ERROR - 4021: IKE(phase1) - Could not contact Gateway (No response) in state
Tip
One For All URC-4021 Manual
Download One For All URC-4021 Universal Remote Manual
Model: One For All URC-4021
Have you lost your Owner's Manual for your One For All URC-4021 Universal Remote Control?
Would you like a digital copy of the One For All URC-4021 Universal Remote Control Users Guide for easy searching of terms and quick reference?
The One For All URC-4021 Universal Remote Control manual is available free in pdf format, just follow the link below (& Click FREE):
Download One For All URC-4021 Universal Remote Control Manual
I hope that helps.
________________________________________________
One For All URC-4021 Code List
One For All URC-4021 Code Entry
One For All URC-4021 Code Search
One For All URC-4021 Reassign Key
on May 30, 2010 | One For All URC-4021 Remote Control
Tip
Download One For All URC-4021 Universal Remote Code List
c450f8f.jpg.
Have you lost your Code List for your One For All URC-4021 Universal Remote Control?
Would you like a digital copy of the One For All URC-4021 Universal Remote Control Code List for easy searching of terms and quick reference?
The One For All URC-4021 Universal Remote Control Code List is available free in pdf format, just follow the link below (& Click FREE):
Download One For All URC-4021 Universal Remote Control Code List
I hope that helps.
Error code 4021
4021 indicates Print job power failure
When there are running jobs, perform the job in error again after the completion of the running jobs.If the error still occurs, turn the power OFF and then back ON, and perform the job again.
Jun 23, 2012 | Toshiba E-Studio 456 Copier
Cannot link vpn. direct from internet provider works. when try connection via d-link dir625 does not connect. does allow internet access
Ok to Setup you VPN follow the instructions below. You can configure DI-804HV, DI-808HV, and DI-824VUP+ by web management interface. Type 192.168.0.1 (The LAN IP is 192.168.0.1 by default) in the browser, and then input user name: admin (there is no password by default) to pass authentication of web management interface. Then finish the configurations as showed below on Gateway A and Gateway B. Configurations of Gateway A 􀂾 Model: DI-804HV (DI-808HV, or DI-824VUP+) 􀂾 Firmware version: v1.40 (You can download the latest firmware on D-Link’s website.) 􀂾 WAN IP Address: 14.15.16.17 (Static IP) 􀂾 LAN IP Address: 10.5.6.1 (Subnet Mask: 255.255.255.0) 􀂾 VPN Configurations: 􀂄 Enable VPN function on Gateway A. 􀂄 Tunnel Name: toGatewayB 􀂄 VPN Method: IKE (Main mode) 􀂄 Local Subnet: 10.5.6.0 􀂄 Local Netmask: 255.255.255.0 􀂄 Remote Subnet: 172.23.9.0 􀂄 Remote Netmask: 255.255.255.0 􀂄 Remote Gateway: 22.23.24.25 􀂄 Pre-share Key: hr5xb8416aa9r6 􀂄 IKE Proposal (Please remember to add the correct proposal ID into the list of IKE Proposal Index when you finish inputting the following information.) 􀀹 Proposal Name: toGatewayB 􀀹 DH Group: Group 2 􀀹 Encryption Algorithm: 3DES 􀀹 Authentication Algorithm: SHA1 􀀹 Life Time: 28800 􀀹 Life Time Unit: Second 􀂄 IPSec Proposal (Please remember to add the correct proposal ID into the list of IKE Proposal Index when you finish inputting the following information.) 􀀹 Proposal Name: toGatewayB 􀀹 DH Group: Group 2 􀀹 Encapsulation Protocol: ESP 􀀹 Encryption Algorithm: 3DES 􀀹 Authentication Algorithm: SHA1 􀀹 Life Time: 3600 􀀹 Life Time Unit: Second 4. Verify the VPN connection Before you start to establish VPN connection between Gateway A and Gateway B, please make sure the Internet connection between Gateway A and Gateway B is workable. You can use “Ping Test” tool on Gateway A (or Gateway B), and input the IP address of Gateway B (or Gateway A) to see if there is any response from its peer device. Connect a PC (called PC_A) to the LAN port of Gateway A, and connect another PC (called PC_B) to the LAN port of Gateway B. Start to “Ping” PC_B on PC_A, then Gateway A will start to establish IPSec connection with Gateway B. If you can get “Ping” responses from PC_B on PC_A, then it means the tunnel has been established successfully. You can also check the “VPN Status” page with web management interface to verify the status of VPN connections. Figure 1: VPN status of Gateway A after IPSec connection has been established. Figure 2: VPN status of Gateway B after IPSec connection has been established.
Hope this helps
Here it is in PDF.http://www.vpnc.org/InteropProfiles/D-Link-DI.pdf
Feb 11, 2010 | D-Link DIR-625 (790069292637) Wireless...
Tip
How to setup VPN on a D-link Router.
Hope this helps
on Feb 11, 2010 | Computers & Internet
IR 5870Ci Errors: E000748-4021 & E000020-03a8
E748-4021 means the SERROR signalof PCI has been detected
solution:disconnect and then connect PCI board if the fault persists ,replace it or the main controller pcb
May 18, 2009 | Canon imageRUNNER C6800 Copier
Gateway digital camera dc-t50
I havd the same problem. The contacts arent pushing the card in far enough to be recognized. Ive been stuffing a small piece of folded paper in there to push it down. Its annoying, but solves the problem.
Oct 18, 2007 | Gateway DC-T50 Digital Camera
Computers & Internet Logo
436 people viewed this question
David Payne
David Payne
