Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Broken pins What exactly happens when one of the pins holding the gear on the icemaker is broken. I have a new Whirlpool with one pin broken, it will make ice in the test mode but not eject it. Could this possibly be the cause? It also will not fill when in normal operation.
  • Anonymous Jan 26, 2009
    Ice is made and dispensed into ice bin. Unable to dispense ice through
    trap door also water dispenser does not operate.
    Model 6GCSTHGXK500
    President:
  • 1,214 Answers
Please provide the specific model number of your refrigerator so more detail information can be provided. You description doesn't quite make sense.
Posted on Jan 24, 2009
97 nissan quest will not move when in gear and the vehicle is rolling freely when in park. ....suggestions? Grinding sound when in gear and the drive shift on the driver side is spinning free
Well, there's a Pin that holds the transmission gears in place when you've got the car in park. This Pin blocks the gearbox from moving... either the pin isn't fully engaging the gearbox, or it's just broken.
If it's not engaging, it's just a question of adjusting the shifter linkage. That can be fixed relatively quickly.
However, the accompanying grinding sounds really make it sound like it's broken.
Jun 24, 2014 | Cars & Trucks
Ice in bucket freezes into a lump, mechanism freezes
it sounds like the ice chute door is stuck open. on this model it can slip off the "hinge pin" or the plastic that holds the pin can break. if the flap is broken it is replacable. the pin can be put back in. if the plastic that holds the pin is broken, you need to replace the whole door. expect to wait 6-8 weeks for a new door, sooner if lucky. cost is $400 +++ more for stainless.I hope the pin fell out. hope this helps
Jun 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool gold ice machine not working
The most likely cause is the water solenoid behind the fridge. Take an ohm meter and test across the two terminals and it should NOT ohm out (beep). If it does not ohm out I would replace the P.C. Board kit, emitter & receiver icemaker control
Dec 30, 2008 | Whirlpool Gold Series GI15NDXT 15"...
How do you replace a bad thermostat in an icemaker?
First you have to remove the icemaker. The is one 1/4in screw holing the in on the bottom back right corner. Once that is removed you can remove the plastic shield that it was screwed into by pulling up and back on it. After that the icemaker can be pulled straight out towards you. (it might take a little force and wiggling of the ice maker to do so) Unplug the icemaker by inserting a small flat screw driver under the tab at the harness.
On the right of the icemaker is a white square cap. Remove it to expose a big gear. Check the pins in the middle to make sure they aren't broken.
If the pins check ok then the problem is either the motor or thermostat. To replace the motor the whole part in the picture above (the Module) needs replacing (Part#W10122536) To replace it remove the three screws in the top two and bottom right corners, pull off the module and replace it with the new one.
To replace the thermostat (part#627985) remove the module and set it aside. Under where the module sat you will find two screws. Remove them and pull out on the black plastic casing. (Be careful because the the ice arm and stripper will fall off when you do this. In the bottom middle of the opposite side is the thermostat. Pry it out and place the new one in. You'll need some stuff called alumilastic. (Part#4317852) Put a dap on the new thermostat and put it all back together.
After It all back together and in its place it may take a couple of hours for it to make the first batch of ice. Good Luck and let me know if you need any clarification.
Nov 03, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool pin retainer is broken on ice dispenser
yes it is before we were repl doors but whirlpool came up with this kit to fix problem just follow instruction exactly and cleaned are real good so the bracket will stick tight you can use nail polish remover alcohol ok make sure you install all parts
Oct 13, 2008 | Whirlpool ED2FHEXN Side by Side...
Whirlpool GD5RHAXNQ00 Ice maker not making ice
We had a similar problem and there was a broken/stripped gear in the icemaker. A&E replaced it to the tune of $150 or so. I don't recall exactly but I recall my husband thinking he could replace the entire icemaker for the price we paid to repair it. The gear make the ice tray flip out the ice once frozen. Good luck, hope that helps a little.
Jun 21, 2008 | Whirlpool GD5SHAX Side by Side...
Whirlpool ed2fhexnq00 icemaker will not dispense filled with ice
can you see the ice maker's white cover?? try to pry that off , usually a little space for a ***** driver to be inserted into where the body of ice maker and the cover meet in lower right corner. after removing check the gear in center of ice machine. there should be 2 little tabs that hold that gear on." picture trying to snap that gear on , the tabs would hold it in place" do those tabs appear tobe broken?? at least one anyway(although small ther should be a distinct space between the tabs where they sprung back into place) if theyre broken, theres your problem you need to replace the ice maker assy,(entire unit)
Mar 13, 2008 | Whirlpool GD2SHGX Refrigerator
Ice maker not working
the icemaker will run at 120v ac +- 10% so 108 v is within range altho marginally. since you have the icemaker removed. remove the front cover and check to see if the drive gear is broken or if the 2 center pins that hold the gear in place are twisted or broken. this is most likely the problem. the motor module can be replace very easily part # is 8201515
the normal home position for this icemaker is at the 2:00 position facing the front of the icemaker. if it is any other position the motor module is almost always the culprit..
Dec 17, 2007 | Refrigerators
Pin retainer broken off from ice dispenser housing
Ill be gald to help you here....The people who answer the phones must be worthless, anyway the part number is 8201756 (ice door kit) it will probably have to be specially ordered, i have installed several and there not exactly easy but it can be done with some patience. Pass this along to your repair guy as he is not giving people correct advice.
Oct 09, 2007 | Whirlpool ED2FHEXN Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
111 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
