Heating & Cooling
How do I replace an old White Rodgers thermostat with new honeywell TH5220
The Orange wire for the reversing valve and used with a Heat Pump
If you have a heat pump, then yes. If you have a gas furnace then no. If you have a HP and the reversing valve is not connected, then you might just be using the emergency electric heat strips. :-o
Jul 21, 2014 | Honeywell Th5220d1003 Non-programmable...
W and W2 wiring on old thermostat...where do they go on the new thermostat?
It depends on the equipment you are connecting the thermostat to. If you have a heat pump, the thermostat must be wired differently than if you have separate heating and cooling equipment. If you have a two-stage or modulating furnace (or boiler), the w and w2 wires will conect for heating, and the y and g wires will connect to the air conditioner. Naturally, some configuring must be done with the new thermostat so that it acts correctly. w-w2-wiring-old-thermostat-go-new-u40lsvyytnuesyuv3fbafhtd-1-0.jpg
please mark this answer helpful.
Feb 22, 2013 | Honeywell RTH6400D 5-1-1-Day Programmable...
Replacing WHITE-RODGERS manual thermostat with 3 wires ( red, white, blue and installing Honeywell electronic thermostat RTH110B, how do I connect it? The heating is not central, baseboard heating.
I have only seen one Honeywell thermostat that would work with a 3-wire heating system.
I would replace it with a White-Rodgers 1F80-0471. They are about $100, but they are a good thermostat, and they work well with the 3-wire zone valves.
Most other thermostats have the "Y" terminal that you need, but do not control the zone valve correctly.
Helping Hands Services
- Fairbanks, Alaska -
Jan 30, 2010 | Honeywell Electronic Programmable...
I'm replacing my old thermostat with a honeywell
usually you should have 4 or 5 wires....if you have AC then this wire should be Y if not was it connected at all before?...Heating requires only R&W
Oct 24, 2009 | Honeywell Electronic Programmable...
Honeywell RTH3100C
You need to go into the installer setting to change it from heatpump to single stage gas heat.Go to if youve lost them.
Dec 13, 2008 | Honeywell Programmable Thermostat Heater
Installing Honeywell RTH7000 - I have too many wires!
check to see if the B terminal is on the new t-stat if connect to it , but this terminal refers to heat pumps and is normally use to energize the reversing valve on the outside unit and not used on ac units , but normally the tag O/B is the same terminal on therostats
Oct 26, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
211 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
