Question about Vehicle Parts & Accessories
How to use the prestige alarm remote model aps92bt2cl
4 Suggested Answers
SOURCE: Free programming instructions for Prestige remote
YOU can call prestige tech support at 1800 225 5074.. or just put the key in the ignition turn the key all the way to the right without starting the car then flip the vallet switch usually located at the bottom of the dash drivers side, flip the switch on and off three times, you will hear a chirp then you should press the first button on the remote for 2 seconds then flip the swith on and off one more time , then press the second button the remote for 2 seconds then flip the switch again on and off one more time then press the 3rd button on the remote for 2 seconds... After which... remove the key from the ignition and your done... Try the remote to see if it works the way it should if not do it all over again..
MSB....
Posted on Oct 22, 2008
reynosaelect
  • 165 Answers
SOURCE: I need the diagram of alarm Prestige model: APS95BT3
go to google and write this> audiovoxtechservices press enter,and in that website request a password to get the instalation manual
Posted on May 11, 2009
logosc75
  • 625 Answers
SOURCE: My alarm light blinks twice stop then twice and
The LED blinking twice and, the trunk and hood being displayed on the remote indicates trunk/hood trigger. Now, when you attempt to remote start the vehicle and nothing happens, it's definitely the hood pin switch. By the way, the remote should be displaying "inhibit" as well at this point. Check for the hood pin switch under the hood; it's probably bent downward, not allowing the pin to make contact with the hood when it's closed. If it's a bracket, bend it upwards. If it's a pin, unscrew it upwards a couple of turns so it makes contact with the hood when it's closed.
Posted on Dec 14, 2010
Prestige car alarm remote not working
mostly self serve fixing them . id ask at a tint an alarm place
there is function to pair them again . have the remote tested if its putting out signal . point at a camera an watch . take it to autozone . listen to it on a radio close to it. you have 2 is the other working.
Jan 05, 2015 | Audiovox PRESTIGE APS920FACTORY...
Prestige car alarm/remote start not working properly
This would be difficult to give an accurate diagnosis without full details like:- what model alarm system or vehicle this is for!
sounds like it might be the starter connection to the key switch is disconnected!
Oct 13, 2014 | Prestige Remote Start
I bought my car used with an aftermarket prestige alarm w/ remote start. Battery and alternator went bad. They have been replaced. The car will not turn on and alarm remote is not working.
Locate a black push button switch under the dash or near the drivers side kick panel (older model), or the alarm has a push button LED light(newer model) or the Valet switch is in the antenna(newest model). Turn the ignition on, press and release the switch one time. This should disarm the alarm.
For programming: turn ignition on, press and release the valet switch three times: you will hear one chirp from the alarm, press the lock button on the remote. Press and release the valet one time, you will hear two chirps from the alarm, press the unlock button on the remote. Repeat as necessary. Turn igniton off to exit programming. Test remote for proper functioning.
Jul 16, 2011 | Prestige Appliances Vehicle Parts &...
I have a new prestige car remote installed recently and i have a problem how to shut off the alarm coz the installer did not or forgot to give me the manual. When i start the car remotely i press the...
You did not mention the year/make/model of your vehicle but, the issue appears to be the factory alarm. The installer failed to make the connection. If you intend to make the connection yourself I would need information pertaining to the vehicle. The (-) pulse before start wire for Prestige remote starters is black with a blue stripe. It is in a 4 pin connector at the module. This wire can be used to disarm the factory alarm before the remote start sequence.
Jan 23, 2011 | Prestige Remote Start
Can't. Find unlock code for my radio in my 1998 vw beetle. An I don't. Have owners manual
The radio will have to be removed from the dashboard.
Then post the radio make+model plus all the letters+numbers on any labels,barcodes or engraved in the metal casing.
Jun 27, 2010 | Audiovox Prestige Code Alarm Remote Alarm...
I need to see if a add on remote start will work with my prestige
The APS9076 is a OEM add-on remote start module only and not an alarm. Are you trying to add or find a remote to an existing Prestige alarm or installing one?
Aug 02, 2009 | Audiovox AS9076 Car Upgrade Remote Start...
I don't know how to use my keyless remote start
DO YOU THE MODEL OF THE ALARM,PROBABLY NOT,EMAIL ME I THINK I CAN HELP YOU,I NEED TO KNOW HOW THE REMOTE TRANSMITER LOOKS LIKE.HERES MY EMAIL: reynosalectronics@live.com.mx
Mar 14, 2009 | Prestige Remote Start
How do i program the remote start function on prestige 997
email me i cant help you,i need to know the model of the alarm and what kind of vehicle is installed here is my email reynosaelectronics@live.com.mx
Mar 13, 2009 | Prestige Remote Start
MSB....
Oct 13, 2008 | Gmc Dodge Ford Reverse Back-up Sensor...
Vehicle Parts & Accessories Logo
63 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
