Thermocouples for Martin gas heater model no au40ad/u40ag/uf40ag
I need thermocouple for gas log heater.model number on valve assembly is 0630545
There are universal thermocouples available. Most are not specific to the appliance.
Ring your local gasfitter. I don't recommend trying it yourself.
Sep 04, 2016 | Heating & Cooling
We have a Chesterfield Cannon double oven (gas) the top oven would not stay lit after holding in the control knob in for several seconds, the engineer came out and fitted 2 new thermocouples but the t
Swap the two thermocouples to see if problem switches. If it does bad thermocouple on one that does not work. If it is the same somethng is wrong with the gas vave itself. The holding coil leading to that burners thermocouple is most likely bad.
Sep 06, 2014 | Heating & Cooling
Water heater pilot lights no burners
The thermocouple must be defective. Thermocouples convert the heat from the pilot into milli volts to open the gas valve. This is a safety to ensure there is a flame, so the gas doesn't just build up (that can cause an explosion)
Jan 16, 2013 | A.O. Smith BTN-200A Commercial Tank Type...
I need a thermocouple for a dyna glo natural gas wall heater
Billy here's a link to A & B Sales. They have what you're looking for. Whether your heater is Natural Gas or Propane makes no difference when it comes to thermocouples.However the length of the tubing does when it's a wall or stand type vent-free heater.
http://www.aandbsales.com/2.html
Hope this helps you & thanks for choosing FixYa.
Sep 21, 2011 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Martin Gas Logs Model 18TCP Lost Flame including Pilot and will not relight. What could cause this?
if pilot is there when it is depressed in pilot mode then the thermocouple is bad.if no pilot gas check for inlet pressure to log set
Jan 03, 2011 | Desa International CCL3924PTA 24" LP Gas...
Need to replace a pilot *** on a cozy heater model dvcf653b
there are 3 phillips head screws on the bottom of heat exchanger and wre the burner assy. meet and 3 wing nuts on the bottom back remove and disconnect the gas line and the wires to valve and remove the assy. easy to remove thermocouple from this point install in reverse order, may need to adjust the pilot flame down on the gas valve if the pressure is causing the thermocouples are burning out.
Dec 09, 2010 | Cozy (W352E) Heater
Were would i buy a thermocouple for model 5018732 wall furnace in Ontario.
usually thermocouples are universal, the main difference is the length of the lead which doesn't really matter as long as it is long enough. You can pick them up at a hardware store usually located in the plumbing department close to the gas water heaters.
Nov 02, 2010 | Williams 1403622 Gas Compact Heater
Will lite but goes out within a min
Make sure the thermocouples not fully engulfed in flame, it needs to be on;y at the tip end as they operate via temperature differential acrosss the thermocouples surface, if the whole thinfs one temp it drops out electrically(makes 30 millivolts) and the electromagnetically operated pilot safety valve closes, thus stopping the main burners operatin as its sensing no pilot exists. try a new thermocouple, about 15 bucks, and set it as described in pilot flame, if that wont do it, the gas valves bad.
Nov 01, 2010 | Blue Rhino ES200209 Open Flame Gas Patio...
Pilot assembly parts or thermocouples
Hardware store thermocouples don't work on patio heaters. The fittings are not the same thread and they are not set up for the anti tilt safety switch. You'll need to purchase the parts from Blue Rhino.
Jan 29, 2010 | Endless Summer 233000 Open Flame Patio...
Charmglow gas patio heater won't start
You got to heat the thermocouple to get the gas valve to open ... I guess you know that ... You checked for spider web???
Jan 18, 2010 | Coleman (5040B750) Patio Heater
Heating & Cooling Logo
125 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
