Question about David Clark Sport & Outdoor - Others
C10-15 connector replacement - David Clark Sport & Outdoor - Others
Printing blank copies
1. No transfer charging. A. The connector terminals of the high-voltage PCB make poor contact. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. B. Defective engine PCB. Replace the engine PCB and check for correct operation. C. Defective high-voltage PCB. Replace the high voltage PCB and check for correct operation. 2. No LSU laser is output. A. Defective laser scanner unit. Replace the laser scanner unit (see page 1-6-29). B. Defective main PCB. Replace the main PCB and check for correct operation. 3. No developing bias is output. A. The connector terminals of the high-voltage PCB make poor contact. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. B. Defective engine PCB. Replace the engine PCB and check for correct operation. C. Defective high-voltage PCB. Replace the high voltage PCB and check for correct operation.
Jun 09, 2015 | Kyocera Mita Drum Cleaning Blade Km 1620...
Winshield wiper delay intermitent module making noises
The wiper delay is in the steering column. It's a small box about 2 x 2 inches with a wiring harness attached. With the testing procedures I found below, you should be able to figure it out. I found wiper delays on eBay for around $10 to $20. Good luck.
WINDSHIELD WIPERS CHEROKEE, COMANCHE & WAGONEER 1. POWER INPUT Remove circuit breaker. Test battery side of circuit breaker. If battery voltage is not present, repair open to splice. Test across circuit breaker terminals. Tester reading should be zero (0) ohms. If not, replace circuit breaker. 2. GROUND Connector A unplugged. Test terminal G. Tester reading should be zero (0) ohms. If not, repair open to ground. 3. INTERMITTENT WIPERS Ignition switch in ACCY. Remove delay module and plug connectors together from the module. If wiper operate in LO and HI speed modes and mist (washer) is working, if wipers and mist operate, replace intermittent module. If not go to step 4. 4. WIPER/WASHER SWITCH Ignition in RUN, wiper switch position as indicated, back probe switch side of connector A for standard, connector B for intermittent: Test connector terminal E-wiper switch in LO and mist/intermittent. If battery voltage is not present, replace switch. test connector terminal C-wiper switch in HI. If battery voltage is not present, replace switch. Test connector terminal F-wiper switch to OFF. If battery voltage is present until wipers stop and then voltage drops to zero (0), system is working fine. If this does not occur, replace switch. 5. INTERMITTENT WIPERS Connector B unplug. Test across terminal A and D while rotating switch from minimum to maximum delay. If tester reading is not between 0-500 ohms, replace switch. Test across terminal A and G while rotating switch from minimum delay to maximum delay. If tester reading is between 0 and 500 ohms, replace wiper module. If not replace switch. 6. WIPER MOTOR Ignition in ACCY, wiper switch position as indicated, probe connector D. Test connector terminal 1. If resistance is no zero (0) ohms,repair open to ground. Test connector terminal 4-wiper switch in any position. If battery voltage is present, replace motor. if is not repair open from fuse panel. Test connector terminal 2-wiper switch in LO. If battery voltage is present, replace motor. If not , repair open from wiper switch. Test connector terminal 2-wiper switch in HI. If battery voltage is present, replace motor. If not , repair open from wiper switch. Test connector terminal 5-wiper switch OFF with voltmeter connected. If battery voltage is present until wipers stop and then voltage drops to zero, system is OK, replace motor. If not, repair open from wiper switch.
Found on the web. I hope this helps.
Rich Long
Jan 26, 2014 | Jeep Cars & Trucks
Kyocera FS-2000D error 6000:0087166
This Code relates o the fuser unit, needs to be replace but if this code keep coming constantly from time to time than you need to check this:
There is a two wire power connector from the switching regulator ( by the interlock switch ) that goes to the fuser connector. This is one of the areas we check for the 6000 error code.
You could also check for a small piece of paper lodged in the fuser connector, both on the fuser and the one at the engine board.
also Check the power at the wall outket. Low power will cause 6000 errors.
Nov 10, 2011 | Kyocera FS-2000D Laser Printer
HP Color Laserjet 3600 shows error 50.9 and 50.1 . It change sometimes 50.9 and sometimes 50.1 . How to solve it?
50.1 Error: (Low fuser temperature)
1. Verify the fuser is installed correctly and fully seated.
2. Check that connector J6007 on the fuser is seated correctly. Replace the connector as necessary.
3. Turn off the printer.
4. Remove the fuser.
5. If there is no conduction in the main thermistor, measure the resistance between fuser connectors J6007LA-1 and J6007LA-3. If the resistance is not 100 kohms to 3 Mohms, replace the fuser.
