Question about Goodman Manufacturing SSZ160241A/GMVC950704CX/CAPF3636C6 - 2 Ton 16 Seer 95% Efficient 70,000 BTU Variable Speed Goodman Gas Furnace / Electric R410a Hybrid Heat System
Blower will not shut off on our Goodman ARUF 364216BA
Goodman ARUF 030-00a-1 leaking freon
spray with soap bubble solution let sit hour then check
Feb 25, 2013 | Goodman CKL36AR36 Air Conditioner
I had a goodman ARUF split system installed 8-25-09.Since then the heat exchanger blower motot replaced,cost $602.75,outdoor condenser unit fan motor to be replaced $592,00,recommend 5/8xing...
Hello, Usually it has to do with the quality of the install and the brand. If it was not installed properly from the beginning then the equipment will fail prematurely. As far as the heat exchanger goes I have replaced many heat exchangers on Goodmans after 3 years being installed, Goodmans are prone to bad heat exchangers.
Mar 05, 2011 | Goodman Heating & Cooling
I have a heat pump model ARUF 042-00A-1A. There is only air blowing but no heat comming out. What can we do? Thanks
Heat pumps are like a refrigerator. Check the "pump" part is working properly. and is cooling one side, heating the other.
If not - maybe run out of gas (needing technical repair and refill) - or a motor fault.
Dec 27, 2010 | Goodman Heating & Cooling
I have a goodman aruf 036-00a-1. When I turn the heater on for the first time each season it smells like a burning dog. What can I do?
all heaters smell that way after a long time of not useing it, it's the lint and hair ,dust built up in the unit,clowny daggers
Nov 09, 2010 | Goodman CKL36AR36 Air Conditioner
My modle number is aruf 036-00a-1 my serial number
MY MODLE NUMER IS CPLE42-1 SERIAL NUMBER IS 010940037
Aug 04, 2010 | Goodman CKL36AR36 Air Conditioner
check the settings on automatic fan control check fan control is clean on the back , check humdifer stat is not set too high ,if fitted .........
Jan 09, 2010 | Goodman Furnace Draft Inducer Blower ...
Goodman heat pump aruf estrips on all the time
cross check your info plate on the outdoor unit with the curcuit breaker installed in the main panel.
Jan 12, 2009 | Haier Energy Star ESA3183 Air Conditioner
Connecting electronic air filter to furnace fan
You may need a "current sensing relay" to clip around the neutral wire on your blower.
Run the 120v power to the main power (the power switch- hot,neutral and ground) . Run the Hot wire through the "Current Sesing Relay" wires to the EAC unit's 120v. power input. The unit will only run when the fan is on.
Hope this helps,
Matt
Dec 31, 2008 | Goodman Heating & Cooling
Goodman Manufacturing SSZ160241A/GMVC950704CX/CAPF3636C6 - 2 Ton 16 Seer 95% Efficient 70,000 BTU Variable Speed Goodman Gas Furnace / Electric R410a Hybrid Heat System Logo
37 people viewed this question
Top Goodman Manufacturing Heating & Cooling Experts
Robbie Daniels
Level 1 Expert
zephyrusd
Level 1 Expert
snowmanii
Are you a Goodman Manufacturing Heating and Cooling Expert? Answer questions, earn points and help others
