Question about Cell Phones
Bluetooth files from pc to cell phone
How do i bluetooth files from my pc to my cell phone? i have windows xp, and i dont see any bluetooth settings on my computer.
    President:
  • 1,214 Answers
YOu need to pair the phone to the laptop.
Posted on Jan 24, 2009
Install spyware files
connect the phone using the usb lead to the bluetooth connection on the phone once connected a found new harware should activate on the screen
if it does not activate you might have to install it manually
click start all programs accessories windows explorer
you should see all of your drives C: hard drive D: your cd/dvd drive
your phone might be listed as a mass storage device
click start control panel administration tools computer management device manager look for any yellow question /exclamation marks ? ! or ared X
this means the driver will need to be installed
right click on it select update /install driver
if your computer came with a mother board disk the drivers could be on it
if you still cant find your mass storage device you might need to download a bluetooth driver
http://download.cnet.com/%7Bvalue=http://www.download.com/bluetoothview/3000-2648_4-10800572.html
Runs in the background, and monitors the activity of Bluetooth devices around you. The BluetoothView application was designed to be a small tools that runs in the background, and monitors the activity of Bluetooth devices around you.
http://download.cnet.com/%7Bvalue=http://www.download.com/bluetooth-driver-ver-5/3000-2110_4-149801.html
to suit multiple usb devices
· Operating system: Windows 95/98/2000/XP/2003/NT/XP 32-bit/AMD 64-bit/2003 32-bit/AMD 64-bit
then download your spyware files to your cell phone
hope this helps
Aug 07, 2012 | Computers & Internet
Tip
How to transfer files between your phone and your computer
Instructional steps
  1. Plug the bluetooth dongle into your computer or if your computer is equipped with an internal module, activate it (this is sometimes accomplished by a switch on the side of your notebook computer).
    Some bluetooth dongles will be automatically recognized and windows will automatically install the drivers for you; however some devices may require the drivers be installed manually.
    Now you'll need to activate bluetooth discovery on your computer. This step may be different depending on the drivers used but should be similar to the following.
    * Look for the bluetooth icon in the windows system tray.
    * Right-click this icon and select open bluetooth settings.
    * Click on the Options tab and select "Turn discovery on".
Activate and configure bluetooth on your cell phone. Setupwill be different depending upon the brand of your phone. You will need torefer to the owners manual of your particular phone for specifics but I willcover general guidelines.
* Locate the bluetooth settings menu in your phone.
* Turn bluetooth ON.
* Give your phone a name (you can use anything you like, but keep in mind thatother bluetooth users can see this name) this is the name that will identifyyour phone when you or others are searching for nearby bluetooth devices.
* Set your bluetooth visibility. This should be set to "shown to all"or "visible". You may wish to turn this feature off when you are notutilizing bluetooth.
Now you'll need to pair your phone and your PC. This can bedone from either the phone or the PC.
From the PC (Windows XP):
* Right click on the bluetooth icon in the system tray and select openbluetooth settings.
* At the bottom of the devices tab, select "Add"
* The Add Bluetooth Device Wizard appears, select "My device is setup andready to be found" and click the Next button.
* The wizard should find your device, if it doesn't, refer back to step three.
* Select your device and click Next.
* When prompted about a passkey, choose "Let me choose my ownpasskey", enter a passkey of your choosing (I like to use 0000 for easebut windows recommends an 8-16 digit passkey). Click Next.
* At this point the computer will attempt to connect to the phone via bluetoothand if successful your phone will prompt you for a passkey. Enter the samepasskey you entered into the computer and press OK.
* If you are prompted to accept a connection request from your computer, selectYes.
Now that your phone is paired with your computer, you arenow ready to begin transferring files. We will use a picture for this example.
* Right click on the bluetooth icon in the Windows system tray and selectreceive a file. This lets your computer know to expect a file transfer from abluetooth device.
* Again all phone models are different so this next step will vary.
Locate an image file on your cell phone and select send - via bluetooth.
* The phone will then search for bluetooth devices in range and display themalong with already paired devices.
* Select your computer from the list of devices.
* The data file will transfer over to the computer and windows will prompt youto enter a file name and choose a location to save the file to.
on Oct 07, 2010 | Computers & Internet
Can't receive file from my laptop
Dont use the bluetooth at all, you should have got a usb cable with the Samsung phone so use that instead it's much easier.
You may have to go into the settings menu on the phone then phone settings, then usb settings and set it to mass storage device then it will show up as a drive in my computer, from there you can drag and drop files easily and way faster............
or
Install the Bluetooth Driver -> http://consumersupport.lenovo.com/ot/en/...
If your not using Windows 7 Put the OS And Driver in here -> http://consumersupport.lenovo.com/ot/en/.....
thanks.
Apr 27, 2011 | Samsung Smooth SCH-u350 Cell Phone
How can i transfer pictures and videos from htc hero to computor
You'll learn how to transfer file (music, photos, videos, ring tones, documents, etc between your computer and your mobile phone.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Easy Instructions Things You'll Need:
  • A bluetooth enabled cell phone.
  • A computer with either a built in bluetooth module or an external bluetooth dongle.