6. If there is no conduction in the fuser heater, measure the resistance between fuser connectors J6007LAF-1 and J6007-2. If the resistance is not 5 ohms to 1 kohms (100 to 127 V) or 20 ohms to 1 kohms (220 to 240 V), replace the fuser.
7. Upgrade the DC controller firmware.
8. Replace the DC controller PCA.
50.9 Error:(High fuser temperature (subthermistor))
5. Measure the resistance between fuser connectors J6007LA-2 and J6007LA-3. If the resistance is not 100 kohms to 3 Mohms, replace the fuser.
6. Replace the DC controller PCA.
Aug 08, 2011 | Office Equipment & Supplies
The left front low beam headlight does not come on. have replaced the bulb, but only hi beam works.
Since you've eliminated the headlight itself as the source of the malfunction, the problem is most likely the headlight bulb connector - the female connection inside the connector to the hi beam is good, but the connector supplying power to the low beam is bad. Your fix is to replace the headlight connector.
How: buy a replacement headlight connector at your favorite auto parts store, cut off the old connector, then (a) solder and heat-shrink or (b) wire nut and E-tape, or (c) crimp connector the new headlight connector onto the existing wiring (being careful to route the conductors to the correct wires on the connector).
Your cost: about $3 for a new connector
Feb 14, 2011 | 2003 Pontiac Grand Am
Codigo C7760 de una Kyocera kilometros 1635
C7410 C7800 C7810 C8010 C8030 Drum unit connector insertion problem • Absence of the drum unit is detected continuously for 1500 ms while there is no error on the copier. Broken external temperature thermistor wire • The input voltage is above 4.5 V. Short-circuited external temperature thermistor • The input voltage is below 0.5 V. Finisher* paper conveying motor problem • The paper conveying motor lockup signal is detected for 0.5 s or longer. Finisher* paper conveying belt problem • An on-to-off or off-to-on state change of the paper conveying belt home position sensor is not detected within 2 s of the paper conveying belt clutch turning on. Drum unit connector inserted incorrectly. Defective drum unit connector. Poor contact in the humidity sensor PCB connector terminals. Defective external temperature thermistor. Poor contact in the humidity sensor PCB connector terminals. Defective external temperature thermistor. Poor contact in the paper conveying motor connector terminals. The paper conveying motor malfunctions. Defective finisher main PCB. The paper conveying belt is out of phase. The paper conveying belt clutch malfunctions. The paper conveying belt home position sensor malfunctions. The paper conveying belt home position sensor connector makes poor contact. The internal tray is incorrectly inserted. Reinsert the drum unit connector if necessary. Replace the drum unit. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Replace the humidity sensor PCB. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Replace the humidity sensor PCB. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Replace the paper conveying motor and check for correct operation. Replace the finisher main PCB and check for correct operation. Adjust the paper conveying belt so that it is in phase and check for correct operation. Replace the paper conveying belt clutch and check for correct operation. Replace the paper conveying belt home position sensor and check for correct operation. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Check whether
Jan 19, 2010 | Office Equipment & Supplies
Cable input connector broken off
Usually the connector or at least a new connector can be put back on. If there is minor damage to the board, a tech can repair it in most cases.
Jul 25, 2009 | Televison & Video
Electrical Connector burnt on headlight. Can connector be replaced?
cut the wire at bulb install female wire connector
Jun 02, 2009 | 2003 Volvo S80
I want to replace front passenger door
You'll need to support/make stable the door first. remove four (4) 12mm hinge bolts which attach the hinges to the door. Move the door about 4 inches away from the veh to access the door wire harness connector. Disconnect the door wire harness at the connector (connector at the veh body) by sliding the boot off connector & exposing the connector underneath. The connector has a 'release' tab center of the connector. press it and wiggle the connector loose. Install the new door in reverse order.
May 15, 2009 | 2006 Hyundai Sonata
Problem in scanned images uploading
If you have 50 units of computer working the same time such as uploading big files, the problem for the rest among your 7 computers that work fast is between the hub connectors on the network system. You can check this connectors by replacing those slow ones to that faster computers.
Then if your faster computers slow down and the replaced connectors from slow working bacomes fast then the problem is in your hub distribution connectors.
If you had trace to that problem, then replace the whole unit of hub connectors.
Aug 08, 2008 | Microsoft Windows XP Professional With...
Sport & Outdoor - Others Logo
49 people viewed this question
Top David Clark Sport & Outdoor - Others Experts
Are you a David Clark Sport and Outdoor - Other Expert? Answer questions, earn points and help others
