Home Theater/How to hook up an old Kenwood KA-109 amplifier toa tunner kt-56 also a stero control kc-106
Home Theater/How to hook up an old Kenwood KA-109 amplifier toa tuner kt-56 also a stereo control kc-106
5 Suggested Answers
caroldon
  • 17129 Answers
SOURCE: HELP NEEDED I am having trouble
In the first part use the following leads
1. Keep the Power amp as the base and connect to the Cd input the CD player, the tuner to the tuner input, the cassette deck - play output to the tape in ( amp) and Rec out of tape to the tape out(amp).
connect all the RCA sockets with the R&L in the same side of the input/output.
Now the graphic equaliser input must be connected to the Amplifier's preamp output and the equaliser's output must be connected to the Amplifier's preamp input.
Now the equaliser will work through the amp.
The left and right speakers can be connected accordingly with the polarity in order.
The second system can be connected similarily with the cassette deck, tuner and cd player connected to the input of the Amplifier using the R&L RCA sockets.
Connect the speakers accordingly and test.
Please connect each RCA cord one by one and do not mix them up.
Posted on Aug 28, 2010
dunnbiker
  • 8546 Answers
SOURCE: I have an old kenwood
Connect the RCA Outputs of the Tuner to the RCA inputs for Tuner on the amp.
Connect the output of the Tape Deck to the Tape Input on the amp.
Connect the input of the Tape Deck to the Tape Output on the amp.
Select Tuner on the amp to listen to the tuner.
Select tape Monitor to hear the Tape Deck(s).
Posted on Dec 30, 2010
AJIN G
  • 6694 Answers
SOURCE: Don't know how to hook up kenwood ka-994
Check the bellow link for the user manual of kenwood KA-994. In page number 4 of the user manual You can see how to make the connections to the receiver
Manual
Ajin
Posted on Mar 10, 2012
  • 34767 Answers
SOURCE: universal remote codes for Kenwood Ka 87 integrated amplifier
The applicable code would be found in a compatible universal remote.
Posted on Jan 11, 2017
What is the wattage output of the kenwood ka 728 integrated amp?
Specifications Power output: 130 watts per channel into 8? (stereo)
Frequency response: 20Hz to 20kHz
Total harmonic distortion: 0.007%
Input sensitivity: 0.2mV (MC), 2.5mV (MM), 150mV (line)
Signal to noise ratio: 69dB (MC), 87dB (MM), 107dB (line)
Output: 150mV (line)
Dimensions: 340 x 109 x 369mm
Weight: 9.2kg
Year: 1984
Kenwood KA 828 Manual Stereo Integrated Amplifier HiFi Engine
Nov 15, 2016 | Kenwood Audio Players & Recorders
How do I turn the volume up and down on a Kenwood tuner KT-56
Hello, according to the information I have, the Kenwood KT-56 tuner is just that. This means in order to have volume control you will need an amplifier. The KT-56 only allows changing of the stations, pre setting stations and may be a couple of more options. But it is only a tuner or simply put a display, now you need to put power behind it to make it put out sound.
Jun 17, 2016 | Kenwood Audio Players & Recorders
How do i program my remoteR0728 to work with tuner #KT-56,amp model#KC-106
if you wish to get more details; check the sites linked here. it has set-up code list & set-up procedure to many popular brand remote controls. common set-up codes to check with tvs and other devices are given, in the order of the "device's brand name" in alphabetical order. pull up older posts. surf the site with patience. surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. it will make surf easy.
Jan 21, 2015 | Kenwood Televison & Video
I just got a Kenwood system, i would like to know how to hook it up, it has, Kenwood power amplifier km207, kenwood stereo control amplifier kc 207, disc player dp-m 97, cassette deck ky-77 cw, stereo...
That's a pretty standard setup. RCA cables from the KM207 to the preamp (KC207), and RCA cables from all of the other components into the KC207. Speakers connect into the KM207
Nov 01, 2012 | Master DE Kenwood with Housing...
Manual
Ajin
Mar 09, 2012 | Audio Players & Recorders
I have an old kenwood stereo system I forgot how to hook up it is a ka-87 amplifier a kt-57 tuner and a double deck cassette player kx-57w .Can anyone help?
Dec 30, 2010 | Audio Players & Recorders
I HAVE A OLDER KENWOOD STACK HOME STEREO SYSTEM WITH OUT MANUALS OR REMOTES AND NEED TO KNOW HOW TO HOOK ALL THE COMPONENTS TOGETHER. KC-206 STEREO CONTROL AMP KT-76 TUNER KX-96W CASSETTE DECK KM-106...
start with the tuner, hook up the equalizer to the tuner, then on the rear of the equilizer hook up all the peripherals except the amps which will go to the tuner outputs and all will feed thru the tuner to the amps and out to the speakers
Oct 23, 2009 | Audio Players & Recorders
Am trying to hook up an older kenwood home stereo system and dont know where all of the wires go. There is a model #kt-87synthesizer, km-207 amplifier, double cassette kx-77cw, stereo control amp kc-207...
Okay you are going to need 5 sets of RCA cables of 3 foot lengths. Ensure the KM-207 is adequately ventilated unless you want to burn up the KM-207. Next you will want to place the KC-207 near the KM-207 and connect the "Output to Amp" from the KC-207 to the "Input" to the KM-207. Now you may stack the KX-77CW, the DP-M97 and the KT-87 Tuner in no particular order. I tend to place them sideways so I may access them just in case I don't like how it is set up. Unless I can access them from the back. "Output" or "Play" from the DP-M207 goes into the "CD Input" in the back of the KC-207. "Output" or "Record" on the KC-207 "Tape 1" goes into the "Input or "Record" on the KX-77CW. "Output"or "Play" on the KX-77CW goes into the "Input" or "Play" on the "Tape 1" of the KC-207. "Output" on the KT-87 Tuner goes into the "Tuner Input" on the KC-207. Here is a trick to help you new stuff uses color codes such as White or Blue RCA cable ends, and Red RCA cable ends to indicate White or Blue for Left channel and Red for Right channel. Now you didn't indicate how to hookup speakers so I will not assume you are concerned about anything but using headphones for listening. I hope this has been of assistance.
Aug 29, 2009 | Kenwood Audio Players & Recorders
Kenwood installation manual help?
Click HERE for Kenwood support and manuals.
May 15, 2008 | Kenwood Audio Players & Recorders
Kenwood Home Stereo System
this outdated system,but a regular rca cable will inter connect the components.as or the remote Box i am not aware of any.
GoodLuck
BIGRED
Feb 17, 2008 | Audio Players & Recorders
49 people viewed this question
 Grubhead
Grubhead
