Question about Sewing Machines
I need a manual for a kenmore 1601 zig zag sewing machine where can i find a free download?
  • 15 Answers
SOURCE: how to oil my sewing machine
Kenmore machines may have parts and manuals available on searspartsdirect.com -- have the correct model number usually a 3 digit a dot and the rest of the numbers (i.e., 158.xxxx or 385.xxxx1). You will see a list, and if you click on parts or attachments list and scroll down into the parts list, there should be a manual listed as either available or not.
As to the new machines, Euro-Pro or any other, if really cheap, then my personal feeling is that they are planned to not last for a long time -- which may account for the lack of oiling instructions in their manuals. The other possible reason 'may' be that like some Viking Husqvarna machines, the metal parts could be infused with oil and the heat from running them produces the oil needed as it runs. Somehow I doubt that could be the answer in an inexpensive machine. If a lot of the parts inside are plastic, then no oil is needed, and they will run until the plastic breaks, necessitating a trip to the repair shop.
Only use sewing machine oil which can be bought at any JoAnn's, Walmart, sew and vac, or sewing machine dealer. Never use household oil or the yellow/blue can of spray that is a water displacement solution which ultimately will gum up the works. You could use Tri-Flow Superior Lubricant.
Basic oiling procedure is to oil wherever metal parts meet (possible friction points) or slide past each other -- a drop or two usually. No grease needed on plastic gears. If you have an old machine with metal gears, then use sewing machine lube (grease) or Tri-Flow lube (can get it at a bicycle shop if no where else).
Posted on Nov 20, 2008
  • 323 Answers
SOURCE: can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
Posted on Feb 16, 2009
  • 18 Answers
SOURCE: Singer 457 Zig Zag Sewing Machine not catching bobbin thread.
There are manuals avilable online to purchase for the singer machines, SOrry I was not able to locate a site that has them for free.
.... http://sewingonline.co.uk/singer-manuals.html
Posted on Aug 16, 2009
  • 16 Answers
SOURCE: Bobbin winder will not spin on sewing machine
If you take the top off you will see a tiny rubber tire that engages the winder to the handwheel. Over time they get really soft are really hard and disintgrate. If you have a local sewing shop take the old one in and get a new one to slip on it takes only a few minutes and cost usually less that $2.00
Posted on Jan 22, 2010
SOURCE: bobbin singer stylist zig zag model 477
Check this web page
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_477_threading_diagram.htm
Posted on Jan 23, 2010
HOW DO YOU CHANGE THE STITCHING FROM STRAIGHT TO ZIGZAG
Check that your sewing machine is even capable of zig-zag. Some machines are straight-stitch only.
Consult your owner's manual.
If your machine can do zig-zag, somewhere there is a dial or setting called "stitch width" that will determine how wide the zig-zag will be.
May 21, 2016 | Sewing Machines
Hi! I'm looking for a manual for a vintage Morse 550 zig-zag sewing machine. Need help with tension assembly.
manual for a vintage Morse 550 zig-zag Kathleen, Check the attached links,manuals and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Morse 550 zig zag manual Google Search
Morse 4300 Zig Zag Sewing Machine Instruction Manual Fotomatic III
Morse Pushbutton ZigZag Sewing Machine Threading Diagram
http://www.sewusa.com/Sewing_Machine_Manuals/Morse_Sewing_Machines.htm
Mar 31, 2016 | Sewing Machines
How to install a Kenmore monogramer to a Kenmore zig zag machine
You are replacing the presser foot with the monogramer and you will need the very specialized instructions for it's proper use.
Jan 30, 2014 | Sewing Machines
Trouble sewing lycra fabric using a zig zag stitch
You have the machine set for blind hem stitching. Change the stitch selector to stretch stitch, which is a single, in line stitching zig zag stitch.
Cheers,
Embroidery Services
San Diego, CA
Sep 13, 2017 | Sewing Machines
Kenmore 1560 Sewing Machine
Be sure TOP control shows zig-zag. Flip top right bar from red to black or black to red on side of machine facing you. You can then change the widths by changing the numbers on that same circle control.
Feb 26, 2008 | Kenmore 15516 Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
