Question about Samsung HLP5085W 50" Rear Projection HDTV-Ready Television
Tv continues to turn on and off by itself..
The tv turns on and off by its self with no picture.
When it shuts off by itself, does the blue circle screen under the "Samsung" label show a picture of a light bulb? If so, it's probably time to replace the lamp.
Posted on Feb 08, 2009
My tv has double color and tthe picture flips then turns itself off.
sounds like a short in the convergence circuit based on model number listed here,
Apr 17, 2012 | Toshiba 43H70 43" Rear Projection...
Replaced lamp, however 50% of screen continues to turn black when the TV is on a long time.
This problems it is not fixable or worth fixing because of the CRT picture tube of screen itself.Slowly dying,now the tv it is not worth a whole tv anymore if tv require a new CRT picture tube.CRT picture tube,if u can get a hold of it,most likely only can buy it from the tvs corporations themselves only and they charges u like a new tv,because the CRT picture screen it self 90% important to the tv functions itself.
May 23, 2011 | Samsung HLR5688W 56" Rear Projection HDTV
My Philips 36'' CRT TV won't turn on.
Hi - Yes. There are high voltage components in your CRT TV that only a certified TV repair shop should repair. And the cost of that would likely be over $100 so you are definitely better off getting a new LCD TV. You will also save a great deal of electricity with your new TV, my 55" only uses $19 worth of electricity a year. And the picture is much better as well.
Have fun shopping!
May 05, 2017 | Philips Televison & Video
Goodmand 42'' TV turns itself off
Check to see it your TV has a timer and it was accidentally touched to activate. Good luck.
Jul 04, 2009 | Televison & Video
TV shuts itself off..red light blinks 7 times.
the only way is by bringing to a tech.i think there is no need fro self-fixing with problems like this.try tapping the tv several times then turn it on.
May 28, 2009 | Televison & Video
Turns on, no picture or sound, light blinks 5X, reboots itself
First thing is to check the lamp. you can easily change this yourself.
May 26, 2009 | Samsung HCM4216W 42" Rear Projection...
Tv Turn sound on, No Picture, turns itself off within seconds
The TV is trying to go on protect mode because an internal fault had been detected. For that reson the protection circuit keeps turning off TV continuously.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
May 23, 2009 | Sony KLV-30HR3 30 in. LCD Television
Tv turns itself off and on.
I just had this problem. The plastic back of the TV has a grated opening directly in the middle and towards the top of the TV. There is a fan directly behind. The grated opening was full of dust so air couldn't pass easily. I simply vacuumed the dust. I went the extra step and removed the whole back of the TV and vacuumed the entire space.
I assume the internal temperature exceeded its maximum so the TV turned it self off. Cooled enough to try a restart, heated up, ...
Oct 02, 2008 | Sony WEGA KZ-32TS1 32 in. Television
TV turns on by it self then constantly changes channel
the controler brain has to be replaced main bord
Feb 03, 2008 | Televison & Video
Samsung HLP5085W 50" Rear Projection HDTV-Ready Television Logo
404 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
