Question about Vehicle Parts & Accessories
Prestige car alarm AS 9492 the alarm rings randomly.
The settings are not set to sensitive,
SOURCE: Free programming instructions for Prestige remote
YOU can call prestige tech support at 1800 225 5074.. or just put the key in the ignition turn the key all the way to the right without starting the car then flip the vallet switch usually located at the bottom of the dash drivers side, flip the switch on and off three times, you will hear a chirp then you should press the first button on the remote for 2 seconds then flip the swith on and off one more time , then press the second button the remote for 2 seconds then flip the switch again on and off one more time then press the 3rd button on the remote for 2 seconds... After which... remove the key from the ignition and your done... Try the remote to see if it works the way it should if not do it all over again..
MSB....
Posted on Oct 22, 2008
iadame
  • 676 Answers
SOURCE: make car alarm more sensitive
Locate the shock sensor. Using a small screwdriver you can adjust the sensitivity of the sensor. Move srew in only 1/4 turns as this will make big adjustments. Adjustments may make alarm too sensitive so try it out and see what works for you.
Posted on May 05, 2009
reynosaelect
  • 165 Answers
SOURCE: I need the diagram of alarm Prestige model: APS95BT3
go to google and write this> audiovoxtechservices press enter,and in that website request a password to get the instalation manual
Posted on May 11, 2009
  • 33 Answers
SOURCE: How do I disarm a audiovox prestige car alarm?
Locate the valet/override switch (button), (if you can't locate it, try tracing the wires under the dash from the main unit, usually a black and gray or black and red set of wires). Turn key to "RUN" position then press the button, the alarm's LED should light up solid at this time indicating valet mode as been set.
Posted on Jun 20, 2009
  • 55 Answers
SOURCE: Hi ... My hyundai sata fe has a Prestige Keyless
What you need to find is the valet button which i believe is the blue blinking LED that should be in the dash and it blinks when you arm the system. So try this.. disarm the system and get into the car like normal than put the key into the ignition turn the key to "run" and press and hold the blue LED button till it turns solid. You are now in Valet mode which means the alarm is OFF. Now try starting the car and see if it starts all the time. If it doesn't start and the little blue light is on solid than we have other problems. Because with the alarm in Valet mode the starter disable feature is turned off. However if it does start all the time and gives no problem you might have a loose ground that has to be tightened up or other wiring issues. Now for the alarm going off at random times, you have whats called a "shock sensor" that is adjustable. What this boxs job in life is is to wait for any "impact" like a breaking window or something hitting the car. Notice i didn't say motion. The shock sensor is adjustable and this could be the random going off problem. The shock sensor would be a little box zip tied to a wire loom under the steering column. let me know... mark
Posted on Aug 16, 2009
The alarm on my 2007 ford escape randomly goes off. how is this easily and cheaply fixed?
It depends what is setting it off. If it is just a loose door latch, it is usually easy to fix. Lock the car and set the alarm. Pull on each door handle to see if a door switch opens and sets off the alarm. If it does, adjust the latch on the door to close the door more fully.
If it is not a door switch, maybe the inertia switch is too sensitive. Unless your model has an adjustable sensitivity, that problem is harder to solve.
Aug 12, 2017 | Ford Cars & Trucks
Could having a factory anti theft system and a alarm system in a 2000 isuzu rodeo cause problem because mine will go off randomly and nobody is around
Your alarm system should have a sensitivity setting screw, if you can locate it, it's probably buried behind your dash. If you adjust the sensitivity it might help with the problem.
Oct 19, 2016 | Isuzu Cars & Trucks
I have a Taurus 2004, and it happens that the car horn beeps 3 times randomly. does anyone know what would it may be?
the horn beeping at random is indicating a fault in the alarm system. alarms have their own battery which is balanced by the car battery and any unbalance ( corroded connections -bad earth, low charged battery in alarm, loose battery connections ) will cause the horn to sound --same as too sensitive a setting for the alarm or a intermittent power to the alarm
Mar 08, 2015 | 2004 Ford Taurus
Prestige car alarm
Check you settings something need to be adjusted in your settings!
Apr 04, 2014 | Vehicle Parts & Accessories
Alarm keeps going on and off
More than likely, the sonic sensor has too much sensitivity, and some low level vibrations, such as exhaust noise from nearby cars/ trucks, thunder OR animals going under the car, might set it off. If you have the PRESTIGE alarm, the alarm box on the left kicker panel, has an adjusting screw for the sensitivity. If other brand, it probably has a way to adjust it as well. If it was a problem with doors/ trunk sensor, it would set off as soon as the alarm is armed, so i dont think this is your case.
May 19, 2011 | 1998 Honda Accord
2002 accord speacial edition alarm goes off randomly while parked
Apr 12, 2011 | 2002 Honda Accord
How to put the prestige aps25ch 1200 foot range in valet mode
ALRMM SHOULDN'T GO OFF IN STORMY WEATHER UNLESS U GOT A LEAK SOMEWHERE OR YOUR SENSOR IS TO SENSITIVE
Jul 04, 2010 | Toyota Vehicle Parts & Accessories
My alarm goes off randomly
Many alarms have a mercury tilt switch for motion detection, and if it is set too sensitively, a good gust of wind can set it off.
You need to adjust its sensitivity setting.
May 05, 2010 | 2000 Isuzu Rodeo
My bulldog Model 2010 Alarm is too sensitive and
I got this from their website.
Adjusting the Shock Sensor Sensitivity
To adjust the shock sensor, disarm the system, press and hold Button #3 (Finder) until the alarm chirps four times
(approximately five seconds), immediately release the button. Tap your vehicle’s hood above the alarm at the sensitivity
level you wish. The harder you hit the car the less sensitivity the alarm will be. The alarm will then chirp three
times. The shock sensor is now set at this sensitivity. Any shock that is equal to, or greater than this sensitivity,
will sound the alarm. Set the sensitivity as often as you wish; however, the sensitivity level will remain set until
the battery is disconnected or you reset it. If you do not tap the car it will automatically go to maximum sensitivity.
This setting is only acceptable if the car is parked inside a garage. NOTE: The factory setting on the shock sensor
should be acceptable for most vehicles.
Sep 09, 2009 | Basic Remote Vehicle Alarm System
Alarm sounds intermittently but no flashing indicators
the alarm has a sensitivity setting anything such as a cat or even wind will cause this , hard rain or even if someone brushes up against it ,try upping the sensitivity setting
Aug 11, 2009 | 2007 Audi A3
Vehicle Parts & Accessories Logo
54 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
