Question about Korg SP170 SP-170 88 Key Digital Piano White with Stand
Sp 170s speakers - Korg SP170 SP-170 88 Key Digital Piano White with Stand
I have a Technics PR-305 Digital Piano. I was playing a couple of songs on it., then about 5 days later. around the beginning of November I went to turn it on it made a loud humming sound from the sp
Yes it can.....but you will need the schematics and some test gear in order to do it.....and a soldering iron....what do you mean by no surround on the speaker?? Can you post a pic??
Nov 25, 2014 | Music
410 bass cab into 210
What kind of problem are you having with this, I assume impedance matching. 2 speakers in parallel cut impedance in half. ex. 2 x 8ohm in parallel equal 4 ohm. IF the same speakers are in series, they double impedance, ex. 2 x 8ohm in series equal 16 ohm. Now matching 2sp and 2 sp, both pairs SHOULD be wired the same and the removal of 2 (dep on config) usually would be treated as 1 ?ohm circuit that equal the other ?ohm circuit. AFTER the removal of 1 leg, the impedance could double or half, depending on configuration.
Mar 12, 2013 | Peavey Music
Korg SP-100 Audio Outs
Look in your midi settings and make sure that "Local" is on to get sound through the speakers.
Mar 07, 2013 | Music
Peavey SP 5 speaker has stopped working
Check the crossover network for cracked solder joints, specially pay attention to the female1/4 jacks as they are very tricky since they are switches also, you might be surprised...
Apr 29, 2012 | Peavey SP 5 Speaker PA Passive
Peavey SP 118P speaker leads...blue and yellow? which one goes where on the speaker?
Blue should go to red. I assume they used an Asian standard. Rough way to remember- sky blue, return brown/ground is green yellow- same potential as brown. yellow somewhere in between.
However reversed leads are not going to be noticed on the speakers of a single amp/speaker. Or if a multi speaker setup in a cabinet as long as all are mated with the same polarity.
It just translates to the direction a speaker cone is moving in relation to the magnet when the polarity of the sine wave peak is positive.
In a stereophonic setup- many can hear the difference an out of phase speaker can make, in a monophonic setup- no one is going to hear the difference. And on a stage setup, unless the speakers are all attached to the same source, they are all moving independently.
Feb 17, 2012 | Peavey Music
I just purchased 2 old Peavey SP-2 and SP-3 speakers. How do I wire from the crossover to the speakers so the horns and 15's are wired in correct.
These cabinets are self contained and you do not use a crossover with them. The speakers do NOT come out to separate connectors. You just drive these with an amplifier. DO PAY ATTENTION to the power rating... you are safe using an amplifier with a MAXIMUM of 150 Watts RMS per speaker cabinet. More than that and running them loud and you will be replacing the speakers. These will cover a 40 foot square room at comfortable level.
Aug 14, 2011 | Peavey SP2 PA Passive Speaker
Whats the wattage of the bulb used in peavey sp2 crossover, my sp2 peavey speaker bulb is blown
The lamp is an "1156" lamp... replace with that part number. Here :
http://search.digikey.com/scripts/DkSearch/dksus.dll?Cat=524517&k=lamp%201156
Or you can find it at auto parts store.
LIKELY the polyfuse device is ALSO gone... Probably similar to this one (1.1 amp, trip 2.2 amp):
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=F2010-ND
or this one (1.85 amp, trip 3.7 amp):
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=F2013-ND
Jan 11, 2011 | Peavey SP2 PA Passive Speaker
Korg SP170 SP-170 88 Key Digital Piano White with Stand Logo
Top Korg Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Korg Music Expert? Answer questions, earn points and help others
