Question about Dryers
Replaced bad heat unit
After taking and getting the thermal fuse and thermostats check, found heating coils bad. Put everything back in ,however the heating coils has only two pongs and only one wire going to it. Hard to hook wires wrong. All the pongs are different size, so you can't put small on large etc. There is no other wires and nothing left over. Do I have to bridge the pongs on coil? Help, wife wants dyer working and a happy wife is a happy life. It is a Kenmore electric model 110.66642500 two years old.
    Sniper:
  • 50 Answers
There has to be another wire. is the one wire you have connected a long wire that goes to terminal block? or is it a short wire , no more than 6 inches that goes to the thermostat and to the other leg of the heater? my guess is you don't have the shorter wire or you wired it incorrectly, especially if the short wire is there the longer wire has to be somewhere these things just don't disappear
Posted on Jan 24, 2009
Replaced all parts for dryer because of no heat dryer runs drum turns had breaker and wiring going into dryer everything ok still no heat could wires be backwards going to replacement parts?
Electric dryers have as many as three thermal fuses. See if you might have missed one. One next to coils, one next to drum and one near the lint trap at air outlet. All three have different trip settings.
Jan 04, 2016 | Dryers
Suddenly quit drying. Everything works but the heating element
Hi tgs6727...
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor/thermal fuse one at a time by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
To test your thermostat/thermistor/thermal fuse remove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset.
You can test it with an Ohm meter or continuity checker, remove both wires from the thermal fuse and put the test probes to each of the ends of the thermal fuse, if no continuity then replace the thermal fuse.
A vent clogged with lint can cause it to overheat.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace a generic element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Please take time to rate me thumbs up
Sep 21, 2011 | Maytag Dryers
My roper dryer won't start unless i find just the
Hi jodiew0228...
Sounds like you have two problems
1...Bad timer...replace your timer
2...Something wrong in the heating circuit...
Check your Wiring
Sep 16, 2011 | Roper Dryers
13 year old Whirlpool dryer blew thermal fuse. Bypassed to test and found that when door is wide open, dryer heats up to normal temperature. When I close the door, the heat automatically goes way down to...
Hi JWillett06...
My thoughts are to change the door switch...
Check out some of the solutions below...
Check your Wiring
Sep 14, 2011 | Dryers
My offerer istaking lingers slinger to dray load. The filter is cleaned after each loadandthe unit does heat up but drying takes as many as six cycles. Any diagnostic ideas? B
Hi brentf524...
Check your Wiring
Sep 09, 2011 | LG Dryers
Is there a way to check the thermostat on the heating coil of a Bosch 500 series dryer with a meter? I've got no heat but I have 240 to the unit and the heating coil has contiunity. The thermal...
Hi mk3327...
Try these solutions to your problem:
Check your Wiring
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse, by removing the wires from each of the two terminals and checking each terminal on the thermal fuse,thermostat,thermistor, ect once you have the wires removed.
Then you do not have to tape the wires together as described above.
Sep 08, 2011 | Bosch Dryers
8577274 for Whirlpool Dryer Thermal Thermistor Fuse will dryer motor run if bad
Hi ibw3rd
To answer your question...No the dryer will not run if the Thermal/Thermistor/Fuse is faulty.
Here are a few more things to check also
Check your Wiring
Sep 08, 2011 | Whirlpool Dryers
I have an amana electric dryer. Will not heat up. i checked thermostat for continuity it is good. i checked the two thermal fuses for continuity they are good. I even jumped a wire accross all three...
Hi pitsburg69...
you have probably already checked some of these...
Check your Wiring
Sep 04, 2011 | Amana Dryers
Dryer wont heat up? we checked the home fuse box and everything good there so now what?
Hi robslobinc...
Check your Wiring
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
To test your thermostat/thermistor/thermal fuseremove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
Aug 19, 2011 | Kenmore 67082 Electric Dryer
Whirlpoool dryer not heating replaced the thermostat
Dont know the model number you have, but most of your items are located in the back of the unit. You need to make sure you replaced the thermostat, and not just the thermal fuse. The thermal fuse sits on top of the element shield, the thermostat is lower, down where the wires go into the element. You may have changed the thermal fuse, but the thermostat may be out. You will need to check (with an ohm meter) all the componants to find the trouble. If that thermal cut-off has went bad again, change the thermostat with it. Be sure you have very good ventilation all the way through, bad vents will cause problems like this all the time. Let me know if you need parts info. Let me know a model number as well.
Nov 16, 2008 | Dryers
Dryers Logo
Top Dryers Experts
