Thermocouples for Martin gas heater model no au40ad/u40ag/uf40ag
Replacement thermocouples
SOURCE: Procom Model SN400TYLA Thermocoupler bad, can't find part
try 18778865989
Posted on Oct 28, 2008
protek480
  • 1714 Answers
SOURCE: Need a replacement thermocouple for my DynaGlo Pro
All thremocouples have a number on them which tells what 'millivolt' output it has. Try to match that up or call a HVAC company and ask them for one with that number.
Posted on Oct 05, 2009
  • 128 Answers
SOURCE: i have a 5 year old glo-warm ventless
Since the thermocouple body is made of metal, and often these have a copper or brass sleeve, that *should* provide good grounding for the thermocouple.
Obviously some engineer at the heater company did not agree with this, so he added an extra ground wire.
Most gas valves are not all that sensitive to exactly how many microvolts the thermocouple feeds to it.
My guess would be that if there is a cheap metal bracket that holds the thermocouple, such as unplated steel or tin, the extra ground wire counteracts the effects of corrosion over time.
So if the heater were stored in a damp garage, the thermocouple connection would get corroded, and the heater would not stay lit. The fix is the extra ground wire.
There are two types of failures with thermocouples: the safe-failure is when the gas is shut-off, even when flame is present, and the unsafe failure would be when gas is not shut off, even when no flame is present.
If the thermocouple somehow was not adequately grounded, then the most likely failure would be a 'safe failure' , such that the burner would not stay lit.
You could rig up some sort of extra grounding wire, but unless the part is subject to extreme vibration or is in an extreme (wet/salty) environment, it's probably not needed.
Of course, to be safe, do a flame blow-out test after you install the new part. While it's highly unlikely that an unsafe failure could occur, better safe than sorry.
Posted on Oct 21, 2009
  • 8404 Answers
SOURCE: Charmglow gas patio heater won't start
You got to heat the thermocouple to get the gas valve to open ... I guess you know that ... You checked for spider web???
Posted on Jan 18, 2010
rockmeister
  • 2047 Answers
SOURCE: parts for martin ind heater au40al how to replace
A thermocouple is a junction between two different metals that produces a voltage related to a temperature difference. Thermocouples are a widely used type of temperature sensor for measurement and control and can also be used to convert heat into electric power.
The following steps can be used to replace them
- Shut off the gas supply valve to the heater. The supply line connects to the thermostat at the bottom front of the tank. Turn the gas supply valve clockwise to shut it off.
- Remove the screws from the outer door at the bottom of the tank and remove it. The outer door covers the pilot tube, supply tube and the thermocouple connection.
- Remove the screws from the inner door located behind the outer door. If your heater allows, remove the inner door. If the inner door is an integral part of the burner assembly, leave the door on but leave the screws removed.
- Disconnect the pilot tube, supply tube and thermocouple from the thermostat. Use an adjustable wrench and turn all three nuts counterclockwise that hold the two tubes and the thermocouple onto the thermostat.
- Pull the burner assembly from the combustion chamber located behind the inner door. They could connect to the inner door as stated in Step 3.
- Remove the old thermocouple and replace it with the new thermocouple. The thermocouple attaches to the burner assembly in a bracket next to the pilot light. Pull and twist the old thermocouple from the bracket.
- Push and twist the new thermocouple into the bracket. Position the tip of the thermocouple where the pilot light flame heats the tip of the thermocouple.
- Replace the burner assembly into the combustion chamber and reattach the pilot tube, gas tube and new thermocouple to the thermostat.
- Reattach the inner and outer doors on the bottom of the tank and turn the gas supply valve back on. Do not forget to light the pilot light.
Hope this solution has been helpful?
Posted on Dec 03, 2010
My gas richmond water heater quit working, replaced thermal coupler light pilot good burner lights and goes out
Did you get the thermocouple positioned so the pilot flame just touches the side of the thermocouple sensor? Is the pilot flame blue with a slight orange tip? Did you use an exact replacement part? Not all thermocouples produce the same millivolts needed to keep the gas valve open. If you think all of these items are correct, then the main gas valve is defective.
Jul 28, 2017 | Water Water Heaters
I need thermocouple for gas log heater.model number on valve assembly is 0630545
There are universal thermocouples available. Most are not specific to the appliance.
Ring your local gasfitter. I don't recommend trying it yourself.
Sep 04, 2016 | Heating & Cooling
When i try to turn on the oven, it clicks and lights but then the flame goes out
You may need to replace the thermostat/thermocouple. This is a common part that needs replacement every few years (sometimes they just stop working sooner too). It's cheap and relatively easy to change. The purpose of this is to prevent a gas leak (because the oven is turned on) if the flame were to go out and could not be re-lit.
Thermocouple Thermocouples What is thermocouple Types of thermocouples
Feb 02, 2016 | Bertazzoni Gas Range
We have a Chesterfield Cannon double oven (gas) the top oven would not stay lit after holding in the control knob in for several seconds, the engineer came out and fitted 2 new thermocouples but the t
Swap the two thermocouples to see if problem switches. If it does bad thermocouple on one that does not work. If it is the same somethng is wrong with the gas vave itself. The holding coil leading to that burners thermocouple is most likely bad.
Sep 06, 2014 | Heating & Cooling
Flame of water heater does not light up
You need to replace you thermocouple its the tiny copper in color probe going into water heater. This componet works of milli volts and keeps the pilot lit when this goes bad the pilot goes out. Heres what you need to do shut gas off take all fittings off gas valve thats the thing with the knob on it to set water temp. pull out manifold and remove thermocouple by pulling at the base straight out. You can buy replacement thermocouples at your nearest hardware store.
May 11, 2011 | Heating & Cooling
Were would i buy a thermocouple for model 5018732 wall furnace in Ontario.
usually thermocouples are universal, the main difference is the length of the lead which doesn't really matter as long as it is long enough. You can pick them up at a hardware store usually located in the plumbing department close to the gas water heaters.
Nov 02, 2010 | Williams 1403622 Gas Compact Heater
Will lite but goes out within a min
Make sure the thermocouples not fully engulfed in flame, it needs to be on;y at the tip end as they operate via temperature differential acrosss the thermocouples surface, if the whole thinfs one temp it drops out electrically(makes 30 millivolts) and the electromagnetically operated pilot safety valve closes, thus stopping the main burners operatin as its sensing no pilot exists. try a new thermocouple, about 15 bucks, and set it as described in pilot flame, if that wont do it, the gas valves bad.
Nov 01, 2010 | Blue Rhino ES200209 Open Flame Gas Patio...
I have a 5 year old glo-warm ventless heater(propane)that needs a new thermocouple. the old one has an extra wire soldered to it that looks like a grounding wire? all the replacement thermocouples do not...
Oct 21, 2009 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Need parts: pilot assembly and thermocouple
THe thermocouple either has 2 wires or a coppr tube going to the gas valve. They can be bought at a good hardware store or a plumbing supply. The length of the wires or copper tube will be the determining factor as to which one you need. As these thermocouples, when heated generate a small electric charge tha keeps the gas valve open. Should cost no more than $10-15 USD
Oct 10, 2009 | Berkeley Forge G-PH001PSS Open Flame Patio...
Dyna-glo parts
thermocouples you can buy from any heating spares oulet or national energy a hone well is most common for useing as a replacement
Feb 03, 2009 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Heating & Cooling Logo
98 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
