Question about Sewing Machines
Why doesn't the Sunbeam handheld sewing machine work?
Uses four AA batteries. All parts seem to move freely, batteries are new but the machine doesn't run. Suggestions, please.
bargainbox
  • 1388 Answers
SOURCE: vintage new home (XR-VII model 990)sewing machine with a handwheel problem
Can you post a photo of the machine, cannot find a reference to this model.
1st just check around the bobbin case area for jammed thread, also in/around the *takeup lever (up/down arm) mechanism near needlebar, as thread often gets wound around and jams the shaft
If it really seems like corrosion in an elderly & neglected machine.... disconnect from power, and using a small rocking movement of the handwheel to identify the parts that should move and with all the covers removed and in a dry well ventilated area with old newspaper to absorb excess,
.......give a light spray of WD40 or similar penetraing lubricant on horizontal Top shaft at each end where it joins main body
..... the region that operates the *take up lever cranks and counterbalance
.....the handwheel has a clutch mechanism, so if you can undo the wheel to access this, it may well be dry and need lube.
.....In the base is another horizontal shaft lube each end and a little where the gears meet to change the drive direction under the hook race/bobbin.
With the same gentle rocking motion of handwheel, see if there is any improvement ...but do not force anything......(to stitch forward, the handwheel spins "over the falls" toward you)
You may not see immediate improvement, so leave overnight and be patient, it may take several days........just be very sure there is nothing jammed anywhere.
Posted on Feb 26, 2008
SOURCE: needle jam
stuck the whole machine the needle did not move .needle and wheel handle both are stuck
Posted on Feb 28, 2008
  • 11 Answers
SOURCE: missing part of sewing machine
That should be your foot I'm guessing?!? The machine should have come with several?!? Like, a zipper foot, button hole foot etc. Mine (Janome SX 2122) are stored in my machine, in the top section where you load the thread. , you can use one of the others. Mine also has a spare basic foot...have a look and see if it's there either in or with your machine or with some of the extra parts it should have come with (may run into troubles if it's second-hand though...as you may not even have all of the parts)...if you don't have a basic foot you can often just use one of the other feet (like a zipper foot or something), which may not quite hold the material down, depending on what you're sewing, at least until you get a chance to get another basic foot...which you can get from any store that sells material or sewing machines. Hope that helps :)
Posted on Feb 18, 2009
Zenqi
  • 208 Answers
SOURCE: Temp misplaced Pfaff 1471 manual during move.
Unplug the machine and check to make sure that the contacts for the batteries are clean and that the batteries are installed with the correct positive and negative orientation. Plug the machine back on and test.
Posted on Jun 27, 2009
SOURCE: when starting to sew, cotton
it is possible that the needle & thread are not compatable
here's how to check
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Posted on Oct 07, 2010
Testimonial: "many thanks for your advice, most appreciated and especially so quickly. Will follow advice and check, thanks again"
Elnita 130 sewing machine is weak when starting
So, the motor is straining to run the machine? Your machine is mechanical? Then, the old oil has most likely solidified and is preventing the machine parts from moving freely. Do not force the motor until you can get the issue addressed or you may burn out the motor. The following method has worked on several old Berninas that were seized:
Wheel on right side that controls the needle up and down is very tight...
Will not zigzag or decorative stitches New to these newer plastic style...
Nov 19, 2016 | Sewing Machines
My sewing machine started to sew slow and seem like it is working hard. Won't sew normal. Hasn't been that long since it was last serviced/oiled. Any suggestions?
Slow is due to friction in the shuttle drive and key moving bars and joint. Apply few drops of petrol/kerosene and run for few minutes. Then apply normal lubricating oils meant for machines.
Dec 15, 2014 | Sewing Machines
New home 692 sewing machine will not sew zig zag even with knobs in correct position, any clues?
the cam or gear that controls the zig zag could be damaged or
worn, I suggest the machine be checked
Nov 06, 2012 | New Home Sewing Machines
Need a mignon Aa battery for my Pfaff.
Your local guy is right. AA batteries are a type of cell (think size, voltage and shape) . The brand doesn't matter.
Sep 08, 2012 | PfaFF Sewing Machines
The motor runs on my Singer Merrit 8734 but the needle doesn't move.
if you have to undo the clutch to wind the bobbin, then try undoing the clutch again & then retightening the clutch & see if that helps & if it doesn't help the machine needs to be checked
Mar 26, 2012 | Singer Merritt 8734
Embroidery arm is free moving. seems to have a new rattle in it. I took it apart and there is a broken piece. Is there a diagram of the internal parts of the embroidery attachement
http://parts.singerco.com/CPpartCharts/alpha/CE-150_250_350__SES1000_Parts_list-07_08.pdf
this shows aa parts ,mine suddenly started to do this today. VERY LOUD
Jan 14, 2012 | Singer CE-200 Quantum Futura Computerized...
My juki serger mo-634de suddenly stopped working. Lights on, wheels and parts move freely, even stitching seems to work if I turn it manually, but nothing happens when I push the pedal. No sound. ...
Hi, I have the exact same machine. it sounds like the wire from the foot pedal to the machine is broken. You would still get power from the wall to the machine to light the light, but no 'gas pedal'. You could maybe get an electrian to test the connection under the foot pedal and if the wire is damaged? or maybe the part that plugs in the machine is cracked or damaged?
Good luck! Annette
Jan 08, 2012 | Sewing Machines
Sewing Machines Logo
29 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
