Question about Refrigerators
Hja 6110 freezer light flashing high temperture error warning indicator
4 Suggested Answers
SOURCE: light and temperture control indicators don't work
The refrigerator was moved to a new location.  The temperature setting was on 41 degrees.  After the move the temperature indicator does not indicate any temp.  How do I reset the temp.  and turn on the indicator?
Posted on Oct 23, 2008
imufo2
  • 3773 Answers
SOURCE: my beko ap930 fridge freezerhas stopped freezing
FREEZER FAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Posted on Oct 04, 2011
  • 2006 Answers
SOURCE: hotpoint ffs70 high temp warning light is on
First check the compressor and make sure it comes on and cycles. Then check the evaporator fan and make sure that is working. Then check for an ice building up on the evaporator coils (an indication of defrost heater malfunction)
Posted on Feb 03, 2012
We have a HJA 6110 American fridge freezer, how do I replace the Freezer motor.
You remove the refrigerant, remove and replace the compressor with new one, install a schraeder valve and using a vacuum pump remove all air from system to -30 lbs and turn off pump to make sure that the pressure holds and there are no leaks in piping. Then charge unit with the correct amount of refrigerant (Critical) and you are good to go.
Apr 24, 2017 | Refrigerators
No alarm sounding but red light is flashing?
Warning light (red)
If the temperature warning light (4) lights up, it
indicates that the temperature within the freezer has
reached a level where the safe food storage is no
longer ensured. When the freezer is first switched on, the warning light will stay on until the temperature has dropped to
a safe level for the storage of frozen food.
Temperature acoustic alarm
This appliance incorporates an alarm which gives off
an audible signal whenever the warning light comes
on. This signal can be temporarily stopped by
depressing the push button for fast-freezing (6).
The fast-freezing push button can be released as
soon as the warning light is off.
Open door acoustic alarm
This appliance also incorporates an alarm which
sounds if the door is left open for more than 60
seconds. The signal will be stopped when the door is
closed again.
Dado
Sep 02, 2014 | Zanussi 3.53 cu. ft. / 100 liter Upright...
FFA74 HIGH TEMP WARNING LIGHT
That indicates that your system is low on Freon or there is a leak somewhere in you sealed system.
samedayappliancerepair.ca
Jul 06, 2017 | Refrigerators
Hotpoint ffs70 high temp warning light is on
Feb 02, 2012 | Hotpoint FFS70 Bottom Freezer Refrigerator
FROST AND ALARM LIGHT ON
Your defrost timer, switch or circuit board is probably shot or it would be defrosting.
Use a fridge / freezer thermometer to tell if temperture high (it should be 0 F plus or minus 5 degrees) to determine if it is too high - this is normal if frost builds up but will get worse unless repaired.
May 04, 2009 | Hoover Freezers
Light and temperture control indicators don't work
Oct 22, 2008 | Refrigerators
Freezer not working
same problem but electronic temperture on in fridge but keeps flashing
Jun 17, 2008 | Bosch Classixx KGV28323 Bottom Freezer...
Fridge freezer lights flashing
the flashing red light indicates a cooling problem,you should call honest local appliance repair shop(not sears they rob you blind)one other thing to try is to unplug for 5 minutes then plug back in and see if it reset sets itself,could be just a board reset issue,let me know-mike
Jun 10, 2008 | Freezers
Servis fridge freezer
It may be that the temperature of the unit is not yet up to temp.The flashing light will indicate this.Warning the user the unit is not ready,or up to safe temp.. Let the unit run to catch up,since you just started it.
Nov 30, 2007 | Frost Freezer WCWO F15WA FREE - POCKET...
Refrigerators Logo
118 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