  1. jQuery(document).ready(function(){ jQuery('#jsArticleStep1 span.image a:first').attr('href','http://i.ehow.com/images/a02/4f/q0/phone-computer-using-blue-tooth-1.1-800X800.jpg'); }); Bluetooth Dongle
    Ifyour computer does not come equipped with a built in bluetooth module,you'll need to purchase a bluetooth dongle. These can be picked uponline or in a retail store and average between $10 and $30.
  2. Plugthe bluetooth dongle into your computer or if your computer is equippedwith an internal module, activate it (this is sometimes accomplished bya switch on the side of your notebook computer).
    Some bluetoothdongles will be automatically recognized and windows will automaticallyinstall the drivers for you; however some devices may require thedrivers be installed manually.
    Now you'll need to activatebluetooth discovery on your computer. This step may be differentdepending on the drivers used but should be similar to the following.
  3. Activateand configure bluetooth on your cell phone. Setup will be differentdepending upon the brand of your phone. You will need to refer to theowners manual of your particular phone for specifics but I will covergeneral guidelines.
    *Give your phone a name (you can use anything you like, but keep in mindthat other bluetooth users can see this name) this is the name thatwill identify your phone when you or others are searching for nearbybluetooth devices.
    * Set your bluetooth visibility. This shouldbe set to "shown to all" or "visible". You may wish to turn thisfeature off when you are not utilizing bluetooth.
  4. Now you'll need to pair your phone and your PC. This can be done from either the phone or the PC.
    * Right click on the bluetooth icon in the system tray and select open bluetooth settings.
    * The Add Bluetooth Device Wizard appears, select "My device is setup and ready to be found" and click the Next button.
    *When prompted about a passkey, choose "Let me choose my own passkey",enter a passkey of your choosing (I like to use 0000 for ease butwindows recommends an 8-16 digit passkey). Click Next.
    * At thispoint the computer will attempt to connect to the phone via bluetoothand if successful your phone will prompt you for a passkey. Enter thesame passkey you entered into the computer and press OK.
    * If you are prompted to accept a connection request from your computer, select Yes.
  5. Nowthat your phone is paired with your computer, you are now ready tobegin transferring files. We will use a picture for this example.
    *Right click on the bluetooth icon in the Windows system tray and selectreceive a file. This lets your computer know to expect a file transferfrom a bluetooth device.
    * The phone will then search for bluetooth devices in range and display them along with already paired devices.
    *The data file will transfer over to the computer and windows willprompt you to enter a file name and choose a location to save the fileto.
    * Thats it!!!
Tips & Warnings
  • Allmobile phones are different and some bluetooth drivers are different.Refer to your phone's owners manual for specific phone settings.
  • It is sometimes a good idea to turn off bluetooth on your phone when in crowded areas for security reasons
Jan 09, 2011 | Cell Phones
I can't receive files through bluetooth from another devices. I need to get the APN Settings for LIME so I can activate GPRS.
check your bluetooth settings... should be always allow. maybe u dont have enough feree memory on the fone to receive the file, move everything to mempory card. try again
Dec 03, 2010 | HTC Wildfire Cell Phone
I can not get my song and pitures on to my laptop on my phone i hsve a samsung toco lite phone and i dont no how do it
if your pc has bluetooth easy get your file on the phone click send by bluetooth then set your pc to recieve file thats what i do have same phone
Dec 08, 2009 | Cell Phones
I want sumsung sgh l700 driver
If your problem is transferring files between PC and SGH-L700, you have 3 options: USB cable (which you don't have), bluetooth connection and memory card.
If your PC has a bluetooth adapter, it's very easy: Just open both devices' bluetooth visibility, set a passkey for communication between them, then transfer the files in your phone using bluetooth.
The last option is, saving the data on your phone to the memory card (MicroSD) then inserting it to your PC using a simple (and very cheap) card reader. You can then transfer files between your two devices.
Feb 18, 2009 | Samsung SGH-L700 Cell Phone
Problem with Bluetooth
Bluetooth does not have that kind of connection, it's not the same as a USB cable. There are functions that bluetooth offers called profiles. Depending on the bluetooth stack you have (the one that comes with windows is very limited) will offer you different services, however, I am pretty sure there are no profiles that offer file browsing, only sending and recieving files. You can sync (with like activesync or itellesync) and send files, but not manage file and folder structures, nor request a file.
Jan 15, 2009 | Computers & Internet
Connecting phone to pc
connecting you phone to your pc is quite easy to do.
all you have to have is:
pc with bluetooth capability( dongle)
celphone with bluetooth enabled
whenever your bluetooth dongle is attached to your pc, specially under windows XP, it is automatically configured to locate/find other bluetooth enabled devices under its radius.
when your phone is detected, you are asked to enter a pin to either receive data or send data to your pc.
having a bluetooth software will also lessen your frustration as bluetooth software have instructions or walkthroughs on how to do this.
cheers
Mar 23, 2008 | Cell Phones
Bluetooth
put on the bluetooth on for both mobile and computer. then from desktop open the bluetooth icon and start dun service ur mobile will be conected
Oct 01, 2007 | Microsoft Windows XP Professional With...
Cell Phones Logo
56 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
