Question about Whirlpool Dryers
Interior light is out.
Interior light housing has what looks like a removable cover. need procedure to remove and replace light bulb. Also need bulb P/No.
    Sniper:
  • 50 Answers
There are two tabs on light shield grasp both and turn to the left it should come off. if not a little friendly persuassion with a screwdriver should do it. replace with the correct wattage bulb. get an appliance bulb they hold up better than regular ones. should be 25 or 40 watt bulb
Posted on Jan 24, 2009
How to replace the brake light bulb in 2010 Chrysler Sebring retractable hardtop
Open the trunk, remove the plastic jamb cover and then the interior cover from the inside of whichever side you want to remove, the remove the plastic wing nuts, and the tail lamp assembly should pop right out allowing you access to the bulb housings which twist lock in to the back of the housing. Hope that helped!
Nov 23, 2014 | Chrysler Cars & Trucks
I need to change the interior light bulb in my Frigidaire over the counter microwave. The model # is FMV156DCA.
Good Morning Evelyn, thank you for allowing me to assist you!
Here are some simple troubleshooting tips to help replace the light bulb on your Frigidaire microwave, FMV156DCA.
    ·First, disconnect power to your microwave. This can be done by either unplugging it or at the circuit breaker panel.
    ·To release cover, remove the screw on the light cover (light cover may become very hot, do not touch glass when light is on).
    ·Remove old light bulb and replace only with equivalent watt bulb available from parts distributor or the manufacturer directly. Bulbs are also available at most hardware stores or lighting centers. Bulbs larger than 30 watts are NOT recommended.
    ·Close light cover and secure with screw removed in step 2.
    I hope this information proves to be helpful. If you have further questions, please do not hesitate to reconnect.
Nov 25, 2013 | Frigidaire FMV156DC Microwave Oven
How do I change the interior light in a 2002 chrysler sebring
perhaps if you were to take a good picture and post it we would have a better idea, as I can not imagine a metal cover over the bulb unless it is some sort of heat shield .
Aug 21, 2012 | 2002 Chrysler Sebring
Replace license plate lights
Firstly, remove the four screws on the bottom of the license plate light assembly using a Phillips screwdriver. Then pull the license plate light cover out away from the rear of the car. Pull the bulb forward and pull it straight out of the wiring socket.
A press the new bulb into place until it is secure. Push the bulb and wiring assembly back up inside the light assembly and replace the license plate light cover. Replace the four screws that secure the light cover and tighten them with a Phillips screwdriver. Finally, turn on the lights to test the new bulb.
Hope this helps...
Jan 17, 2011 | 2007 Toyota Sienna
Our 2005 dodge diesel quad cab 4x4 has a interior light that stays on nd drains the battery steady !!
either you have a door switch thats stuck or bad,suggest until you figuer out which,remove the bulb from interior lighr that stays on,a push button may have gone bad or simply stuck in on position. removing the bulb will stop the battery drain,but will have no inside light from that bulb when you remove it. the plastic cover on that light should just pop out with a straight screw driver when pryed open from one side or other of plastic cover. look for an indentation or slot on side of plastic cover to remove that cover. hope this helps and thank you for choosing fixya.com
Jan 03, 2011 | Dodge Ram 3500 Cars & Trucks
How do you get to the left brake light bulb to change it?
Open trunk,pull trunk interior/liner away from back left corner
Remove three nuts, that hold tail light housing
Remove housing and replace burnt out lamp
They use an extended duty lamp/bulb,you may not find that
I add, that most China Made bulbs, don't last a year. So look for a Wagner, made in Mexico,France etc
Oct 22, 2010 | 2005 Lincoln LS
My interior lights stopped working. i checked the fuse and it is fine. i beleive the bulbe are blown? how do i go about replacing them?
The reflector/cover of the interior lights are press fitted only. you need to remove the same with some small tools like screw driver at right point where they provide a small opening.
Once you have removed the cover, you will gain access to the bulbs.
Jun 06, 2010 | Hyundai Motor 2002 Sonata
Need to change out back brake light on 2006 nissan
take interior cover behind tail light inside trunk off.the bulb the bulb twist locks in hole(twist counter clockwise to remove)repeat procedure to replace.
Mar 23, 2010 | 2006 Nissan Altima
Can't get the glas cover off the interior bulb
If you cannot remove cover with normal finger force, then spray with WD40, and grip cover with a pair of vice grips with a cloth wrapped around the jaws, and try turning it that way.
If it will still not come off, then your only option is to break it, and replace bulb, but make sure you can get a replacement cover first.
Please rate my solution.
Thanks.
Aug 20, 2009 | Neff U1661 Double circotherm super...
Replace light in overrange GE microwave
Advantum 120 over range microwave - with burned out interior bulb: Remove top fron grill cover -- held byu 2-3 screws on top. Remove sheetmetal plate that lies parallel to top of unit, just to the right of the square plastic porting on the far left of the unit. The sheet metal plating is about 12" wide and 8" deep and is shaped like 2 overlapping rectangles. It is held in place by 1-2 screws. (I don't recall if you needed to remove other plastic grid on right front -- I did, but I was still searching for the bulb). The bulb is located about 5" from the left side and about 2" in from the front, covered by a small sheetmetal box. THe bulb looks like the little halogen bulbs used in low-voltage outdoor lights - but is slightly larger - DO NOT REPLACE WITH THAT KIND OF BULB). Remove the one screw holding the box, unplug the bulb and find a replacement. Can't tell you where to get a bulb -- that's what I'm doing next. Good luck.
Jul 25, 2008 | Microwave Ovens
Dryers Logo
1,013 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
