Question about Minka F719-TSP Treville Tuscan Patina Ceiling Fan
F719 going in reverse
My F719 recently started going in reverse and that wouldn't be surprising, except that I only use a wireless controller and this particular controller does not have a reverse button. So what could have made it start going in reverse? How can I get it to go in the right direction?
    Scholar:
  • 65 Answers
You may find your answer here http://www.ceiling-fans-n-more.com/ceiling-fan-remote-controls.php
Posted on Jan 24, 2009
How to fix reverse problem.
it sounds like you need a rebuild. blackish fluid indicates clutch failure.
Sep 14, 2014 | 1990 Buick LeSabre
I would like to find the following two items: minka lavery treville collection......f719-tsp which is a fan and 1365-196c which is a 5 light mini chandlier
I have the 1365-196c in brand new condition. We recently changed fixtures. I believe it sold for nearly $2k new, but I am willing to sell it for a very reasonable price. If we could work it out, I also have the fan and multiple other minka fixtures in the same collection.
Please contact me if interested.
Sep 22, 2013 | Minka Lavery Minka Aire F702-TSP Volterra...
Zonet home wireless router blocking facebook suddenly, no recent changes to network
Have you tried Unplug Modem, remove battery, unplug wireless, Install battery in modem, plug in, wait for selftest, plug in wireless device, wait for self test, plug in computer, boot normally. If that fails Push and hold the reset button on the wireless device for 30 seconds. The Moden should have a reset as well, push and hold for 30 seconds or so. If I had the Make, Model of the Modem and Wireless device I could be more helpful.
Dec 05, 2012 | Zonet Computers & Internet
Wiring for reverse switch on a 2008 ford expedition
You probably didn't do anything to the wiring ,relay contacts maybe stuck closed ,Check the relay or have it check for DTC'S
Transmission Control Module (TCM) Diagnostic Trouble Code (DTC) Chart DTC Description Action P1910 Reverse Lamp Control Circuit/Open Go To Pinpoint Test U . P1911 Reverse Lamp Control Circuit Low Go To Pinpoint Test U . P1912 Reverse Lamp Control Circuit High Go To Pinpoint Test U .
Principles of Operation
The transmission control module (TCM) sends gear status information to the PCM over the communication network. When the transmission is in REVERSE (R), the TCM energizes a relay which supplies voltage to the reversing lamps.
Oct 18, 2017 | Cars & Trucks
I went to reverse the car out of a parking place at the grocery store and it wouldn't go in reverse. What could the problem be.\
Hello and welcome to FixYa!
One cause why it wouldn't go in reverse is because of a bad TCM (transmission control module). If the TCM is faulty something in the transmission will surely fail. Please have the TCM checked and replace if necessary.
Hope this helps and thank you for using FixYa! Have a good one!
Sep 12, 2011 | 1999 Volkswagen Beetle
Minka F719 Lavery Wired fan and fan works but light does not come
The light leg should be hooked to a power source. If you have a separate wire from a wall switch, that's where it should be hooked. Otherwise, you can hook it to the fan leg and operate the light from the switch on the fan.
Jan 31, 2010 | Minka F719-TSP Treville Tuscan Patina...
Door won't stay closed, then opens only partially.
If the main light flashes 10 times when the door reverses it is a door sensor problem. Each sensor has a small light that must be on and not blinking for them to work properly. If one of them is not on tweak them a bit to make sure they are pointed at one another.
The stopping about 1/3 of the way up is either a broken door spring, a main drive gear that is going bad or an adjustment to the 'up force'. The 'up force' control is on the back of the motor unit near where all those white wires go. Increase it a bit. It will sometimes compensate for a gear that is going bad but if this is the case it will start doing the same thing soon.
Oct 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Panasonic plasma won't change channel or volume
Also had the same problem with our Panasonic 50" Plasma...could not change the channel or the volume (with the remote control nor with the actual TV controls). Before I called for repair, I UNPLUGGED the TV and then plugged it back after a minute. I was surprised....the TV started working again. (Switching the TV on and off is not sufficient). I could change channels and volume, etc. So this saved me a repair this time. Might be worth trying this solution. Wouldn't hurt one bit, but rather save you a repair fee.
Aug 26, 2009 | Televison & Video
I have a linskys wireless G access point. Its working for my laptop but just recently my laptop said that my interent secuirty is secuirty enabled and that linkys is a unsecure network. What do I do? It...
jpconda - you did nothing wrong.
By changing your SSID, your connection broke, because you were still associated with your old SSID (linksys).
Right-click on your wireless network connection symbol in your taskbar and choose "View Available Wireless Networks". If you broadcast your SSID, you should see your new name in the list.
Just connect to it (and hopefully enter the security key..;-).
If you don't see it, go to 192.168.1.1 and enable the broadcast of your SSID ( on the Wireless Tab - Basic Wireless Settings). Don't forget to save your changes!
Once your are connected, you can disable the broadcast again, if you don't want someone else to "see" your network.
Jan 11, 2009 | Linksys Wireless-G WRT54G Router
Minka F719-TSP Treville Tuscan Patina Ceiling Fan Logo
203 people viewed this question
Top Minka Dryers Experts
Joseph Coppeto
Joseph Coppeto
Are you a Minka Dryer Expert? Answer questions, earn points and help others
