Code te comes up on washer wf206bnw/xaa how can i fix
3 Suggested Answers
  • 106 Answers
SOURCE: My washer has a te
It means the THERMISTOR is faulty and most likely needs to be replaced. It's about a 7-10 dollar part, plus shipping. The problem is, you'll need to take the machine apart to replace. The best thing to do, is contact a professional for repairs.
Posted on Mar 07, 2011
  • 6277 Answers
SOURCE: i have a samsung frt load washer wf206BNW/XAA. It
Although you say it's level I really would recommend you try my method to make absolutely certain before considering something inside ;-0)
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly!
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal suspension is malfunctioning.
Good luck,
John C
Posted on Apr 05, 2011
Samsung washer model#wf306law/xaa error code tE - temperature sensor problem. what part do i need
This could be either a sensor or a wiring issue, You need to check the wiring that runs from the sensor to the electronics, the wires can break inside the plastic sleeve and cause the electronics to think there is a sensor fault, It could be a sensor fault but i usually find a broken wire in these machines.
May 10, 2017 | Samsung Washing Machines
I'm getting error code tE on samsung silvercare WF316LAS/XAA
tE is mostly related to
temperature sensor wire and connection problem. Look for a broken or loose wire.
Dec 07, 2012 | Washing Machines
LE in display
Hello,http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf page 18 of this service manual elaborates on the LE error code and what to check.. Hope this helps you..
Thanks
May 30, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Samsung washer wf218anb/xaa has code dc and wont spin clothes they are still wet
The DC error code is an unbalanced laundry error. Try putting less clothes in and if that doesn't fix the problem, then replace the hall sensor( located behind the drum, underneath the rotor).
Mar 03, 2010 | Samsung WF337AA Front Load Washer
Dn error code came up? Won't drain or anything else
I have the same problem with mine. Any solution?
Jul 18, 2008 | Samsung WF337AA Front Load Washer
Te error on LG frontload washer
ARE YOU SURE IT'S CODE IS TE AND NOT DE
DE IS PROBLEM WITH DOOR LOCK . TAKE THE WIRE OF THE DOOR SEAL AT FRONT . PUT YOUR HAND IN BY DOOR LOCK POSSIBLE THE PLUG HAS COME OF THE DOOR LOCK, IF NOT THE LOCK NEEDS REPLACING.
SWITCH APPLIANCE OF FIRST. GOOD LUCK
Jan 10, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
