Question about HP Photosmart 945 Digital Camera
Card locked? I have a HP 945 but everytime i turn my camera on to take pictures, the camera says the card is locked? but the card is not on lock i tried several other cards, but all with the same problem.. Does anyone nows how to solve this problem?
  • Anonymous Nov 06, 2007
    I have the hp photosmart 357 with the same card locked problem.what do i do?
    Problem Solver:
  • 12 Answers
Hi, if that would have happend to me the first thing i would try is to clean the SD card socket with alcohol.
open the camera and gie it a try.
Posted on Nov 21, 2007
SOURCE:
Everytime i try and take a picture it says card locked
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 29, 2011 | Samsung PL200 Digital Camera
When you turn camera on or try to take picture it says card locked
The memory card in the camera has been locked. if you remove the memory card, you will see a small tab on the card and it is likely switched to the "lock" position. This can happen easily by accident if you are handling the card. Simply slide the switch on the memory card away from the lock position and you should be back in business.
Apr 17, 2011 | HP Photosmart M425 Digital Camera
Does Hp 945 work without a memory card
Yes, but the camera has only 32M of internal memory so you won't be able to take and store more than a handful of pictures. For "real" use you'll need one or more SD cards. Make sure you get SD cards 2GB and smaller, not SDHC cards.
Aug 18, 2010 | HP Photosmart 945 Digital Camera
My hp 935 is saying that the memory card is locked. I have turned the camera off and back on again. It still does not work. I have taken the batteries out and back in and nothing. I do not know what to do....
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Mar 11, 2010 | HP Photosmart 945 Digital Camera
My camera says card locked
Your memory card has a lock switch, move the switch to unlock.
Jul 02, 2009 | HP Photosmart M447 Digital Camera
Unlock card on digital camera
I JUST HAD THE SAME PROBLEM WITH MY CARD SAYING ITS LOCKED.....TAKE YOUR CARD OUT OF YOUR CAMERA AND TURN IT WHERE THE LABEL IS FACING YOU AND ON THE LEFT SIDE IS A SMALL TAB THAT IS COLORED DIFFERENTLY THEN YOUR CARD....SLIDE IT UP TO WHERE ITS NOT ON THE LOCKED SIDE....
May 03, 2009 | Polaroid I533P Digital Camera
Hp photosmart that keeps saying card locked when inserted
Write Protection: There is a tab on the memory card so you will you need to remove it from the camera and change the position of this tab to "unlock" it.
Mar 17, 2009 | HP Photosmart M447 Digital Camera - Silver...
How to unlock camera card--HP M525
Little sliding switch on the side of the SD memory card. Remove from camera, slide switch away from lock position, re-install and you should be good to go.
Mar 07, 2008 | Canon PowerShot A530 Digital Camera
Unlock card
If the card is locked, you could the steps below:
- Turn off camera
- Remove memory card
- Take a look on the switch of the memory card itself
* If it's at the TOP = card is UNLOCKED
* If it's at the BOTTOM = card is LOCKED
- So, you just have to make sure that the switch is at the top
for the memory card to be UNLOCKED
After doing that, you just have to put back the memory card to your camera and turn on the camera. Try to check if this works.
Nov 10, 2007 | Pentax Optio 550 Digital Camera
Card Locked
remove the memory card out of your camera and look to the side of it.. there is a little switch on the memory card that locks the card... try that first it might not be your camera... :) good luck :)
Nov 04, 2007 | HP Photosmart R707 Digital Camera
HP Photosmart 945 Digital Camera Logo
82 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
