Question about Toshiba Satellite A105 Notebook
All leds flahing and power on switch falshing yellow wont turn on
When i plug in the power cord all leds flash and also the power switch to trun it on with and the screen flashes to , and i can not get it to power up so i can get in to it. my son got it to turn on once and then no more so i just dont no what to do no .. i was told power cord or motherboared i just dont wont to put a lot of money in it or i will just go get a new one . if you can help let me no please thanks it is a ( toshiba satellite )
A105-S2194 (MODLE) PSAA5U-00Z01C POWER CORD. 19 .V 3.42A
THANKS GOD BLESS Pastor: Eld. william spradling
Could be a battery failure
Posted on Jan 24, 2009
Power wont turn on..battery led flash orange
Remove battery. Maybe faulty? Try another cord/charger with the EXACT same specs. Reseat the Memory Mods. has the AC jack been damaged by pulling on the cord? Try plug in and at the laptop's AC jack "wiggle" the AC jack plug. Any change?
Jan 04, 2013 | Toshiba Satellite U305-S2804 Laptop
TV wont trun on. Pull plug and wait 5min, still wont turn on. What can be done to fix this
Tv turn on?Front LCD panel LED power light indication flashing?Yes,than the power supply board is dead,that the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jul 09, 2010 | Philips 32PFL3403D/27 32 in. LCD TV
The monitor wont work
plug back to vga and setup multy screan c
Jun 25, 2010 | Sceptre X9G-NagaIV 19" LCD Monitor
THE TV IS CUTTING OFF BY ITSELF AND THE OPC LIGHT IS BLINKING
This problems very common on Sharp Tv.Do ur tv LED power light turn on solid first.Few mins,than LED,OPC flahes.Power LED,OPC flashes,push power button again,do this at leat 5 or 6 times somtimes the backlight will come back on and work.The power LED,OPC light flashes,turn off/on more than 5 or 6 times don't work.Ur Tuner signal board is dead,must replaced.
Mar 30, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
The PC doesn't start. led is not blue when power cord plugged
Below is a link to the service and maintenance guide. This will serve as a reference for disassembly. It is free to use, copy and print. It is in PDF format. I would check the voltage at the tip of the adapter to make sure it is putting out the proper voltage. I have seen plenty if failures with the HP laptops at the DC jack area, in most cases these jacks are connected to the motherboard by a cable and plug, which makes them easier to service than the soldered type. Here is your guide........
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c01550099/c01550099.pdf
Jan 13, 2010 | HP Compaq 6830s Laptop
Canon ip1800 printer not working
when the yellow led flashes is never a good signal... you should check the manual's printer to find out the error code meaning "4 yellow flashes and 1 green)
Usally it's the waste tank that is full, in this case you need to:
  1. Push “resume” for 5 seconds for canon IPXXXX.
  2. Push Power switch then remove power cord.
  3. Insert plug power cord while pressing “power switch” at the same time.
  4. Push Start/reset by step 2 continue Wait display shown “0′
  5. Push + change display from “0′ to “1′
  6. Push color button 2 times
  7. Push Power switch again , Printer will print 1 page
  8. Open cover
  9. Unplug power cord
  10. Take out ink cartridge #40 and #41
  11. Insert plug again
  12. Push power switch
  13. Open cover (scan cover)
  14. Insert ink cartridge #40 and #41 again
Jul 18, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Flashing light in gauges
security system . Trun the ignition key on and leave it on for about twenty minutes,(light should stop falshing) then try and start it.
May 20, 2009 | 2000 Pontiac Sunfire
Cx2620 gateway wont turn on
Possibly Need a New DC Jack In Your Laptop... the DC JAck Is The Port Where Your AC Adapter Plugs Into...
Though You SHould as well Check For Proper Power To Your CHarger Cord.. Not all AC Cords That Have Their Lights On Are Able To Charge...
To CHeck If It's The DC Jack... Remove Your Battery..... Plug In the AC Adapter Cord... Power On... If You Get No Lights/ No Power/ No Fans Etc..... It's Your DC Jack
Nov 20, 2008 | Gateway Convertible CX2620 Notebook
Laptop won't power up!
disconnect the battery and just keep the ac power connected. hold down the FN button and hit the power button. if some lights falsh and the computer shutsdown in 4 - 5 seconds its a bad motherboard. If you get other light lemme know. Call dell tech support and get a dispatch made if system shutsdown right after the lights flash. You can also try the chat support at www.dell.com/chatsupport
keep a phillips screw driver handy when you call as they might as you to disconnect the hard drive, CD drive and other cards like thememory card and wireless card to check if they are not causing the issue.
Rate if helpful.
Sep 24, 2008 | Dell Inspiron 1501 Notebook
Toshiba Satellite A105 Notebook Logo
117 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
