Question about Kenwood 2005 KDC-MP5028 CD/MP3 ReceiverFree Standard Shipping
Is it Dead?
My cigarette lighter in the car shorted out and the HU then flickered on and off, then just shut off. I replaced the fuse for the cig. lighter and radio, still nothing. I checked the fuse on the back of the HU and it was good. The HU makes a quiet clicking noise and the red triangle at the top right hand corner of the face plate blinks every now and then.
  • 199 Answers
Hi it sounds like the cd mech is wurring so power should be ok.
try RESETTING the unit with the reset button, you will need a pen tor a pin to do this in most cases. if still no joy, then double check that you are getthing two pwer feeds to the radio
1 should always be there this is the perminant power feed. and the other4 should only be there when the ignition is on.
let me know how you get on.
Mark
Blue ICE
www.blueice-electronics.co.uk
Posted on Feb 26, 2008
Cig lighter fuse keeps blowing out
Research what else is on the circuit. In the old days when cars had more than one cigarret lighter I discovered that a penny fits in the socket perfectly and would cause a short.
Apr 06, 2014 | 2004 Chevrolet Tahoe
Have a short on my infiniti i30t 1996 cigarette lighter ..burns the fuses all the time
Make sure the fuse is the right size. If it is then your best bet is to replace the actual lighter as it's probably the culprit. You could also go one size up in fuses because if there is a short circuit in the lighter it will blow that fuse just as fast. I had the same problem once and it turned out to be the light in the ashtray that had the short. Usually it's the lighter itself.
Nov 01, 2013 | Cars & Trucks
My car radio and cig lighter has stop working
prob just a fuse problem. alot of cars will have the radio and cigarette fuse on same circuit. double check all fuses, if good take to shop cause there is a short somewhere.
May 19, 2010 | Car Audio & Video
Hi,i'm having trouble with the cig lighter on my car, it keeps blowing fuses. can i wire it directly to the battery with an inline fuse? How would i do this?
you could do this by running 2 wires directly from the battery to the back of the cig lighter and by fusing the positive.if it is only when using the cig lighter and not when charging a phone ect.it could be element on the cig lighter shorting
Apr 05, 2010 | 2000 Volkswagen Golf
2006 jeep liberty cigarette lighter problem
its probably not the lighter itself, it's probably lost power. check the fuse for the cig lighter and see if blown. if it is, replace. if it blows immediately you have a dead short. if not, pay attention to when it stops working. could be a problem with whatever you are plugging in, or something else on the circuit
Feb 18, 2010 | Jeep Liberty Cars & Trucks
Radio fuse keeps blowing
make sure nothing in cig lighter socket..coins,etc..if nothing present,unplug cig lighter socket and replace fuse..if fuse doesn't blow,it's the socket causing fault..if it does,unplug radio,plug cig lighter back in and replace fuse..if fuse doesn't blow,radio is cause of fault..if it does,then ther is short in wiring
May 19, 2009 | 1992 Honda Accord
Please help me with power in cig lighter
Hi, grab a voltmeter and test volts at car lighter connector, near to car lighter socket, if there is volts in there (uncommon) , then check for short or broken contact on car lighter socket, or replace the first socket connected in line.
If there is no voltage getting to cig lighter, check the two connections at the back of the fuse box, on the cigarette lighter fuse.
If there is volts only on one side, then fuse is gone again, in that case there is a short on wiring, maybe on one of lighters, locate it and fix it.
If there is power on both sides of the fuse, then fix or replace wiring between fuse box and cigarette lighter, one wire is broken.
If there is no power on both sides of lighter fuse, then fix the wiring between fuse box cig. lighter contact and battery, if this is too complicate you can even build a new wiring and solder in place of the old one.
If the lighters have more than one fuse, do the same job for both lighter. Cig. lighters do not use a relay, and there is no additional fuse, the above procedure is enough to fix any possible problem on such a simple device.
If you have no practice with this kind of repair on car electrical system, then better to go to a car electrician or mechanic rather then messing up the car electric system.
Please do not forget to leave us feedback afterward, that is important for us.
Many thanks.
Apr 22, 2009 | 2002 Mitsubishi Montero Sport
Power port/ cigarette lighter keeps blowing fuses
the cig lighter might be shorting out and cauding the other problem. sell the car and buy a toyota.
Apr 03, 2009 | 2006 Chevrolet HHR
Cigarette lighter and radio not working on 2002 Honda coupe
They probably share the same fuse. Sounds like cig lighter coil is shorted and "fiddling around" blew the fuse. Replace the fuse and try a different lighter coil.
Mar 19, 2009 | 2002 Honda Accord
Kenwood 2005 KDC-MP5028 CD/MP3 ReceiverFree Standard Shipping Logo
140 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
