Question about DoALL C-70 Horizontal Band Saw 1963
DoAll C-70 Band Saw
Separating the blade operation from hyudraulics
How does dall 1612-3 power feed work?
Consult your manual. If you don't have the manual , check bandsawmanuals.com ,they have free downloadable manuals.
Aug 13, 2014 | DoALL 1612-3 Vertical Band Saw W/ Blade...
Doall manuals
There's a free downloadable manual on bandsawmanuals.com . I have downloaded manual from them
Aug 04, 2014 | DoALL Model C-916a Fully Automatic...
How to rebuild a transmission on a ellis band saw
I saw a video on youtube about Doall Band saw transmission. If you have time, watch it, and if you need parts, you check bandsawparts.com
Jun 24, 2014 | Blade Ellis 1800 Mitre Band Saw 1" ...
WHAT ARE DIMENSIONS FOR PART
Contact Doall or you may also download manual on bandsawmanuals.com
May 29, 2014 | DoALL SH-3028NC - DC-280NC Production Band...
Saw was running fine and just stoped in middle of cut in Auto and wont start back . Checked fuses all ok.Any help on what to lookk for next?
If it had stopped cutting and won't turn on again, it sounds like the problem is with the motor of the band saw. I suggest you contact Doall or if you have vast electrical knowledge, open the motor and check yourself which part of it have failed.
May 24, 2014 | DoALL 290197 - C-305A Automatic Machine
BANDSAW BLADES
AWSBS2 band saw takes 70 1/2" long blades. Blade Widths : 1/4", 3/8", 1/2" .
Apr 14, 2014 | Saws
Transmision not work
What is the model of your band saw? Try to visit this site metalsaw.com . They offer band saw repair services.
Apr 12, 2013 | DoALL Vairable Transmision Band Saw
Hydraulics leak at the overflow
Typically, the automatic lowering device is a hydraulic cylinder controlled by a bleed valve. The more the bleed valve is opened, the faster the blade will move downward into the material. If the blade is falling too fast, the cylinder may be leaking fluid past the valve. This will also cause the blade to slip or get stuck in the metal material being cut. You need to adjust the bleed valve there man.
Nov 08, 2012 | DoALL SH-3028NC - DC-280NC Production Band...
I'm looking for a table top band saw that will cut 4140 and harder steel, what kind of blade and saw would you recommend. ?
i have a great company for you to contact to find the perfect blade for your needs. go to www.doall.com and click on the doall sawing tab and find the customer support phone number. call them during business hours and you can get at blade tech on the phone that will ask you a few questions to what saw you have and what your cutting and they can put you on the perfect blade. i use them for a bandsaw we use at work, we manufacture awnings and signs. i get all my bandsaw blades from Doall
Dec 24, 2010 | Delta BS100 Shopmaster 9 Inch Bench Top...
My KING KC-115C Horizontal metal cutting band saw cuts off track.
I used to work for Doall saw company. While I am not familiar with the particular model you have, I have seen issues like it in Doall saws.
Firstly, If bearing guides are not adjustable, replace them. There should be only about a 32 of an inch play between them (in addition to the thickness of the blade). Secondly, for a prodution horizontal bandsaw you should have the blade tensioned a @30,000 psi. Thirdly, if after that, you are still having problems, I would suggest checking the bearings on your drive and idler wheels for runout (in addition to the condition of the tires).
Nov 18, 2009 | EZQuest King (K529900) Burner
DoALL C-70 Horizontal Band Saw 1963 Logo
65 people viewed this question
Top DoALL Saws Experts
Tom Chichester
ray gallant
Are you a DoALL Saw Expert? Answer questions, earn points and help others
